#169 |
Drives: GT86
looks secure
#170 |
Drives: 2020 DGM BRZ Limited
No luck, the line is now just leaking - having it towed to the dealership so they can try and resolve
Sent from my SGH-M919 using Tapatalk 4 Beta |
#171 | |
#172 |
To me it looks like there is an additional AN fitting on the end of the line we are clamping. Meaning there may be an adapter (compression fitting) on the hardline as well. Nice.
Sent from a Motorola DynaTAC 8000X Last edited by Yruyur; 07-24-2013 at 03:41 PM. |
#173 |
Drives: 2013 BRZ, 2002 WRX
Ugh. Really? Where is it leaking? I'm guessing the hard line connection. Def gonna have to double-check that hose.
#174 | |
At this point, I'm on the fence - I believe the dealer is going to want to revert the line in the engine bay, and bypass the sensor. If they do that, I'm probably gonna need John to get me a e85 only tune for me to runout the 3/4 tank of e85 that's in it currently..... either that or when they drain the line, drain the tank, then pull the harness and re-flash with 1.14 pumpgas. Either way, not a good situation and my car is DOA at the moment. |
#175 |
Just got back from talking to the tech, they seemed confident it could be resolved, so far I think plan of action is to replace the line from the metal hardline to the sensor, if they can't find a clamp that will properly seal it up. It looks like using that ID for the hose was a little too large/skinny - after reading up a bit 8t seems that the combination of rubber line and metal lip should form the seal, the clamp is there to simply reinforce the hose. Fix seems to be either a different ID hose, or the change over to a hardened connection it looks like John is going after. Either way, if you have it installed be careful! I don't want to hear about cars going boom....
![]() Sent from my SGH-M919 using Tapatalk 4 Beta |
#176 |
Just about to log anyone remember the ethanol value in ecutek to add to the logs?
Sent from a Motorola DynaTAC 8000X |
#177 |
#178 | |
Drives: 05 TSX & 13 BRZ
Sent from my Galaxy Nexus using Tapatalk 4 Beta
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1 |
#179 |
Drives: GT86
Map F under "all parameters" by memory
#180 |
Mr. Grumpy
Drives: 86 GT, Fuji Red, MT
The new fitting looks good, much more secure and the thin wall of the hose won't be a problem with that set up. @Visconti, will us Aussies be able to get that fitting for the engine side connection as well?
I was playing around with a section of the hose last night with new clamps and the hose really wrinkles up when pressure is applied to it, hence the leaks when you tighten it further. Double clamping seems to fix that. I'll be driving around gingerly until the new fitting gets sent out....... |
#181 |
I know that there's been plenty of posts about people having fuel leaks and there aren't many people running this kit right now, so I'd like to hear from anyone who hasn't had any issues with a fuel leak and/or sensor adhesive failure.
2013 DGM BRZ
#182 | |
Haven't had any issues with the adhesive tape, but what I did before installing it, I warmed it up with my heat gun, heat and pressing it down for about a minute did the trick.
| Tags |
| campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued |
| Flex fuel testing | Dynotronics1 | Southwest | 5 | 06-22-2013 03:27 PM |
| FA20CLUB Flex Fuel Kit Ready | FA20Club.com | Engine, Exhaust, Transmission | 16 | 05-22-2013 11:04 AM |
| ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 09:36 AM |
| Cheap flex fuel? | nix | Engine, Exhaust, Transmission | 1 | 05-11-2013 04:05 AM |
| Flex Fuel? | VenomRush | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 01-15-2010 02:55 AM |
