Old 07-22-2013, 01:30 AM   #1
ndsleep612
Drives: Thee Argento Cricket
High idling on new FR-S
My FR-S was manufactured in May 2013. I bought this in June 2013. After 1 month of ownership and 600-ish miles later, I discovered today that the car has high idling between 1200-1500 at start up when the engine is warmed up.
Most of what I read about you guys have low idling, never high idling. This is no good. Time to visit the dealership tomorrow morning...
ndsleep612 is offline   Reply With Quote
Old 07-22-2013, 04:16 AM   #2
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
And it stays like even after like 30 seconds? Or only for a bit after start up?
JDM FRS is offline   Reply With Quote
Old 07-22-2013, 04:18 AM   #3
ft_sjo
Drives: GT86
You're taking your car to the dealership because of a normal fast-idle condition on warm-up?
The Following User Says Thank You to ft_sjo For This Useful Post:
strat61caster (07-22-2013)
Old 07-22-2013, 04:21 AM   #4
JDM FRS
JDM FRS's Avatar
Yea mine revs about the same at startup then goes down. Kinda wish it stayed high because it sounds so sexy lol
Old 07-22-2013, 04:32 AM   #5
Fast_Freddy
Drives: Passat
Look at your temp gauge. Your engine is only partially warmed up and that high idle is perfectly normal unless it stays that way for several minutes or is always that high. The ECU knows best, don't worry so much. The moment anything goes wrong you'll get a CEL. Until then, relax and enjoy the car.
Fast_Freddy is offline   Reply With Quote
Old 07-22-2013, 04:42 AM   #6
SigmaHyperion
Drives: 2013 SWP BRZ Limited
Well, first off, the engine isn't full warmed up as indicated by the temp gauge. And, additionally, I've owned a lot of cars, and I don't think of the ones made in the last decade or so at the very least would drop straight to regular idle immediately after start, even if the engine was fully-warmed up. There's always some period of time where it idles a little higher than usual.
Now if you had been driving it around town for 15 minutes. Stopped at a light. And it still idled like that. Then, yeah, you could have an idle problem. But the means to make that happen should throw a CEL if that were the case.
SigmaHyperion is offline   Reply With Quote
Old 07-22-2013, 05:38 AM   #7
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
remember temp gauge doesn't mean the car is fully warmed up. Oil warms up slower than coolant.
bkblitzed is offline   Reply With Quote
Old 07-22-2013, 09:09 AM   #8
Mikem53
Drives: FR-S 6MT
So what's the problem? All normal.. Chill out
Mikem53 is offline   Reply With Quote
Old 07-22-2013, 09:40 AM   #9
Symmetrical
Symmetrical's Avatar
Drives: 2013 DGM BRZ Limited
That looks perfectly normal to me. My BRZ still does the warm up idle even though the engine's already warm, but then after 5 seconds or so it drops back to low idle.
Symmetrical is offline   Reply With Quote
Old 07-22-2013, 11:04 AM   #10
ndsleep612
I drove this car the entire day yesterday and had this problem at startup each time. Mind you, if you drive the entire day you'll have a warmed up engine. So far this is the only issue that can be replicated on the car. The ecu is weird...
On a warmed engine, the idle still sits at around 1500rpms for over 30 seconds.
Old 07-22-2013, 11:31 AM   #11
ndsleep612
After 30 seconds on a warmed engine the rpm still stays the same. It doesn't drop unless I drive.
Old 07-22-2013, 11:35 AM   #12
ft_sjo
Drives: GT86
Well that doesn't sound right.
Old 07-22-2013, 11:49 AM   #13
radroach
Drives: car
My car idles at 1500 for 20-30 sec. before first driving.
Old 07-22-2013, 12:08 PM   #14
whtchocla7e
Drives: 2013 FR-S Hot Lava
NORMAL.
Live to drive another day
whtchocla7e is offline   Reply With Quote
The Following User Says Thank You to whtchocla7e For This Useful Post:
King Tut (07-22-2013)
Idling/RPM question Crackseed Hawaii 3 02-25-2013 12:54 AM
Idling problems Canadian cars Skye CANADA 17 08-28-2012 02:11 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
Idling and parking brake markmatley Engine, Exhaust, Transmission 1 06-09-2012 08:20 PM
