Old 07-31-2013, 10:10 AM   #1
brillo
Drives: 2013 Firestorm FR-S
0-60 time vs. 0-58 (one shift)
Just curious, the magazine's report the 0-60 for our cars around 6.4-6.5 sec but I know that requires three shifts (2nd tops out ~58mph). Has anyone seen a test that shows what the 0-58mph (one shift only) is?
Given the ECU tunes raise the rev limiter, I would think 60 is achievable in 2nd gear now.
I realize the car is not a drag racer but I'd be curious to see if the car is in the high 5s with only one shift to 58mph.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-31-2013, 10:23 AM   #2
MrSlay
Drives: Gx 460, FRS, Prius
Its also possible with a taller tire. Ill try it out once my wheels get in.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
Old 07-31-2013, 10:41 AM   #3
Drftfan
Drives: Argento FR-S
Hmmm. Very interesting proposal
This is your first performance car?
Drftfan is offline   Reply With Quote
Old 07-31-2013, 10:50 AM   #4
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Limit is at 59.2mph. You can use inertia to JUST hit 60 if you clutch at the right time. Doing so, I've had my data logger read 5.9 second 0-60 on a few occasions (this is with a drop in air filter, axleback delete, 14.5 lb wheels and very very sticky 215 tires). Though it's a purely academic exercise as you then have significantly slowed down all further acceleration
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-31-2013, 10:56 AM   #5
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
I clocked a 0-58 of 5.7 this morning (hand timed by a friend in my passenger seat. Only "performance" mods are K&N drop-in and Unichip EMS. ~70degf ambient air temperature.
Not half bad.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-31-2013, 11:12 AM   #6
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Yep, clutch in at 7300 and you'll hit 60 without engaging 3rd gear.
raul is offline   Reply With Quote
Old 07-31-2013, 11:13 AM   #7
brillo
what rpm are you launching at? Are you drop launching to achieve those numbers?
Old 07-31-2013, 11:17 AM   #8
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Do you guys chirp your tires on the 1-2 shift?
Old 07-31-2013, 11:18 AM   #9
enwave
enwave's Avatar
I'm an automatic (in manual mode) so I'm using that whole fake launch limited thing. Engage it by holding the brake for more than a second or so at >5mph, then once you stop, give it gas. Launches at about 4000rpm.
Old 07-31-2013, 11:20 AM   #10
enwave
enwave's Avatar
@jsimon7777 it depends on the road surface. I've had it a couple of times, but more often I don't.
Old 07-31-2013, 11:22 AM   #11
raul
Lap time enthusiast
raul's Avatar
Yes. Anyone who shifts aggressively will be able to do this on stock tires.
Old 07-31-2013, 11:24 AM   #12
thill
Easily... At least on the Primacy tires that break traction uber easy.
Old 07-31-2013, 11:45 AM   #13
husker741
I was able to chirp into 3rd the other day.
husker741 is offline   Reply With Quote
Old 07-31-2013, 11:52 AM   #14
CBR600RR
Drives: Raven Black
I did a 0-60 in 5.8 with: stock tires, 16.4lb rims, e85 tune, 8000 redline... I can spin second and chirp third anytime I want, unless i have a heavy passenger...
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
Shift knobs Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 8 03-01-2013 02:22 AM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
Shift light. Style Scion FR-S / Toyota 86 GT86 General Forum 24 07-19-2012 03:19 AM
Shift Apparel Lexicon101 Other Vehicles & General Automotive Discussions 2 05-02-2010 12:44 AM
