go_a_way1
Old 07-31-2013, 02:17 AM   #1639
mike the snake
I'm getting almost the same setup, so hopefully we'll know on Friday.
I'm going with gunmetal Raijins, 18x8.5 front, 18x9.5 rear, +45 offset front and rear, with Michelin PSS 245 35 18 front and 265 35 18 rear.
I've found a number of other forum members with the same exact sizes, lowered a bit so I'm confident this will all work.
The only issue I've read about is inside clearance when NOT running coilovers. The 45 offset sets the wheels inboard so no issues with fender rub (I gather, from researching for hours and hours on this forum.
The Following User Says Thank You to mike the snake For This Useful Post:
tinma (07-31-2013)
Old 07-31-2013, 03:53 PM   #1640
tinma
Drives: '13 BRZ
let me know how it works out! im really curious as to how the clearance will be with stock suspension with your setup
tinma is offline   Reply With Quote
Old 07-31-2013, 04:26 PM   #1641
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Yes, curious to hear about it as well. +45 is a high offset on our cars, especially for 9.5" wheel. If you say others are running that setup, then you should be fine unless they are all running coilovers.
If you can measure the inboard clearance, that would help this thread.
And of course we want to see photos of your new shoes!
Slick is offline   Reply With Quote
Old 07-31-2013, 07:11 PM   #1642
itdansharpe
itdansharpe's Avatar
Hehe..
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 07-31-2013, 08:35 PM   #1643
Slick
Slick's Avatar
Originally Posted by itdansharpe View Post
Hehe..
I take it from your sig that you're running that exact setup Dan?
Old 07-31-2013, 08:56 PM   #1644
mike the snake
I will be also installing ST coilovers. Coilovers are supposed to be in Friday, the rest is supposed to be in Thursday, so hopefully Friday I'll have it all installed.
I'm shooting for 1.5" to 2" lowered, with 1 to 1.5 degree camber (whatever I can get with the stock perches and eccentric bolts) with flush fit and no rub.
It's going to look awesome with meaty tires and lowered a bit.
Of course I'll post pics as soon as the parts are on!
Old 07-31-2013, 08:58 PM   #1645
itdansharpe
Yes I am. No issues whatsoever.
Old 08-01-2013, 11:10 AM   #1646
Karl07
Drives: 2012 86 GTS - Storm Black
Hi quick one for you.
I have a set of new wheels to go on:
Front 18x8.5 +40
Rear 18x9.5 +38
I will have adjustable coil overs installed before these go on.
My local tyre shop suggested the following sizes:
Front 245/35-18
Rear 285/30-18
I'm having massive issues finding decent rubber in the same brand let alone model that do both sizes. The only one I've found are federal 595rsr and I travel 1000km a week highway so they would wear out way too quickly.
I saw one thread the guy was running 245/35 all round. Is this less than ideal?
What size/s would be a better option? I don't really have much faith in the tyre places around here.
I plan on lowering the car enough to get rid of the wheel arch gap if that makes any difference.
Thanks, Karl.
Karl07 is offline   Reply With Quote
Old 08-01-2013, 11:11 AM   #1647
itdansharpe
Front 18x8.5 +40
Rear 18x9.5 +38
Front 245/35-18
Rear 285/30-18
Thanks, Karl.
Go wider in the front, you may find more options in 255.
Old 08-01-2013, 11:37 AM   #1648
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Front 18x8.5 +40
Rear 18x9.5 +38
Front 245/35-18
Rear 285/30-18
Thanks, Karl.
Spot on. I wouldn't change anything.
255/35 in the front is going to be a little taller. But as stated may provide more options but it is not ideal.
Edit, I thought you were FI with the tire size selection. If NA sizes are too large.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-01-2013, 07:22 PM   #1649
Karl07
Ok thanks.
Is it bad to have two different tyres front/back?
Old 08-01-2013, 08:08 PM   #1650
djdnz
1337
Drives: 2013 BRZ WRB S/C
Ok thanks.
You can't rotate them and they will tend to understeer more than if you had square, but with so much front grip you probably won't notice anyway lol.
285's though, are you turbo? Those are wide tires you're looking at.
djdnz is offline   Reply With Quote
Old 08-01-2013, 08:50 PM   #1651
Slick
Slick's Avatar
Ok thanks.
Different sizing or brands?
No issues with sizing as many run staggered, but always stick with the same make & model of tire.
The Following User Says Thank You to Slick For This Useful Post:
ill86 (08-01-2013)
Old 08-01-2013, 11:03 PM   #1652
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by djdnz View Post
You can't rotate them and they will tend to oversteer more than if you had square, but with so much front grip you probably won't notice anyway lol.
It will actually understeer (inherently) more. Not oversteer. A square setup will oversteer easier than a staggered. Same with increasing rear track width.
However, there are many other factors that can be adjusted.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
