Old 07-31-2013, 12:36 PM   #15
Boostedpro
I get the same thing. Spin on the 1-2, chirp 2-3 but is anyone else having their stability light flash on the 3-4 shift?
Boostedpro is offline   Reply With Quote
Old 07-31-2013, 12:59 PM   #16
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
It's likely due to the fact that when shifting hard, the ECU detects the motor for a brief moment is spinning higher than the speed of the wheels should be at that RPM+Gear. Not enough to overpower and cause wheel spin though. The TCS tries to be proactive and stop spin before it starts if you're in full-on mode.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-31-2013, 01:25 PM   #17
tennisfreak
Drives: 2018 BMW M240i
Originally Posted by CBR600RR View Post
I did a 0-60 in 5.8 with: stock tires, 16.4lb rims, e85 tune, 8000 redline... I can spin second and chirp third anytime I want, unless i have a heavy passenger...
Dang I was hoping for more with an e85 tune. Have you been dynoed?
Old 07-31-2013, 01:43 PM   #18
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by enwave View Post
I clocked a 0-58 of 5.7
I'm an automatic
Automatic can get to 62.8 mph in 2nd gear at 7400 rpm.
Manual can only get to 59.1 mph in 2nd gear at 7400 rpm.
This is why OP is asking about 0-58 mph for manual transmission.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
enwave (07-31-2013)
Old 07-31-2013, 03:46 PM   #19
CBR600RR
Drives: Raven Black
Nope, no Dyno.
1/4 mile of 14.37 @ 100mph though
Old 08-17-2013, 08:08 AM   #20
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
im trying to go with 17x8 +25 with 235/50/17 or 17x8.25 +30 235/50/17
does anyone know if this will fit?
this will make 0-60 one shift
NYCsubaruBRZ is offline   Reply With Quote
Old 08-17-2013, 08:09 AM   #21
NYCsubaruBRZ
manual trans is faster tho right?
Old 08-17-2013, 08:41 AM   #22
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
The 235/50-17 will make it to 60 mph in a 1-2 shift. But the weight of the tires (unless the wheels are significantly light...like 14 pounds) will make the car slower. There aren't many (any?) wheels that fit that criteria.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 08-17-2013, 08:49 AM   #23
NYCsubaruBRZ
i dont care a bout a tit bit of weight. i want a bigger profile tire
will that rim tire combo fit without rubbing?
Old 08-17-2013, 09:48 AM   #24
Kido1986
Dodging cones
Kido1986's Avatar
235/45/17 or 225/45/18 would be the tallest decent choices. Use a 17x8 or 17x8.5 or a 18x7.5 for best handling performance with these tire sizes
Old 08-17-2013, 10:06 AM   #25
regal
Drives: Scion FR-S/Toyota Yaris
Nope, no Dyno.
That's great performance, congrats. On par with an S2k also nearly as good as edmund did with the stock innovate.
Gives hope that one day the right header, tune, and lighter wheels on 93 should get a 100 mph et.
I think bone stock under 6" 0-59 mph is still pretty quick, its that torque dip/lag in third gear on the way past 70mph that gives these cars the bad rep for being slow. But even stock they are dam quick under 60 mph (in 2nd gear) which is really all you need off the track.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 08-17-2013, 10:27 AM   #26
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I would wonder what my car would do on my autoX set-up. It's 17x9 RPF1s (16lbs) and 255/40/17 sized ZIIs or RS-3. Driveline is stock.
The extra height in these tires over stock might get me 60 MPH in one shift. Additionally because of all the grip the tires have I can launch the car on top of the torque dip in first gear and unless the surface is very dirty I have enough grip to get all or most of that power to the ground with little wheelspin. SO my car should launch WAY WAY better than a stock car or even a car on better than stock, but still average summer tires.
Old 08-18-2013, 09:24 PM   #27
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
ahem... No fat chicks, no fat hicks or tires won't chirp
Old 08-18-2013, 09:26 PM   #28
FRSBRZGT86FAN
Smile
Yes quite faster, but with the longer gears in the auto I bet it if it had like 50 more hp from all the basic mods it would be quite sprightly.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
NYCsubaruBRZ (08-18-2013)
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
Shift knobs Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 8 03-01-2013 02:22 AM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
Shift light. Style Scion FR-S / Toyota 86 GT86 General Forum 24 07-19-2012 03:19 AM
Shift Apparel Lexicon101 Other Vehicles & General Automotive Discussions 2 05-02-2010 12:44 AM
