Old 07-16-2013, 03:16 PM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is it worth listing the right front disc part numbers to complete the thread?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-16-2013, 03:31 PM   #16
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
DBA 4000 Series T-Slot Slotted Front Rotor 4650S are the ones I installed on FRS
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-16-2013, 04:10 PM   #17
wparsons
wparsons's Avatar
Originally Posted by FRS2000 View Post
** I verified that the Brz has different rear rotors available between premium and limited models. I checked both at the dealership. I haven't confirmed the fronts though.
FYI: I contacted DBA directly in Australia... they have good customer service.
Not sure about the rest of the world, but Canadian BRZ's have the exact same brakes on both trim lines. I've looked at both in person, both have vented rears and the same diameter fronts.
flickr
Old 07-16-2013, 05:16 PM   #18
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I find that very surprising. Still, doesn't change the part numbers for the Limited which are wrong.
Old 07-16-2013, 05:18 PM   #19
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
I did too. Then I confirmed that it's not true.
Here are pictures of the rear brakes on a 2013 Premium sitting on the local dealer's lot - the same vented discs as on all US-market cars:
Admiral Ballsy is offline   Reply With Quote
The Following User Says Thank You to Admiral Ballsy For This Useful Post:
SkullWorks (07-16-2013)
Old 07-16-2013, 05:24 PM   #20
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Does Dba make 2-piece rotors for us yet?
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 07-16-2013, 05:33 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
That's what I thought.
Old 07-16-2013, 05:34 PM   #22
OrbitalEllipses
Drives: Attitude
We have the 2010+ LGT rear rotor in the US on all of our trims.
Old 07-16-2013, 05:37 PM   #23
Admiral Ballsy
Shorter of breath
Or WRX, or...well, several cars use it, anyway. There is no "Legacy GT" anymore, is there?
Old 07-16-2013, 05:42 PM   #24
OrbitalEllipses
Drives: Attitude
Different from the WRX rear rotor by a couple millimeters. It's the 2010 LGT rotor; there was an LGT through 2012.
Old 07-16-2013, 05:44 PM   #25
Wonderbar
Driveway labs.
Wonderbar's Avatar
Our ebrake is larger than the wrx. 2004 sti rear rotors work for us.
Old 07-16-2013, 05:46 PM   #26
OrbitalEllipses
Drives: Attitude
Why would it [2004 STI rotor] fit...? Completely different hat offset, but has the right parking brake diameter (190mm). 2010+ Legacy GT rotor = our rotor.
Old 07-16-2013, 05:47 PM   #27
Wonderbar
Driveway labs.
Wonderbar's Avatar
Because that with the Subaru 2-pot rear caliper and brackets is what I will be running.
Old 07-16-2013, 05:48 PM   #28
OrbitalEllipses
Drives: Attitude
Okay, so it fits in a specific application that does not relate to the thread at hand (which is replacement rotors)? Not trying to give you a hard time, but this thread already has a ton of misinformation.
DBA T3 rotors fitted AVOturboworld Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-16-2013 02:28 PM
Color, how important is it to you? Iixii BRZ First-Gen (2012+) — General Topics 63 11-09-2012 10:25 AM
OptionJDM - DBA Rotors OptionJDM Brakes, Suspension, Chassis 6 07-21-2012 11:50 AM
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-13-2012 10:58 AM
How important is an LSD on this car? colHolm Scion FR-S / Toyota 86 GT86 General Forum 92 05-13-2011 05:53 PM
