Old 07-24-2013, 03:35 PM   #323
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by swift996 View Post
Oh for sure! I wanted to go the turbo route but this is my daily driver and I thought a supercharger would be a better idea for less hassle (beginning a MBA program this fall and need to focus on that). I'm coming from a M3 and 911 so I'm not blown away, just happy with the set-up.
I hear that, I have had an E46 M3, E92 M3, C6 Z06, and Cayman R. I look forward to the future Innovate intercooled developments, but I am definitely glad I am not still waiting for it to be released. Will you be upgrading as soon as the intercooler is released?
Old 07-24-2013, 03:42 PM   #324
swift996
swift996's Avatar
Yeah, I'm waiting for more details essentially. I'd like to explore a 70mm pulley which will add about 20whp according to Robi's dyno plots. However I want to make sure it's safe on 93 alone. For the track I'm exploring the intercooler + e85 or an Aquamist WMI kit (with 93). Either way I plan to run one of the two for heat management. My goal was 275-300 whp with this car. With this kit, I'm just hoping for a reliable 260-270whp. I think that will max it out for the most part. I love it now but it's still a tad bit short on power.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-25-2013, 10:02 PM   #325
crank
crank's Avatar
Drives: WRB 2013 Subaru BRZ Limited
Hey man love the set up looks clean, have you thought about a Perrin CAI with this kit? It replaces the stock airbox, but also makes the airflow less restrictive. Just my 2 cents I guess.
Full Perrin Intake/ Perrin Cat-Back /PST Carbon Fiber Drive Shaft/ 5% Tint All around
Build Link:http://www.ft86club.com/forums/showthread.php?t=44038
crank is offline   Reply With Quote
Old 07-25-2013, 10:24 PM   #326
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We should have that pulley done by the end of august if all goes well. I think with a good header, 2.5" exhaust, and e85 or meth injection; this setup should hit 300whp on a cool day. These twin screws from Sprintex in the jeep/mini side have done quite well, so with the 70mm pulley and good cooling it should be solid.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
xxscaxx (07-25-2013)
Old 07-25-2013, 10:44 PM   #327
nix
nix's Avatar
Drives: AVO BRZ
I don't know what Innovate's plans are but i'm sure you could buy the intercooler core & heat exchanger direct from bullet in queensland. Kind of surprised no one did that yet it's been out for a while.
nix is offline   Reply With Quote
Old 07-26-2013, 10:49 AM   #328
swift996
swift996's Avatar
Yeah, I've thought of it, I plan to just wait until someone fabricates an innovate-specific option (lower cost too). A cone filter is going to flow 2x the air compared to a drop in.
Yeah, I'm hopping so. I need to figure out a WMI plan. I'm concerned about the AEM kit because the nozzles have those water dribbles/droplets at lift off. I've confirmed that AquaMist is developing a kit for the BRZ to work with modulation from both the DI and PI. I'm not sure if AEM's new check valves alleviate the droplet issue. Anxious to see the results you get from the pulley. I won't be far behind! The 93 tune is a little underwhelming after running around on E85 for a week I'm still on the factory over-pipe, I'm wondering if that could be choaking off some of the flow. I need to find one that clears my 25.4mm sway bar though.
Yeah, I thought about that but not sure if I'd rather just run water/meth. I guess I want to see more results to see it's effectiveness. It's obviously a simpler solution but I need more data.
Old 07-26-2013, 09:29 PM   #329
Xero-Limit
Xero-Limit's Avatar
AEM sent us a new nozzle a year or two back that I've been using for the MX5--0 issues. Had the intake off and the whole thing was so clean you could eat off of it.
Old 07-29-2013, 05:36 PM   #330
swift996
swift996's Avatar
Small Update:
I went by Sears today and picked up a cordless impact gun. I went with the 3/8" one because most of my sockets are that size and it's also quite lighter than the 1/2". It still has 130 ft-lb of torque power.
Also, I received a replacement donut gasket, I plan to install this evening. I'm not sure but there might have been a slight exhaust leak from the OEM one due to the modification I had to make to it to fit the front-pipe.
I'm waiting to receive:
Lightweight Hitch Receiver
Perrin Oil Cooler (in black)
I also might chance it with a Perrin over-pipe, just not 100% sure if it will play nice with my sway bar. I plan to grab some data logs tonight or tomorrow. On the 93 tune it seems to be a little choppy/rough at low RPMs under very light throttle.
