Old 07-21-2013, 04:05 PM   #379
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by swift996 View Post
Yeah 93 is going to send less fuel than E85. So it sounds like simply upgrading injectors should buy you some protection. Simple install (took me 30-40 minutes) and you can do it when you're installing the supercharger since you pull the injectors anyways. I might do the pump anyways to support more power down the road (smaller pulley w/ intercooler or WMI).
I didn't get the injectors until this week, so I couldn't do it when I did the SC install. Will likely do it in the coming weeks though. and thanks.
wrxgoose is offline   Reply With Quote
Old 07-21-2013, 04:08 PM   #380
swift996
swift996's Avatar
Yeah I know I meant for @xjohnx on the install
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-21-2013, 07:36 PM   #381
xxscaxx
Drives: 2013 SWP BRZ
anyone going to be upgrading their motor mounts? Been thinking about doing it and with my JDL UEL header coming soon (hopefully) seems it would be the best time to install them.
xxscaxx is offline   Reply With Quote
Old 07-21-2013, 09:01 PM   #382
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I'm installing my kit on Wednesday. @NickFRS will be installing his simultaneously. We might have @Jason@Nameless helping us out since he has already installed his. I know that @tech4pdx will have his on soon, too. That's a LOT of S/Cs for our area!
Old 07-21-2013, 11:17 PM   #383
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
what do you think about increasing the fuel pressure of the injector by changing the FPR.
That's a solution that was used on VW R32 swaping the 4 bar FPR to a 5 bar FPR. Much cheaper than new injector's.
May be this car don't have a FPR on the low pressure fuel system
Mars2 is offline   Reply With Quote
Old 07-21-2013, 11:18 PM   #384
whataboutbob
AutoX-10/10ths every run
First AutoX in mine today. That extra power is going to take some time to get under control. Very nice not to have to deal with the torque dip.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
ftc~brz (07-22-2013), sw20kosh (07-22-2013)
Old 07-21-2013, 11:19 PM   #385
ftc~brz
Done
Drives: WRB BRZ
Had that done with my install. Perrin mounts are pretty sweet
ftc~brz is offline   Reply With Quote
The Following User Says Thank You to ftc~brz For This Useful Post:
Sportsguy83 (07-22-2013)
Old 07-21-2013, 11:55 PM   #386
xxscaxx
Nice. Just wondering if its truly worth it. I see a bunch of people saying its "needed" but then again I'm not sure we are at that power level where it's a necessity. Rather put that 350+dollars somewhere else.
Old 07-22-2013, 12:16 AM   #387
ftc~brz
Done
Drives: WRB BRZ
That's what I thought too but there was a lot of slop shifting around in there that it concerned me enough to just go ahead and change them now so it's not an issue later. I like the piece of mind. It was definitely worth the $350+ for me.
Old 07-22-2013, 01:09 AM   #388
Dezoris
Dezoris's Avatar
If you need the Innovate serviced, does it get shipped out of the Country or does Innovate have engineering and repair in the USA?
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
akuhei (07-22-2013), xjohnx (07-22-2013)
Old 07-22-2013, 08:23 AM   #389
xjohnx
Grip>Slip
xjohnx's Avatar
Good question.
Old 07-22-2013, 09:19 AM   #390
xxscaxx
That is a good question.
I don't see what all the fuss is about with the fuel pump. Its super easy to put in. Peace of mind if anything.
I have heard so many different things from people regarding what you need that I can't believe anyone. I think people need to just listen to whatever their tuners want regarding fueling.
First I hear all you should upgrade is the fuel pump, injectors aren't needed. Even for e85.
Then its you need injectors for e85 for high load conditions.
Then its fuel pump and injectors. I have been told about 2-3 different sizes being "adequate".
Now its no need for the fuel pump.
Pick your tuner, if he says you need a fuel pump/injectors/rainbow pinstripes, get it.
Old 07-22-2013, 09:26 AM   #391
Mikem53
Drives: FR-S 6MT
Doesn't always work well just by upping the pressure.. Cause you alter the spray pattern of the injector to where its not misting or optimized..
Mikem53 is offline   Reply With Quote
Old 07-22-2013, 09:30 AM   #392
Mikem53
Drives: FR-S 6MT
I don't think blindly following the tuners advice is great advice.. Especially since they might tell you to buy their rainbow pinstripes and other goodies they sell that you don't need.. Knowledge is power and money in your pocket in most instances...
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
