Old 07-03-2013, 05:48 PM   #15
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
Would be a great time to install the Rydeen Duo backup camera; run them together... with full instructions on which panels to remove.
GeorgeJFrick is offline   Reply With Quote
Old 07-03-2013, 05:50 PM   #16
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
https://www.subaruonlineparts.com/in...?cPath=160_170
$529.99, Little bit better.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
Chee-Hu (07-12-2013)
Old 07-03-2013, 06:22 PM   #17
KGFRS86
SoCal Asphalt FR-S Owner
KGFRS86's Avatar
Drives: 13' Asphalt FR-S
Do you guys think this will be compatible with the FR-S? I wonder if this is only compatible with the Subaru head unit..
KGFRS86 is offline   Reply With Quote
Old 07-03-2013, 06:26 PM   #18
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
I would stay away from this Accessory unless they (Subaru-Kicker) have worked out some form of adjustment with it.
I have not reccomended these subs to my customers for years now because they are full on bass or unplugged. With no adjustment between the two.
I have had a few customers purchase these for their Impreza's and be totally turned off by the full-on or nothing bass with no real form of adjustment.
Beyer Subaru is offline   Reply With Quote
The Following 3 Users Say Thank You to Beyer Subaru For This Useful Post:
Chee-Hu (07-12-2013), GeorgeJFrick (07-03-2013), Marchy (07-05-2013)
Old 07-03-2013, 06:56 PM   #19
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
For that price I'd rather get a JL stealth box.
Trojan_SC is offline   Reply With Quote
The Following 3 Users Say Thank You to Trojan_SC For This Useful Post:
ravenblackfrs (09-14-2013), SkAsphalt (07-04-2013), suaveflooder (07-20-2013)
Old 07-03-2013, 08:45 PM   #20
GerryL
Drives: White BRZ
Originally Posted by Davesta619 View Post
Was thinking of getting the oem audio plus system 400+. Wonder if this will be equivalent or better.
The OEM system also includes new tweeters, and amplifiers for the existing system new DSP tuning and really improves the overall imaging of the existing system, on top of adding low end. I'd be surprised if this sub could add the subtle improvements that the OEM system does.
GerryL is offline   Reply With Quote
The Following User Says Thank You to GerryL For This Useful Post:
Yruyur (07-04-2013)
Old 07-03-2013, 09:43 PM   #21
hellyvin
Drives: WRB Brz
Anyone getting the OEM 400+ or already have it know how much it is to get it installed?
hellyvin is offline   Reply With Quote
Old 07-04-2013, 09:16 AM   #22
GTFrank
To me the stock system sounds like crap. Just adding bass is not going to help it much. For all that trouble you may as well go for a full radio after market amp and JL sub woofer. You are looking at twice the price but 5 times better sound quality. The Factory radio is the worst sounding I have experienced in years. Even the cheapest double din that Pioneer makes should far exceed the factory radio's performance. I am waiting for the next line of OS 7 compatible aftermarket radios than the factory system comes out.
GTFrank is offline   Reply With Quote
Old 07-04-2013, 09:29 AM   #23
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Get the stealth box and a real amp.. I mean seriously, it's drawing all the power it needs for the amplifier from the radio??? I didn't see an extra 4 gauge power and ground connection so I'm either missing something or the amp is capable of about 25 watts of power to push a 10" sub.
You get what you pay for...I wouldn't waste $50 on this setup let alone retail.
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
Sbeezy (07-04-2013)
Old 07-04-2013, 10:39 AM   #24
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
From the radio harness, not the radio. 100W doesn't require anything remotely resembling 4AWG, it's less than a 10-amp draw assuming class D (which it probably is).
However, you've still got a good point - the radio fuse is 7.5A, so unless the harness is using another power point somewhere, the specs are definitely fudged.
Admiral Ballsy is offline   Reply With Quote
Old 07-04-2013, 10:43 AM   #25
chadstyle
chadstyle's Avatar
The power source is the same...it's fused prior to the radio at the fuse box. If the fuse for the radio isn't upgraded during the install then its sharing the power that the radio is already pulling from that fuse. So if there's a 15 Amp fuse on the radio and the amp is sharing that fuse too without upgrading then there is no way possible that you will ever see 100 watts from the sub amp.
If they're rating the setup at 100 watts then I would guess its actually putting out 20-30 RMS.
Sbeezy (07-04-2013)
Old 07-04-2013, 11:49 AM   #26
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
I call shinanigans on this attempt at "premium" or "upgraded" audio by Subaru. They should know better that to offer their enthusiast customers (as most BRZ/FRS owners are) such a fickle and half hearted solution for the so-so audio in these cars...
On a side note - if someone finds out the size of this box, and where to buy it (ie Kicker) you could plug any amp and sub into it you want.... So if anyone out there has an insider at Kicker manufacturing, you should do some poking around. I mean I love JL's stealth box but I find their price has exceeded the brand's true value. I just want a frigging custom box for less than $300 so I can put my RE SEX 10" and alpine amp in my car!
RandomHero is offline   Reply With Quote
Old 07-04-2013, 12:00 PM   #27
Yruyur
Yruyur's Avatar
Link in my signature to my oem audio install and review.
Sent from a hamburger
Old 07-04-2013, 12:09 PM   #28
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
Sbeezy is offline   Reply With Quote
The Following User Says Thank You to Sbeezy For This Useful Post:
chadstyle (07-04-2013)
Subwoofer prewiring Nate219BRZ Electronics | Audio | NAV | Infotainment 3 09-09-2013 05:56 PM
SOLD! OEM Audio Plus Subwoofer + Amp + OEM Wiring shiro Audio/Visual, Electronics, Infotainment, NAV 25 08-30-2013 07:40 AM
BRZ Subwoofer solution? GeorgeJFrick Electronics | Audio | NAV | Infotainment 3 06-26-2013 09:10 PM
Subwoofer? yomchi1989 AUSTRALIA 31 09-06-2012 09:23 PM
Does BRZ and FRS come with a Subwoofer? R0ME0 FR-S / BRZ vs.... 6 05-07-2012 02:54 PM
