Old 07-23-2013, 02:22 PM   #43
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by ultra View Post
In response to the OP - if you're interested in 'safe and reliable' horsepower then the best bet is to sit back and wait a year or two while the early adopters do all the real world R&D work for you.
There's plenty of variety in terms of forced induction options on the market but based on the threads on this board peoples' real world experiences seem to vary quite a bit. For every 'w00t big whp' thread on these boards it seems that there's a nightmare thread where somebody had installation issues, tuning issues or low whp results with the same kits. No exceptions for any particular vendor's kit it seems.
The key to the successful builds seems to be a matter of carefully chosen supoorting mods and having a very skilled installer *and* tuner on hand locally.
Even then my perspective is that most people are in 'fingers crossed' mode since the installs are all so newly done.
We're far from having a huge wealth of reliability data to look at so IMO, even fiveen the high quality of most of the kits on the market already, the 'install and forget it' type of 'safe and reliable' kit doesn't exist yet.
You need a tuner's mindset, local support and a willingness to accept the possibility of a failure when going FI at this stage.
SPOT ON ! and very sage advice.
cf6mech is offline   Reply With Quote
Old 07-23-2013, 02:36 PM   #44
lexusb3
Drives: FRS
but i still believe more failure on the tuning part because im at 400+ and beat the hell out of it with a few thousand miles ! compared to Crawford a few hundred miles and BOOM
lexusb3 is offline   Reply With Quote
Old 07-23-2013, 02:51 PM   #45
Gen
Drives: Scion FR-S
More than one from what I hear. I've also heard that their situation probably isn't a result of a specific deficiency with the OEM engine. Granted, I'm surprised I can manage to find the gas pedal most days, so I know very little about this first hand.
Gen is offline   Reply With Quote
Old 07-23-2013, 02:53 PM   #46
lexusb3
Drives: FRS
so its has to be the tune lol then again i dont know im just assuming. Ill go read their build now
Old 07-23-2013, 02:59 PM   #47
Gen
Drives: Scion FR-S
That is consistent with what I have heard and something about rod angles on their built engine or something of the sort I do not understand. Really, I have no specialized knowledge in this arena, so it's all hearsay.
The Following User Says Thank You to Gen For This Useful Post:
lexusb3 (07-23-2013)
Old 07-23-2013, 06:00 PM   #48
EL7
EL7's Avatar
Drives: 13 BRZ Limited 6MT SWP
Originally Posted by BRZPDX View Post
If this is your DD, I wouldn't recommend going FI for another year and see how people are holding up around the 30k mile mark after FI. It is too early to tell.
^This.
Exactly what I'm doing before I make the leap next year. Seen good reports from one member floggin his Raven on the FA20Club kit so far. 9K miles and counting.
EL7 is offline   Reply With Quote
Old 07-23-2013, 07:04 PM   #49
lexusb3
Drives: FRS
Originally Posted by EL7 View Post
^This.
13.5k miles now lol
The Following User Says Thank You to lexusb3 For This Useful Post:
EL7 (07-24-2013)
Old 07-24-2013, 05:45 AM   #50
cf6mech
I do believe Crawford, Accelerated, I , and a few others have taken this engine past your horsepower level and found a weakness. Dynos all don't read the same and measure differently, to me there sole purpose is to see a gain from a baseline, my engine could very possible read 500 on your dyno,...don't know. If you haven't reached the limits on the stock fuel system above and beyond a change to the stock fuel pump in the tank, meaning,... having to go to a surge tank or a rising rate return system to make things safe, like I have,.. I know comparatively I'm making a lot more power than you regardless of horsepower claims, not because of the use of it, but because of the necessity of it.... I don't think this confusion over why some engines go boom and others don't is because of tuner issues,...I think its more of an issue of what guys are claiming for horsepower and the variances from one dyno to another and BHP versus WHP. Yes there are going to be a few bad tunes with resulting damage, but guys like Quirt Crawford, Visconti and Don at AP making rookie tuning mistakes?.....I just don't believe that. I'm believing once you reach 20psi boost,... stronger head studs,...which aren't available, and stronger more compliant aftermarket crank bearings,... which also aren't available, and a very serious look at forged rods and pistons is a must for the FA20...
The Following User Says Thank You to cf6mech For This Useful Post:
ultra (07-24-2013)
Old 07-24-2013, 09:47 AM   #51
Frs300
Frs300's Avatar
Drives: Pile of junk
you can get head studs
Frs300 is offline   Reply With Quote
Old 07-24-2013, 11:07 AM   #52
jamesm
you've seen the logs people have posted from visconti's e-tunes, right? i wouldn't just have blind faith that because someone is well known they can do no wrong. and whether you need fuel upgrades has to do with a lot more than just power level, especially with this hybrid DI-port system.
for example some tuners utilize the DI heavily and can run e85 on stock injectors. others require upgraded pump and injectors to accomplish the same thing, leaning more on the port injection. it's not just 'i think i need more fuel capacity so i must make more power'.
Old 07-24-2013, 11:12 AM   #53
EL7
EL7's Avatar
13.5k miles now lol
Hahaha, yup. Sorry lexusb3, I couldn't recall your handle at the time but yours is the ride I was referring to.
I like how you are open about really stress testing the kit and generally drive the car with a less than zero f*cks attitude. I've been following FBM and FA20Club kits so far and the more I read about FA20Club and the service and performance their kit puts down the more I'm leaning towards their setup.
I wish I could find a couple other FI members who are detailing their driving habits and the reliability of their kits. If anyone can point me to some more build threads like @King Tut and @Sportsguy83 I'd appreciate it. I'd really like to find a large variety of kits and custom builds to follow.
The Following 2 Users Say Thank You to EL7 For This Useful Post:
lexusb3 (07-24-2013), Sportsguy83 (07-24-2013)
Old 07-24-2013, 11:24 AM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
^This.
My engine has over 20,000 miles on it now and about 12,000 miles of that has been forced induction.
Old 07-24-2013, 03:34 PM   #55
lexusb3
Drives: FRS
Thanks to me that's the point to let people have the info !!! I have the balls the money and access to a local tuner 15 minutes away and E85 5 minutes away I just felt like the perfect canidate to do what I'm doing so of course ill share every minute
Old 07-25-2013, 05:50 AM   #56
cf6mech
Guess you haven't been there done that yet then. Doesn't matter DI or Port or any combination of the two,...eventually this 165whp engine is going to need more fuel volume once you double or tripled the fuel systems design limits...come on! It has all to do with power level when we are talking BIG power. And that big power level for this engine rides around 20 psi with E85. No blind faith here, just the acknowledgement of the fact that they have been at the forefront of these engines FI, have done the most test and tuning of them, do this for a living, and are not backyard tuning Bozo's.
Safe amount of boost on stock engine? Octane Forced Induction 51 12-06-2017 07:25 PM
How reliable is a boosted FRS/BRZ? wootwoot Forced Induction 123 07-22-2016 03:18 PM
Most reliable F/I kit? official_george Forced Induction 103 05-14-2013 12:00 PM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
