Old 07-20-2013, 09:53 PM   #365
xxscaxx
Drives: 2013 SWP BRZ
I haven't but i'm using the FA20club P3 gauge so it has built in boost
xxscaxx is offline   Reply With Quote
Old 07-20-2013, 10:22 PM   #366
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
I thought the factory sensor was only good to 5lbs of boost though?
MattF is offline   Reply With Quote
Old 07-20-2013, 10:34 PM   #367
xxscaxx
i believe it can go to 7 but either way I can just run a new sensor and be set
Old 07-20-2013, 10:38 PM   #368
FA20Club.com
Drives: 2013 White Out FR-S
its 7psi. mainly for diagnostics. you cant boost higher but wont be able to log anything higher than 7psi.
FA20Club.com is offline   Reply With Quote
Old 07-20-2013, 10:59 PM   #369
wrxgoose
WUB WUB
Drives: 2013 Firestorm
sorry, but I saw this, and wanted to share it. POWERRRRRRRR
wrxgoose is offline   Reply With Quote
Old 07-21-2013, 01:01 AM   #370
sw20kosh
Drives: 2013 Black FR-S
why have I seen people's OBDII apps not go any higher than 5.3 (mine included)? I figured it was the sensor that was limiting this.
Old 07-21-2013, 01:06 AM   #371
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
correct. the stock MAP sensor maxes our around 5.2 PSI.
I'm running the P3 gauge with their analog boost sensor. Seeing about 7.5 PSI with the 80mm pulley.
Tom
tom@kartboy is offline   Reply With Quote
Old 07-21-2013, 08:40 AM   #372
FA20Club.com
scaling on the sensor. you guys can have it edited just like what we do with the oem afr sensor to read lower than 12.1. the factory pressure sensor is 0-5v but isnt scale the entire window i think it only goes to 3.9v from what i can remember off the top of my head and starts at .6
Old 07-21-2013, 11:20 AM   #373
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by moto-mike View Post
Our pulls on the stock fueling were nearly as choppy as the innovate graphs due to stock fueling. Those DW700's are perfect for this kit.
So the choppiness is going to be a permanent issue with the base innovate kit or do you think you can over come this issue?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-21-2013, 11:25 AM   #374
xjohnx
Grip>Slip
xjohnx's Avatar
I'm currently wondering the same thing. We may know more once @moto-mike goes through some logs today. We may also learn if the stock fuel pump + DW700's will be sufficient to support E85 on the stock innovate pulley.
I wouldn't mind installing new injectors, that looks fairly straight forward. It's the pump that I don't want to deal with right now (if I can avoid it).
Old 07-21-2013, 02:39 PM   #375
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Put the stock pump back in. Works fine to 7800 RPM with the stock pulley and E85. Ran it down to nearly an empty tank and no starvation issues.
Verdict though would be on the smaller pulley, cold weather, and headers. If we're still good there I think stock should suffice.
Xero-Limit is offline   Reply With Quote
Old 07-21-2013, 02:43 PM   #376
xjohnx
Grip>Slip
xjohnx's Avatar
Great news, thanks for following up!
Old 07-21-2013, 03:50 PM   #377
wrxgoose
WUB WUB
same with regular pump gas? friend and I have been a little worried about starvation issues with the stock pump, and any info would be awesome
Old 07-21-2013, 03:59 PM   #378
swift996
swift996's Avatar
Yeah 93 is going to send less fuel than E85. So it sounds like simply upgrading injectors should buy you some protection. Simple install (took me 30-40 minutes) and you can do it when you're installing the supercharger since you pull the injectors anyways. I might do the pump anyways to support more power down the road (smaller pulley w/ intercooler or WMI).
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
