Old 07-27-2013, 09:12 AM   #1
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Pic Request: 17x9 on stock suspension
I don't plan on doing suspension mods anytime soon but i'm definitely looking for a 17x9 245/40/17 wheel/tire setup.
i'd like to get a taste of how a 17x9 setup will look on the stock suspension.
...an aside: reason for the stock suspension is because it is very good. i would like to test the factory suspension through some circuit racing before making my decision to go for an upgraded suspension.
hmong337 is offline   Reply With Quote
Old 07-27-2013, 10:58 AM   #2
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
http://www.ft86club.com/forums/showthread.php?t=7533
Here's a link to a 17x9 setup... with a stretch the tire will sit flush with fender, according to the OP. I am thinking of going the same route...
gatorbushmen is offline   Reply With Quote
Old 07-27-2013, 11:16 AM   #3
whataboutbob
AutoX-10/10ths every run
Here's mine. 17x9et35.
http://www.ft86club.com/forums/showp...5&postcount=53
http://www.ft86club.com/forums/showp...2&postcount=54
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
Bimble Bamble (07-05-2015), cevin45x (08-08-2013), hmong337 (08-03-2013)
Old 07-27-2013, 12:21 PM   #4
JerryMichaels7
Drives: Whiteout FRS
does the front rub on the stock suspension with your setup at all bob???
JerryMichaels7 is offline   Reply With Quote
Old 07-27-2013, 01:02 PM   #5
whataboutbob
I should point out that I am on RCE yellows with Whiteline camber bolts. The 35 offset is a must if you want to run 245/40R17s. I have about a pinky finger of clearance between the rim/tire on the inside and the spring perch on the factory struts. No rubbing on fenderwell or fender with my setup.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
Bimble Bamble (07-05-2015), hmong337 (08-03-2013)
Old 07-27-2013, 01:27 PM   #6
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
You should be able to find links to 17x9 setups all over the sticked wheel thread.
Old 07-27-2013, 07:28 PM   #7
knipple
Drives: 2013 Ultramarine Scion FR-S
OEM suspension. I have not detected any rubbing. These are 17X9 et +35. Tires are BFGoodrich G-Force Rival 255/40/17.
I have camber bolts in the front and have had as much negative camber dialed in as possible.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
knipple is offline   Reply With Quote
The Following 2 Users Say Thank You to knipple For This Useful Post:
Old 08-03-2013, 02:00 AM   #8
hmong337
Emperor JDM
hmong337's Avatar
Thanks guys! I'm definitely looking at wheels with offsets between 35 to 40.
Old 08-03-2013, 12:45 PM   #9
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
That's not the case.
255/40R17 on Mach V Awesome 17x9 +42.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following 2 Users Say Thank You to Mach V Dan For This Useful Post:
cevin45x (08-08-2013), Jaylyons1 (03-28-2014)
Old 08-03-2013, 03:44 PM   #10
siXXtoes
Ohh Snap
siXXtoes's Avatar
Drives: Argento FR-S
17x9 +35 with 225/45/17 MPSS on stock suspension
P&L EL headers and over-pipe, ARK Grip front-pipe and cat-back exhaust, Delicious Tune, Rays Gram Lights 57DR 17x9 +35 wrapped in Bridgestone RE11a's
SoCal SD 86 Club Admin
https://www.facebook.com/groups/socalsd86/
siXXtoes is offline   Reply With Quote
The Following 3 Users Say Thank You to siXXtoes For This Useful Post:
cevin45x (08-08-2013), hmong337 (08-04-2013), whataboutbob (08-04-2013)
Old 08-04-2013, 03:41 AM   #11
Kai Uhl
Kai Uhl's Avatar
how would one get those whiteline decals?
Kai Uhl is offline   Reply With Quote
Old 08-04-2013, 08:52 AM   #12
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
The old 4x4 look--yikes... lol
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
Old 08-04-2013, 10:32 AM   #13
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
17x9 +45 rpf1 with 245/40/17
Size:  371.8 KBName:  ImageUploadedByTapatalk1375626591.743858.jpg
Size:  274.1 KBName:  ImageUploadedByTapatalk1375626620.975748.jpg
Size:  271.2 KBName:  ImageUploadedByTapatalk1375626668.478476.jpg
The last picture is the distance between the tire and the coil i have had no rubbing in the last month since install. Wait thats a lie i rubbed once pulling into my very steep driveway thats about it.
Lee358 is offline   Reply With Quote
The Following User Says Thank You to Lee358 For This Useful Post:
Old 08-04-2013, 12:31 PM   #14
hmong337
Emperor JDM
hmong337's Avatar
@Lee358
Wow! That's cutting it close. Is there any rub on full lock?
Thanks for posting.
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
Picture Request: Stock Turanzas on 8" wide wheels Robmilkshakes Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-17-2013 06:05 PM
WORK Emotion CR Ultimate (Kiwami) - 17x9 +38mm 5x100 IN STOCK NOW RavSpec Wheels and Tires 14 12-01-2012 12:26 AM
17x9 with stock tires? Lee358 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-09-2012 04:36 AM
Stock Rims Request Double4Free FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 03-03-2012 03:10 PM
