Old 07-05-2013, 05:44 PM   #99
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Im not trying to replace the harness for a PandP harness; Im trying to make it work with the one we have. I almost guarantee we can do this, in steps ofcourse. First, find the power wires and find the right connector on the unit, then finding the right ports for the wires. It sounds hard, and im sure it is, but in the same breath this is a great project and I will find a way.
Originally Posted by tjohnson104 View Post
okay what about a premium brz swap. would the premium have the same case as the frs, or just because its subaru would there be a more willing chance of the wires being back there?
Im not sure; somebody should check and see.
also, does anybody have better, high quality pictures to the actual connecters that go into the stock FRS climate unit? if not, ill try to take some soon.
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 07-05-2013, 05:47 PM   #100
Sco2355
Yes the premium BRZ HVAC swapped to the dual climate from the limited will be the exact same issue. The Premium BRZ with non-dual climate has the same harness we do.
Sco2355 is offline   Reply With Quote
Old 07-05-2013, 05:50 PM   #101
AG3NT_5CARFAC3
Drives: Toyota GT86
Front/Back of the GT86 unit and the FRS
Old 07-05-2013, 05:51 PM   #102
Sco2355
So you're just doing this for the sake of doing it? I just don't see any reason if it isn't functional.
Old 07-05-2013, 05:54 PM   #103
AG3NT_5CARFAC3
Drives: Toyota GT86
It should work, it just wont have the "true dual" climate; It will do everything our stock FRS unit will do, just in a GT86 form. And thats fine with me. What I dont think is worth it is a WHOLE harness for $800+ just so the passenger can have a different temp then the driver. Also, a BRZ Limited/GT86 ECU would have to be installed, along with the vents...so for about $200, im willing to help to the solution.
Old 07-05-2013, 05:59 PM   #104
Sco2355
I have a feeling the FRS ECU will work. Also what vents are you talking about? The little servo's? All the venting behind the dash is the same between the two. You realize none of the digital stuff is going to work because there is NO wiring for it. It just seems like a short cut that I personally wouldn't take. I'd rather have all the pieces and make it all functional.
The Following User Says Thank You to Sco2355 For This Useful Post:
FRSToyota86 (12-23-2013)
Old 07-05-2013, 06:19 PM   #105
AG3NT_5CARFAC3
Drives: Toyota GT86
if I have a few grand to make it fully functional, I would. But I dont. I know I can make it fully light up, just when you adjust the temp, the numbers will move on the "Auto" side. It just wont be true "dual climate". There are, in theory, TWO climate wheels on the GT86 version instead on ONE on the FRS...as for the vents, I was talking about dual climate vents that would work with the ECU and the correct harness
Old 07-05-2013, 06:23 PM   #106
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Cessblood is offline   Reply With Quote
Old 07-05-2013, 06:30 PM   #107
AG3NT_5CARFAC3
Drives: Toyota GT86
@Cessblood is dual climate is for RHD
The parts catatlog shows 4 different part numbers for the dash harness. Preimum AT & MT, Limited AT & MT
Old 07-05-2013, 06:37 PM   #108
Sco2355
There are no "dual climate vents" that work with the ECU and harness. And there is no theory... The GT86 is like the FRS. They have a base with the same HVAC as us and the upgraded models with dual climate. Both have a different harness. I'm going to just end it here. Good luck with your install...
Old 07-06-2013, 02:07 AM   #109
Jlin
Drives: FRS
How are you addressing the difference between the mechanical vent selector in the frs and brz premium vs motorized vent selector in the limited?
Jlin is offline   Reply With Quote
Old 07-06-2013, 11:34 AM   #110
usmc1341
Drives: 2013 scion fr-s
They told christopher columbus the world was flat and look what happen!!!! OP I say go for it!!!
usmc1341 is offline   Reply With Quote
Old 07-06-2013, 12:13 PM   #111
Sco2355
We aren't saying don't do it. I for one will be doing it also. Most of us just want it to work the way it's suppose to. To me that adds value. I can see in the future when people sell their cars and its done, people will be more willing to pay a bit more when it's done correctly. It drives me nuts when people do hacked up conversions.
Old 07-06-2013, 12:41 PM   #112
AG3NT_5CARFAC3
Drives: Toyota GT86
@Sco2355 do you have the dual unit yet?
and for the next 5-7 years, this is my car. When it is time to sell/trade it, all id have to do is put the stock unit back in and sell the dual if somebody needs it, unless a private sale the new owner is (and will be) happy with my work.
The Following User Says Thank You to AG3NT_5CARFAC3 For This Useful Post:
sklimo (08-20-2013)
Auto Climate Control turns on randomly cantaloupe BRZ First-Gen (2012+) — General Topics 18 03-14-2013 08:38 AM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 08:03 PM
auto climate control units at japanparts abutterman Cosmetic Modification (Interior/Exterior/Lighting) 17 01-22-2013 07:14 PM
Climate control bezel Surok AUSTRALIA 7 10-25-2012 05:34 AM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 09:19 PM
