Old 07-25-2013, 12:57 AM   #183
EL7
EL7's Avatar
Drives: 13 BRZ Limited 6MT SWP
I'm going to have update ready to ship out to everyone in a few days
I'm glad I wasn't able to put this in right away. Good to see John has recognized the issue and is sending out the revised part to everyone.
EL7 is offline   Reply With Quote
Old 07-25-2013, 09:10 AM   #184
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by Sensisnow View Post
I know that there's been plenty of posts about people having fuel leaks and there aren't many people running this kit right now, so I'd like to hear from anyone who hasn't had any issues with a fuel leak and/or sensor adhesive failure.
So far no leaks and the sticker has held on. I kept thinking I had a leak but I've contributed that to having no cat in the header. I checked dozens of times with no visible signs of fuel.
post_break is offline   Reply With Quote
Old 07-25-2013, 03:16 PM   #185
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Getting the car back from the dealer - haven't seen it yet but it looks like they were able to switch out the hose with one of the correct ID - will take pictures and post a little later tonight on what the change was - hopefully this takes.
mikalem is offline   Reply With Quote
Old 07-25-2013, 05:33 PM   #186
mikalem
mikalem's Avatar
Back from the dealership - what ended up being replaced was the entire hose from the metal fitting to the side of the sensor coupling. Pictures are attached - they reused the clamp, but it's not tightened on very tight and I can physically see the bulge in the rubber hose - gives me a feel good on the seal being created. See pictures for the changes, sorry I don't have any before but it used to look very close to the DIY pics, as that was what I was working from in the beginning.
Old 07-25-2013, 10:32 PM   #187
Foobar
SLO NO MO
Foobar's Avatar
That's a great dealer you got. I can see some others telling you they won't touch that flex fuel kit with a ten foot pole.
Sent from my Nexus 4 using Tapatalk 2
Old 07-25-2013, 11:18 PM   #188
Sensisnow
Drives: 05 TSX & 13 BRZ
Agreed, what dealership is that? I had to take my WRX to one of the Columbus dealerships back in the day when I broke down in the area and they were terrible. It sounds like your dealership really stepped up though!
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 07-26-2013, 06:50 AM   #189
mikalem
mikalem's Avatar
Byers Dublin Subaru, on the North side. Hetfield is the only other Subaru dealer I know of in town, haven't ever had to deal with them. Ordered the car through them and waited 6 months, they have been a great dealership to go to, but I'd like to think I'm a pretty reasonable customer as well - they treat me decent and I tell others about the experience, win win like it should be
Old 07-26-2013, 10:04 AM   #190
DriftEm
DriftEm's Avatar
did any of you with after market high flow fuel pump had fuel leak issue with this kit?
DriftEm is offline   Reply With Quote
Old 07-26-2013, 12:39 PM   #191
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I have @Visconti's 290LPH fuel pump installed and I'm not experiencing any leaks. Hope he'll chime in on the hose issue. I did notice that the provided hose did go on quite easily when installing, which usually isn't the case when working with fuel lines. Typically gotta wrangle those suckers into place.
I'm sure John will make it right.
cobrabyte is offline   Reply With Quote
Old 07-26-2013, 01:47 PM   #192
mikalem
mikalem's Avatar
Yeah, I know John was planning on sending out a connector update to the first rounders of the group buy - the picture he had looks complex. I kinda like what the dealership was able to do for me - just their stock fuelline hose run into the fitting provided in the kit, and it looks like they used some type of compound to help slide the hose down onto the metal fuel tube - all in all matching the stock fitting much better.
If you haven't installed it yet, I'd consider not using the hose John provided from the metal fitting to the sensor and source your own with a thicker wall and smaller inner diameter, or wait for the new connector John cooked up.
Old 07-26-2013, 08:46 PM   #193
Yruyur
Yruyur's Avatar
Picked up another e85 upgrade for the kit....
Better safe than sorry.
Sent from a Motorola DynaTAC 8000X
Old 07-28-2013, 12:06 AM   #194
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Thanks to @JiB's awesome mounting idea, I also relocated my gauge to a more subtle place.
enouf is offline   Reply With Quote
Old 07-28-2013, 04:29 AM   #195
JiB
JiB's Avatar
Drives: GT86
hahahah so good!
JiB is offline   Reply With Quote
Old 07-28-2013, 09:21 PM   #196
DriftEm
DriftEm's Avatar
Well, my setup is also leaking, from the same place as others. I did the double clamp setup like some one did here and for now no leak.
I'm very uncomfortable with this issue. I don't understand why John didn't use the same kind of fittings like the other connections. This needs to be resolved before a car catches on fire.
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
