Old 07-17-2013, 09:58 AM   #1583
tinma
Drives: '13 BRZ
Lol Mexi flush
tinma is offline   Reply With Quote
Old 07-17-2013, 10:21 AM   #1584
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Any possible fitment issues on 17x9 +35 with 255/40/17 all around on springs @ 1" drop?
raul is offline   Reply With Quote
Old 07-17-2013, 11:03 AM   #1585
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by Sekal View Post
I've been getting biased opinions and I need to expand my question to a bigger party.
18x9 +33 offset. 255/35 tire. Stock suspension. Will it rub in the front? I want to keep the front full, as in chunky and full of meat.
via pm
Yeah, I don't want a mexiflush.
Is it a problem with my wheel or will a smaller tire avoid mexiflush? What tire sizes would you recommend.
Should I keep 255/35 rear and try a different size? I could use your help.
Here's my car, with a 18x9 +42, 245/35/18 test fitted in the front - this is poking from the wheel well at stock height by about 5-10mm in the front. In the rear it's probably going to look pretty much flush at stock height.
You are proposing 18x9 +33, 255/35/18 - so picture mine with a meatier tire, and 9mm further out from the wheel well (which it is already 5-10mm out already). Lots of poke in the front.
In order to avoid so much poke on stock suspension, you have a few options.
Stretching the tire is an option I suppose, but the wheel is still poking the exact same amount, its just the tire might make it look a bit closer to the wheel well. It's not going to look great, I don't like the stretched tire look, I really don't like it with stock suspension. Personal preference. My tires are more stretched than I wanted... think its the brand of tire really.
The other option is to add lots of camber. Hard to do with stock suspension. Again at stock height this might look sillier than if it were the same car lowered. But an option none the less. 3 degrees might work.
You might be able to have the backpad of the wheel machined by 10mm. But that's going to cost money to have it done properly, you had better love those wheels because now they're custom and if you ever break/bend a wheel you're going to have to get the same process done to them next time.
The last option, and the best option IMO is to get a different wheel with a higher offset. At 18x9 and stock height, I wouldn't do any more than +42, maybe +40 if you're doing 255/35/18. If you go any higher you will hit the struts/springs. This will still poke, like my picture above, but not as offensively as a +33.
If you are set on those wheels with those tires, either lower it and add a bit of camber, or just deal with lots of poke.
djdnz is offline   Reply With Quote
The Following 2 Users Say Thank You to djdnz For This Useful Post:
IloveBaldEagles (07-17-2013), tinma (07-28-2013)
Old 07-17-2013, 11:39 AM   #1586
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
I'd say. It'll stick out 7mm more than this, which is 17x9 +42 with the same tire size. This is with Whiteline Com-C upper strut mounts for -2 degrees front camber.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following User Says Thank You to Mach V Dan For This Useful Post:
fstlane (07-18-2013)
Old 07-17-2013, 12:12 PM   #1587
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
Thanks for all the help guys
I am very insecure. I have no friends. I want people to love me
Old 07-17-2013, 12:22 PM   #1588
raul
Lap time enthusiast
raul's Avatar
@Mach V Dan
Hmm... I just found this:
http://www.ft86club.com/forums/showthread.php?t=17040
Doesn't seem to poke much.
Old 07-17-2013, 01:03 PM   #1589
djdnz
1337
@Mach V Dan
That's more than 1" drop. It's also nearly 3 degrees of camber. But yes, can be done!
Old 07-17-2013, 10:57 PM   #1590
Dipstik-sportech
Dipstik-sportech's Avatar
Originally Posted by ill86 View Post
Effectively a 7.5" +38
With 275 it should fit fine
Rear only drag radials... Yeah yeah :-)
Now another possible issue. With a 26" tall tire on the rear and stockers on the front will my tc and stability control go mad even if I shut it off? I really don't wan to do the pedal dance before every run lol
Old 07-18-2013, 01:44 AM   #1591
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
I have no idea, sorry.
25" doesn't cause problems fwiw.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 07-18-2013, 03:18 PM   #1592
encity5
encity5's Avatar
Hey guys, im a noob with wheel fitment and have been reading up past few days.
Im hoping to settle on my first wheel purchase which i am looking at miros type 398s
I wanted a square setup. the wheel size is
18x8.5 +34
and were thinking about tire sizes at
235 40 18
i am not lowered and on stock suspension. I might lower after i buy wheels with a 1inch drop.
Is there anything else i need or am forgetting about? Im not too worried about making it flush, just want the new wheels to fill out the gaps a bit better and not poke.
Thanks!
Im still looking but i havent seen any setups with 8.5 width and a 34 offset, most setups ive been seeing are between 40-45mm offset, which has prompted me to ask. The fitmet chart also lists 44 front and 37 back offset for flushness. So im wondering if +34 is too much of a difference
encity5 is offline   Reply With Quote
Old 07-18-2013, 06:11 PM   #1593
ill86
ill86's Avatar
Drives: iG FR-S
8.5 +34 will poke slightly up front w/o negative camber from alignment or drop.
If you have seen 8.5" +44, your +34 is 10mm out from that.
18x8.5 +34
235 40 18
Thanks!
The Following User Says Thank You to ill86 For This Useful Post:
encity5 (07-18-2013)
Old 07-18-2013, 06:40 PM   #1594
ill86
ill86's Avatar
Drives: iG FR-S
FYI
8.5" +34 does not equal 8" +34 or 9" +34, etc.
You can only do "quick math" if the width is the same.
Ie: 8.5 +34 vs 8.5 +44 = 10mm difference
If width changes your numbers comparing do as well.
1" = 25.4 mm (call it 25mm)
8" +34 vs 8.5" +34 is 12.5 mm difference in width
So, 6mm more wheel in, 6mm more wheel out.
8" +34 vs 9"+34 is 25mm difference in width
So, 12.5mm more wheel in, 12.5mm more wheel out
Then of course any mm difference in offset.
Lower offset number, more wheel poke
Higher offset number, less wheel poke
Any other questions, ask away.
I'd prefer to teach you how to fish than just give you fish to eat. This way you can teach others if you choose to.
Old 07-18-2013, 09:01 PM   #1595
Vic
63 Auto Body
Vic's Avatar
Drives: 2013 SCION FR-S WHITEOUT
Hey guys, I'm new to this so Im trying to run a 17x9 with 20 offset square setup on a stock suspension (no drop, stock.).
I'm going with 245/40/17 tires on it. I'm just concerned with any rubbing issues if anyone has a similar setup.
Can someone recommend me good tires that doesn't reduce the handling feel of the fr-s with this setup? Thanks!! (I'm a noob at this)
Vic is offline   Reply With Quote
Old 07-18-2013, 09:25 PM   #1596
mashal
DADA
mashal's Avatar
Drives: 2013
Rims are Moda MD11: 18x8", offset is et42, the centre bore is 72mm I believe (hub centric rings will fit them to any car)
Tires are Westlake SV308s: 225/40R/18 all-seasons
What do you guys think of that? I copied that of the ad.
mashal is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
