Old 07-22-2013, 12:48 PM   #15
SigmaHyperion
Drives: 2013 SWP BRZ Limited
Originally Posted by ndsleep612 View Post
On a warmed engine, the idle still sits at around 1500rpms for over 30 seconds.
Like I said in my earlier post, every vehicle I've owned for at least the past decade has always done this.
I could have driven it all day long, it could be 110* outside, the engine could be boiling hot, and it'll idle at above 1000 RPM at start-up for at least a little bit before dropping. Unless it's doing it in the middle of a warmed-up drive cycle (i.e. you're stopped at a red light after 15 minutes and it's still high), you're fine.
If I were totally guessing, I would guess it has something to do with an ECU check and the emissions systems in modern vehicles. They certainly seem far more likely to exhibit this behavior than cars in the past, which would drop idle almost immediately.
SigmaHyperion is offline   Reply With Quote
Old 07-22-2013, 03:34 PM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by whtchocla7e View Post
NORMAL.
This.
Old 07-22-2013, 09:06 PM   #17
BRZnut
Drives: BRZ DGM Limited
What is the idle after 10 min of driving?
Old 07-27-2013, 09:58 AM   #18
arghx7
Drives: car
it's normal
Old 07-27-2013, 10:54 AM   #19
andrew20195
Drives: 2013 Subaru BRZ
Besides warming up the engine, another purpose of a fast idle is to warm up the catalytic converter. Furthermore, if you tend to drive aggressively before the engine is fully warmed up, the ECM will attempt to warm the engine more quickly than normal.
@OP: I suggest you start the car from overnight cold and time how long it takes for the idle to drop to normal levels -- around 700 RPM.
andrew20195 is offline   Reply With Quote
Old 07-27-2013, 11:06 AM   #20
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
This looked perfectly normal to me. Now when you stop at a light. What happens? Does it sit there?
Idling/RPM question Crackseed Hawaii 3 02-25-2013 12:54 AM
Idling problems Canadian cars Skye CANADA 17 08-28-2012 02:11 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
Idling and parking brake markmatley Engine, Exhaust, Transmission 1 06-09-2012 08:20 PM
