Old 08-04-2013, 03:03 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Sitting on the side of the road. coolant all over engine bay
Just going down the interstate and cel comes on, coolant hot or low sensor voltage. Pull over coolant is almost at 300f and oil at 270f . Coolant is all over the engine bay like a bad Japanese porno. I have no idea what has happened. Waiting on tow truck atm.
Old 08-04-2013, 03:10 PM   #2
arghx7
Drives: car
When and what was the most recent work done in the engine bay?
Old 08-04-2013, 03:15 PM   #3
ML
ML's Avatar
Catch can on the pcv line last week. Been running fine though.
Old 08-04-2013, 05:20 PM   #4
DarkCard
Drives: Asphalt Scion Frs 6MT
Wow thats odd, did you hit something? the caps look in tact I'm almost thinking the radiator ruptured
DarkCard is offline   Reply With Quote
Old 08-04-2013, 05:25 PM   #5
xjohnx
Grip>Slip
xjohnx's Avatar
Have you been able to locate the source yet?
Old 08-04-2013, 05:51 PM   #6
ML
ML's Avatar
Car is sitting at my brothers shop until morning. Currently drinking heavily. Will report asap.
Old 08-04-2013, 06:39 PM   #7
Opposed
Drives: 2013 Asphalt FR-S
That's kind of what im thinking as well. The upper hose looks to be ok. A head gasket could do this, but it would be odd, and most of the spray seems to be heavy on the front of the engine. What was the temp gauge reading? I wonder if it overheated, then boiled over through the overflow tank or rad cap???
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 08-04-2013, 07:15 PM   #8
ML
ML's Avatar
Yeah it looks like it overflowed into the fan or something. What would cause it to overheat though. Please not head gasket.
Old 08-04-2013, 10:40 PM   #9
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
idk about the over heating but the way it sprayed your engine bay looked like how my old sti did with a radiator crack.
bkblitzed is offline   Reply With Quote
Old 08-05-2013, 01:34 PM   #10
ML
ML's Avatar
I hope its just a radiator crack, and not HG...I remembered when I changed the oil, the coolant was a little low, but my brother didn't have the right antifreeze the maintenance book called for so he just topped it off with the normal stuff he had. Could this have caused the antifreeze to
gunk up in the line somewhere and then blow? It couldn't have been more than a few mL.
Old 08-05-2013, 01:40 PM   #11
celica73
I doubt mixing the different types of antifreeze would do this, but I question why you would do it. If you don't have any of the right stuff, just top it off with water. In NC a little antifreeze will go a long ways. We don't need -20 protection.
Old 08-05-2013, 01:41 PM   #12
brz_star21
Drives: DGM BRZ
What was the water-to-coolant ratio used? Looks more like a radiator failure than the engine.
brz_star21 is offline   Reply With Quote
Old 08-05-2013, 01:46 PM   #13
ML
ML's Avatar
Not sure, what ever was from the factory. Engine still runs fine, I cranked it up for a minute or two last night. No smoke, or noises, everything seems to run fine.
Old 08-05-2013, 01:48 PM   #14
ML
ML's Avatar
True, I don't know, we just didn't.
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
Green engine coolant used quickly? Tylub Issues | Warranty | Recalls / TSB 19 06-19-2013 01:15 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-13-2013 11:33 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
What's Everyone's Mileage Sitting At Right Now? IchigoIchie CANADA 28 08-11-2012 11:56 PM
