Old 05-01-2013, 06:15 PM   #183
zoomzoomers
zoomzoomers's Avatar
Most guys recommend using the factory filter, but with regards to oils you'll get all sorts of differing answers. Just use a reputable oil brand and change frequently. You should be fine.
Originally Posted by CheesusCrust View Post
Guys, I've never changed my oil before, and my car just hit 7500. Changing it will be easy enough, but what oil/filter do I buy? I live in VA
Old 05-01-2013, 10:08 PM   #184
R L Newb
Drives: LR BRZ Ltd, 06 STi
subie oil/ subie filter. works great for typical use.
I think I pay something like $36 if I buy a filter,crush ring and 4 quart and around $50 when it's 6qts. that's based on fuzzy memory and conjecture, plus we get discounted parts at the local subie dealer for being part of the impreza club.
R L Newb is offline   Reply With Quote
The Following User Says Thank You to R L Newb For This Useful Post:
zoomzoomers (05-01-2013)
Old 07-20-2013, 11:22 AM   #185
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Second oil change analysis from Blackstone. This is with using Motul 300V for 6K miles:
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
The Following 2 Users Say Thank You to lordtakuban For This Useful Post:
bluesubie (07-22-2013), R L Newb (07-24-2013)
Old 07-22-2013, 10:52 AM   #186
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Thanks for posting this! 300V is definitely a race oil that you can easily run to 7,500 miles on an oil change interval with plenty of calcium (and a bit of magnesium) for detergency/dispersancy (are those words?) and you still have a good TBN (it starts at around 7.97).
Viscosity took very little hit as it starts around 8.0. And since you're not really burning any oil, your cats are probably fine with the slightly elevated phosphorus vs. the 800 ppm's in GF5 oils (if you have cats).
Any engine mods and what are the driving conditions? Is this the newest Ester Core 300V?
-Dennis
bluesubie is offline   Reply With Quote
Old 07-22-2013, 11:12 AM   #187
sato
sato's Avatar
Drives: Dodge Patitas
Thank you for posting your results and history. Furthermore, I also appreciate having linked the other results posted by other members
sato is offline   Reply With Quote
The Following User Says Thank You to sato For This Useful Post:
Old 07-24-2013, 11:07 AM   #188
R L Newb
Glad you like it, I figured it would provide a more useful thread then fishing through a bunch of pages.
I updated the first post with my latest oil change and link to lordtakuban's 2nd. I ended up running my oil until 9600 miles because of a general lack of time to do an oil change. So 1 year, 5 oil changes, 36k miles and the stock stuff still works.
Old 07-24-2013, 04:50 PM   #189
bluesubie
Wow, nice uoa! The Flashpoint probably took a little hit from fuel dilution, but uoa wear metals look good!
-Dennis
Old 07-25-2013, 05:24 PM   #190
R L Newb
I was surprised it held up so well. Seems like for normal use with the occasional asshattery you can push the limit on the changes without issue. I haven't been paying close attention but is anyone autox'ing theirs and posting UOA? I'd like to see the difference.
Old 07-26-2013, 04:00 PM   #191
bluesubie
Your silicon still seems high for the number of miles. Do you have an aftermarket intake?
Here's a Blackstone virgin oil analysis from last December, so I don't think it's an oil additive (unless the oil was reformulated):
http://www.bobistheoilguy.com/forums...Number=2843880
-Dennis
Old 07-26-2013, 04:50 PM   #192
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I have about 3000 miles before I hit 7500 again, and I will send a sample to blackstone and the other company that does the UOA's.
I autox probably at least once a month and I run on E85 occasionally so it should be interesting to see what kind of results it shows.
Ranatsu is offline   Reply With Quote
Old 07-29-2013, 09:38 AM   #193
bluesubie
Are you tuned for E85? I see varying results in UOA's in WRX's/STI's that run E85 and are tuned for it. I've seen a couple of good uoa's, but have probably seen more uoa's where the oil took a beating. Even with 3,000 mile intervals on Rotella T6 5W-40.
-Dennis
Old 07-29-2013, 10:05 AM   #194
Jeffsu350
Drives: Frs
I autox my car, after the first 1k miles.
You can see my uoa in this thread
Jeffsu350 is offline   Reply With Quote
Old 07-29-2013, 01:24 PM   #195
Ranatsu
Cone basher
-Dennis
Yea, I have a map for e85. So far i've only run it for about 1.25 tanks.
Old 07-30-2013, 07:59 AM   #196
lordtakuban
-Dennis
The only engine mods that were in effect during the oil use was an AFE drop-in dryflow filter. This is my daily driver. I accelerate quickly ... a lot. Well, as quickly as this car can go anyway. I have not yet autocrossed it. But that's mainly due to lack of time.
I installed the TRD Intake a couple weeks after doing this recent oil change. All cats are still present. I meant to change the oil at 5K, but lost track of time and mileage and it slipped to 6K. But, based on the numbers, I could likely go longer.
I got the 300V a few months back from my distributor. And the price leads me to believe it's the newer formula. The cans look about the same though and I don't think I have any old cans from the previous oil to compare details.
Since I put about 8K miles/year on the car, it will be a while before I do another change. I'll be sure to post the results on this thread to keep a good running history.
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
