Old 08-04-2013, 12:40 PM   #15
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Originally Posted by hmong337 View Post
@Lee358
Wow! That's cutting it close. Is there any rub on full lock?
Thanks for posting.
not that i have experienced
Lee358 is offline   Reply With Quote
Old 08-04-2013, 01:52 PM   #16
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
Mines rubbed the front shocks on 17x9 45et with 245/40/17 ego v12 tires on OEM suspension in hard cornering.
garfull is offline   Reply With Quote
Old 08-04-2013, 01:55 PM   #17
Lee358
Lee358's Avatar
did you end up with a spacer?
Old 08-04-2013, 02:03 PM   #18
garfull
garfull's Avatar
Long story short I went coilovers but now I'm switching back to OEM shocks. There was 2mm of clearance when it rubbed. Going to look at 5mm spacers on the front but I'm still concerns that with the camber bolts I'm still going to rub. Will have to see once I swap the suspension back.
Old 08-04-2013, 02:14 PM   #19
garfull
garfull's Avatar
Old 08-04-2013, 02:45 PM   #20
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Yea, this is the reason I was looking into the offset ranges as I don't want any clearance issues with anything +40 or higher.
hmong337 is offline   Reply With Quote
Old 08-04-2013, 03:06 PM   #21
wparsons
wparsons's Avatar
If you want to run useful camber up front from camber bolts (-1 to -2*) you'll want +35 with 17x9 wheels. The +45 might fit at 0* but it might rub and will definitely rub if you run camber bolts.
flickr
Old 08-04-2013, 10:26 PM   #22
whataboutbob
AutoX-10/10ths every run
Originally Posted by Kai Uhl View Post
how would one get those whiteline decals?
I had them custom made by a local shop. I won the AutoX raffle at the last 86fest and got a amateur sponsorship out of it. PM me and I can get you in contact with the shop that I worked with if you are interested.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
karma003 (08-09-2013)
Old 08-04-2013, 10:27 PM   #23
whataboutbob
Originally Posted by Mach V Dan View Post
That's not the case.
255/40R17 on Mach V Awesome 17x9 +42.
--Dan
Mach V
Are you are on stock suspension/ride height? If so, ok. I couldn't get a 255 on a 17x9et35 on my car with the RCE springs/factory struts, Whiteline camber bolts, and COMCs.
Build thread:Here
Old 08-04-2013, 11:11 PM   #24
fstlane
fstlane's Avatar
Drives: BRZ Limited
I'm curious also. I'm running 17x9+42 Rota Titans with 245 Direzza Z2 tires and I have about 4mm of clearance. This is with stock struts, camber bolts and alignment. The only thing I replaced was the springs with RCE Yellows.
fstlane is offline   Reply With Quote
The Following 2 Users Say Thank You to fstlane For This Useful Post:
cirros (05-13-2020), mulekr1 (01-16-2017)
Old 08-05-2013, 09:47 AM   #25
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Yes, these pictures are of stock suspension. That was the original subject...
i'd like to get a taste of how a 17x9 setup will look on the stock suspension.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 08-05-2013, 11:25 PM   #26
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Originally Posted by siXXtoes View Post
17x9 +35 with 225/45/17 MPSS on stock suspension
What wheels r those?
karma003 is offline   Reply With Quote
Old 08-06-2013, 12:05 AM   #27
garfull
garfull's Avatar
are you maxed out negative on the camber bolts?
The Following 2 Users Say Thank You to garfull For This Useful Post:
hmong337 (08-06-2013), raul (08-06-2013)
Old 08-06-2013, 02:08 AM   #28
siXXtoes
Ohh Snap
siXXtoes's Avatar
Drives: Argento FR-S
rays gram lights 57dr's in gun metal blue
P&L EL headers and over-pipe, ARK Grip front-pipe and cat-back exhaust, Delicious Tune, Rays Gram Lights 57DR 17x9 +35 wrapped in Bridgestone RE11a's
SoCal SD 86 Club Admin
https://www.facebook.com/groups/socalsd86/
siXXtoes is offline   Reply With Quote
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
Picture Request: Stock Turanzas on 8" wide wheels Robmilkshakes Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-17-2013 06:05 PM
WORK Emotion CR Ultimate (Kiwami) - 17x9 +38mm 5x100 IN STOCK NOW RavSpec Wheels and Tires 14 12-01-2012 12:26 AM
17x9 with stock tires? Lee358 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-09-2012 04:36 AM
Stock Rims Request Double4Free FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 03-03-2012 03:10 PM
