#57 |
Drives: Some rust bucket
#58 | |
I've seen cases where it started after just an outlap on the track |
#59 |
#60 | |
Drives: 2013 WhiteOut FR-S
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
#61 |
#62 |
Well i think u already know the answer
#63 |
Drives: First SWP BRZ-L
Love your profile pic.
![]() FYI, I can *definitely* hear the det on tip in with my headers. The louder exhaust has made it significantly more noticeable. Autocross actually made it det a TON, since you are on/off/on/off/on throttle the entire course, most of the time above 5800. I was cringing when in the passenger seat as an instructor was driving because of her really great accelerator pedal modulation was making it det pretty much constantly the entire course. There was far, far less det on the car on the track, since it only det'd once per upshift, instead of 3 or 4 times a second x 60 seconds like it did in autocross.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
| The Following User Says Thank You to Tainen For This Useful Post: | RehabJeff86 (07-12-2013) |
#64 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Can someone help me figure out my torque readings and if it relates to the DI issue?
I ran the Knock Detector app (https://play.google.com/store/apps/d...kills.kd&hl=en) and did some runs in 2nd and 3rd gear and random RPMs and had a "Possible Knock" maybe 1 out of 5 times or so. Also in the app, my throttle while fully depressing the gas to WOT was only around 83% (should be 99 or close I assume), anyone know what could be causing this? Maybe the ECU holding back for some reason? Secondly my AFR numbers don't look so good.. Normally around 14-15 at idle which is fine but I have seen it spike to 20 occasionally running extremely lean. One specific instance I remember was when I was coming to a stop and it jumped up to 20 for a seond before returning to ~14.5 at idle. I am assuming this is not normal; can anyone chime in on what's going on? Possible leak causing the AFR to run super lean?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#65 | |
Drives: 2013 FRS Asphalt
I do know that at wot the throttle postion is always around 80ish percent. Not sure why they do that.
2013 Scion FR-S AT Picked up 5/30/2012
#66 |
Godzilla Konvert
Drives: DMG BRZ Limited 6MT 2013
Can all the folks that actually have the DI issue please let us know your car's build dates... maybe the newer ones already have this fix. So far, all of the cars I know about is was purchased in 2012 with build date in 2012. Can someone confirm or deny this?
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel |
#67 | |
Drives: GT86
All of the above is perfectly normal and not a problem. |
| The Following User Says Thank You to ft_sjo For This Useful Post: | l0aded (07-15-2013) |
#68 | |
Drives: Scion FR-S/Toyota Yaris
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#69 | |
Drives: Black frs project
http://www.ft86club.com/forums/showt...34#post1068034 again Mike drove a car on the track KNOWING that the seal had already failed. They had taken the car to the dealer and they said bring it back when it has a code... It was popping going out on the track....and once you have heard this sound you KNOW that the seal is bad. Mike knew this and drove it anyway... |
| The Following 3 Users Say Thank You to robispec For This Useful Post: |
#70 |
Drives: GT86
Sometimes I wonder if you're just plain stupid, or are only interested in listening to yourself and/or whatever on Google matches your delusions? Most modern vehicles have adaptive spark strategies which constantly advance the spark angle until a knock event occurs.. KNOCK HAS TO OCCUR FOR THIS TO WORK.
End of discussion. Stop spreading FUD and paranoia. |
| Trunk release failure - BRZ | Smilez | CANADA | 35 | 07-15-2019 11:15 PM |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 12:25 PM |
| 100% DI Failure with Nurburgring rentals | regal | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 10-07-2013 06:18 PM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 01:25 PM |
