Old 07-28-2013, 10:56 AM   #15
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by grostoine View Post
FA20CLUB and P&L are the ''same''. The main difference is where the coupler is...
Then they are not the same. Putting the vband that close to the collector squeezes the piping as the exhaust gas exits the collector.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 07-28-2013, 11:31 AM   #16
grostoine
Drives: Subaru BRZ
That's why I put some '' '' over same. I meant the way it looks, is the same. I know the collector is not located the same way but if you put them both in one piece, they are the same...
grostoine is offline   Reply With Quote
Old 07-28-2013, 02:14 PM   #17
slava
slava's Avatar
Drives: brZed
Thanks for feedback guys. Looks like I need to be a little more patient and wait for Nameless or fa20club. Also sounds like I might as well save up and do a full exhaust with tune at the same time.
slava is offline   Reply With Quote
Old 07-28-2013, 02:29 PM   #18
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
The wait is worth it
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-28-2013, 03:11 PM   #19
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
The HKS with a tune looks pretty good to me. It still has a dip relative its peak torque, but is less than 5ftlb lower than the Borla UEL (also with a tune) for ~400 rpm. Everywhere else it's higher, and up top it's much higher.
uspspro is offline   Reply With Quote
Old 07-28-2013, 03:32 PM   #20
FRSGeek
Drives: UltraMarine 6 Spd MT
I am waiting (already ordered) the FA20Club w/CAT version. *fingers crossed*
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
FRSGeek is offline   Reply With Quote
Old 07-28-2013, 08:36 PM   #21
Hawaiian
That guy
Hawaiian's Avatar
If you wait a few weeks till 86 nationals in ky several cars will be dynoed on the same day, same dyno. A lot of information should come out then.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 07-28-2013, 09:56 PM   #22
Ingen
Drives: Ultramarine FR-S 6MT
Originally Posted by Aaron_blatherwick View Post
Is there a reason for only wanting an el header? I my self was tore apart in deciding on which to buy, have you seen the comparison of the borla el to the uel?
I haven't seen a comparison of power but the fabrication quality I have seen in pics of the borla unit has erased the good feelings I had from the sound.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
The Following User Says Thank You to Ingen For This Useful Post:
TylerLieberman (07-29-2013)
Old 07-28-2013, 10:08 PM   #23
FR-S Matt
With all the issues I've seen, warranty or not, I don't trust it. No one should have to replace a header multiple times. If I had to replace my header from cracking after every year, I wouldn't be too happy. Granted a header install on this car is 10 times easier than most cars, I still think a quality product goes a long way.
Old 07-28-2013, 10:21 PM   #24
Ingen
Agreed. If I pay several hundred bucks for a part, and install it, you can bet I will be pretty grumpy if I have to set aside more time putting the car on jack stands for the same problem again.
Even if it is free to replace the part, I have better things to do than redo things I already did!
Old 07-28-2013, 10:34 PM   #25
utekineir
blowhard
Drives: frs, project forester
on turbo subarus its been long established that el is better power, uel is the burble.
utekineir is offline   Reply With Quote
Old 07-28-2013, 10:43 PM   #26
FR-S Matt
I think you'll only really see the difference on very high horsepower amounts. Yes, there is a slight difference, but realistically on the road, you will not feel it below 350 whp imo. Most people would prefer the sound and sacrifice the small hp loss without looking back. Your true enthusiast though that wants every ounce of horsepower will go EL though. You'll see bigger gaps with the stage 2 turbo kits between UEL and EL.
Old 07-28-2013, 11:00 PM   #27
slava
slava's Avatar
Drives: brZed
EL sound is way better, main reason why. Don't want the rumble, prefer smooth sound instead.
The Following User Says Thank You to slava For This Useful Post:
Hawaiian (07-30-2013)
Old 07-28-2013, 11:01 PM   #28
FR-S Matt
This is how a lot of people make their decision which is why it is awesome we have both options.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Brzzee (07-30-2013)
DIY: ReWire AT Shifter to Reverse & Correct the +/- pattern (on selector stick) ymboc DIY (Do-It-Yourself) Guides 11 04-02-2022 05:07 PM
Correct barb size for catch can? Hanakuso Engine, Exhaust, Transmission 15 01-23-2014 06:32 PM
Do these look correct for our car? 9005 Replacement BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 1 06-24-2013 11:15 AM
correct idle rpm after warmup StormTrooper Issues | Warranty | Recalls / TSB 11 04-27-2013 07:00 PM
Fitting 9.5" wheels in back.. is my math correct? eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-23-2012 02:19 PM