Old 07-31-2013, 09:31 AM   #331
endrswrd
Drives: 2013 LTD BRZ
Just a quick question on your setup, has your tune been done yet for all your mods, or are you just running a slightly tweaked innovate tune?
I was hoping for more out of this kit on 93, but if you truly are only getting 5 psi that may be part of the issue.... Either way, car looks great! Probably handles like a go cart as well!
endrswrd is offline   Reply With Quote
Old 07-31-2013, 10:06 AM   #332
swift996
swift996's Avatar
It's a slightly tweaked tune but I've sent data-logs to Moto-East so it's been optimized. I still plan to get it dyno tuned soon though. I think it's just the stock MAP sensor can only read to 5.3psi. I might be adding water/meth injection soon and will be having that tuned.
My idea is:
Map 1 - 93 w/ Water-Meth
Map 2 - 93 Base/Safe Tune (No Water-Meth)
Map 3 - E50
Map 4 - E85
That way whether I'm running E85 or 93 w/ WMI, I should have about the same power output. I'm also waiting to see developments on the 70mm pulley and if it's safe to run on just 93 conservatively. I might do the 70mm pulley, cold-air intake, and WMI at the same time. This car although like a race car now, is still my daily driver and reliability is paramount but I'd like another 30-40whp.
Old 07-31-2013, 07:35 PM   #333
antlers
White Guy
antlers's Avatar
Drives: 2005 Subaru WRX STI
Delete some junk from your photobucket please!
antlers is offline   Reply With Quote
Old 07-31-2013, 09:28 PM   #334
swift996
swift996's Avatar
Update
I've ordered and awaiting:
- Perrin Oil Cooler in black
- Poorboys Wheel Sealer - try to keep some of this dust off my wheels...I also acquired about $15 in brushes to get all the crud from my race pads off.
I'm close to ordering the AEM water/meth kit. I need to coordinate some time with Moto East to install and tune it.
I received my Perrin OverPipe:
All hardware included:
I thought this was pretty poor for the price point, you can see the piping isn't flush with the flange cc: @PERRIN_Chris
Compared to OEM pipe:
It clears my Hotchkis sway bar (25.4mm) but just barely:
Install notes:
Pain in the rear
I'd recommend removing the motor mount bolt and jacking the engine, it's super easy and will save you time. I did after 30 minutes of trying to snake the OEM pipe through. It just doesn't want to come out.
It started poring rain so I got soaked and dirty as heck. I at first had a small leak from the header end on the top side of the flange. I loosened the header bolts and got them tight first and then did the rear. It's a little better but still I have a slight leak. I might try to run it by @ptuning if they can squeeze me in. I'm not sure if one of the flanges are not up to par. I also burned the hell out of my shoulder on the header. There is a slight grade on my driveway so I was soaked and it was hard to move/dark as heck. The install took me about 2hrs which was much more than I was expecting. If I was lucky with no leak and did the motor mount procedure, I would have got it done in 45 mins.
Driving impressions, well there's a leak but it does feel a little smoother just from running it around the block. I need to get the leak addressed. I might try again tomorrow evening but have to pick someone up from the airport.
Old 08-01-2013, 12:20 PM   #335
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
The gap on the overpipe actually looks pretty good. Our exhaust parts are all hand cut, mandrel bent pipes, so there always will be a small gap, but it won't hurt performance.
Sorry to hear about the leak, if you need any more gaskets, let me know!
PERRIN_Chris is offline   Reply With Quote
Old 08-01-2013, 12:35 PM   #336
swift996
swift996's Avatar
Turns out I mashed the gasket on install because the two pipes wouldn't line up perfectly at first. I'm up and running now with no leaks. I probably just lost my patience last night in the rain. I used a ptuning gasket which was thicker to be safe.
2013 BRZ Limited (black) Epictetus Cars for Sale/Trade 2 11-14-2012 11:38 AM
My crystal black brz limited chadz Member's Car Journals 37 09-12-2012 06:26 PM
BRZ, Black, 6MT, Limited...DELIVERED! boarder1995 BRZ First-Gen (2012+) — General Topics 3 06-14-2012 04:03 PM
Need a black AT Limited trim BRZ! jaytaurus Northwest 4 05-18-2012 05:29 PM
