Old 07-29-2013, 11:00 PM   #323
Dezoris
Dezoris's Avatar
Originally Posted by BRZnut View Post
Yes but what is the difference between the ones that are 1, 2 and 3??
Going to continue this here:
http://www.ft86club.com/forums/showp...8&postcount=46
The Following User Says Thank You to Dezoris For This Useful Post:
Carwhisperer (07-30-2013)
Old 07-30-2013, 12:02 AM   #324
kodyo
Drives: Scion FR-S
After watching the video Dezoris posted, I can see why Toyota/Subaru wouldn't be hasty to a decision. Clearly a pain in the a$$ to get to them (should read "expensive"). Keep in mind, also, that there is an engineering process at these companies, so things have to be thoroughly checked and approved. If it is a proven issue, a fix will come out sooner or later.
kodyo is offline   Reply With Quote
Old 10-02-2014, 09:13 AM   #325
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by peachch View Post
Do you know what cylinder start leaking first? In my case, I got CEL P301 around 15000mi. I replaced all spark plugs.
Popping sound came up after I brought my car to a track. It had 17,000mi on it. Then, I found out that 1st cylinder injector O-ring was missing and 3rd cylinder injector O ring does not look good. I replaced all O-rings and Insulators.
Have you brought the car to track after 1st time fix?
http://www.ft86club.com/forums/showt...t=20930&page=2
I added oil cooler and run around 500mi. The issue has not reoccurred yet.
Weren't you running a visconti tune?
Astroboy is offline   Reply With Quote
Old 10-06-2014, 10:33 AM   #326
ISDriven
ISDriven's Avatar
Drives: chill
I have 2015 with only 1,200 miles, drivetrain is 100% stock and I already have this problem. I followed the brake-in procedure for the first 1000 miles and I still have been going easy with since then. (SIGH)
ISDriven is offline   Reply With Quote
The Following User Says Thank You to ISDriven For This Useful Post:
Astroboy (10-06-2014)
Old 10-06-2014, 09:14 PM   #327
Astroboy
Astroboy's Avatar
Drives: None
Sorry to hear. Take it in to the dealership, then write your experience here
Old 10-07-2014, 03:26 PM   #328
ISDriven
ISDriven's Avatar
Drives: chill
I dropped it off last night. They just called and said what I am hearing is normal. I know what I heard and I know that it was not "normal"
I already knew that they were not going to be able to reproduce the problem though. The service guy did sat that the 2015s have a different design for the collar/seal on the DI.
We will see what happens with time.
Old 10-07-2014, 03:37 PM   #329
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Very interesting there is a factory ECU correction for the direct injector leaking issue. I'm just wondering if tuners take this into account when they change ignition timings, AFR's etc.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
Astroboy (10-08-2014), ISDriven (10-07-2014)
Old 10-08-2014, 12:12 PM   #330
Astroboy
Astroboy's Avatar
Drives: None
Maybe it's that these vehicles are running to lean do to faulty ecu's that are causing these failures.
Old 10-08-2014, 12:32 PM   #331
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
What do you mean it's not reproducible? You should be able to make nice firecracker noises easily when free revving if it's actually DI seals.
Decay107 is offline   Reply With Quote
Old 10-08-2014, 01:12 PM   #332
ISDriven
ISDriven's Avatar
Drives: chill
I only heard it twice in a week. The service guy had never even heard of the DI issue before so the likelihood of them reproducing the situation was unlikely. Maybe what I heard was something else.
A loud as f#&$ pop from under the hood is never normal though.
Tech said, "Found cold start injectors heard through reverb pipe. No abnormalities at this time."
I'm going to remove the sound tube to eliminate that as a possibility.
Old 10-08-2014, 01:55 PM   #333
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You mean the stock ecu? Nope.. above 4000 RPMs it runs quite rich. Factory adds more fuel in high RPMs for protecting the motor generating high temperatures and dangerous knocking. Tuners always changing these AFM ratios and run leaner ..
The Following User Says Thank You to nikitopo For This Useful Post:
Astroboy (10-10-2014)
Old 10-08-2014, 02:30 PM   #334
s2d4
s2d4's Avatar
Not the same issue.
The popping on cold start can be normal if fuel has ethanol in it.
The Following User Says Thank You to s2d4 For This Useful Post:
Old 10-08-2014, 04:28 PM   #335
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by s2d4 View Post
Not the same issue.
I hate that 10% ethanol crap. One time, Since everybody on this forum was recommending shell gas station, I figured i'd give it a shot. I took my car ONE time to a shell gas station that apparently had 10% ethanol in it, and I soon started having many issues with my car. I go to my local gas station now because they have 93 octane gas with no ethanol content.
Fuck you shell and your 10% ethanol.
Old 10-08-2014, 11:32 PM   #336
peachch
Drives: White 86 Sport Plus
I am running Visconti tune. After got update, It seems like the problem is solved. I have 40k mi. Now.
peachch is offline   Reply With Quote
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
