Old 06-07-2013, 02:24 PM   #225
Integrity Concepts
Integrity Concepts's Avatar
Drives: Concepts
Originally Posted by Redmist View Post
I don't care what JL is asking for it, if there's something better out there for less money then let us know...and no, a ghetto fibreglass job that'll fit any 10" driver doesn't count.
I'm sure it's great but I want a shallow mount *stealth* box, not a generic sub box that encroaches on the trunk space and I'm prepared to pay a premium.
Now I hear what you are saying in that you want something small, and I don't want to assume you were completely referring to our product, but I don't necessarily agree with your terminology in what appears to be in reference to our enclosure. So to hopefully help clarify your statements, let me put it all into perspective with some numbers.
JL's Stealthbox houses a 10TW3 woofer that would like to see a net airspace of .50 cu ft. When you add the displacement of the woofer at .019 cu ft. you get .519 cu ft to be exact. This would mean that if JL built their Stealthbox specifically to this woofer's needs it would be less then a 1/4 cu ft smaller than our enclosure. 1/4 cu ft is almost exactly 1/28th of the entire 7.0 cu ft trunk in this vehicle. So if you are worried about space that much you should really be looking at our 8" enclosure which comes in at about .4 cu ft, and you could even put a JL 8W3 in there which in my opinion would sound better than any flat sub.
Now lets look at the physical "encroaching" space that the Stealthbox occupies compared to our enclosure, you will see that our enclosure actually has a more compact design. In fact our enclosure utilizes more vertical space instead of stretching out to the back of the seat like the Stealthbox. Consider that the front of the Stealthbox has large ribs to strengthen that long flat stretch of fiberglass, this actually is taking up even more space. When you look at just the footprint of the two enclosures, our enclosure "encroaches" only 2.5" further where the sub is and not at all from the strut tower to the back of the seat. I would estimate that the two enclosures actually have the same sq in. footprint, and would welcome anyone to measure the Stealthbox for this comparison.
All this to say that terms like "Encroaches" hardly describe our enclosure.
I would also like to add that our enclosures are hardly "generic" since we tailor them to your woofers needs and customize them to your match your vehicle and personality.
I just really hope you weren't describing our enclosure when you used the term "ghetto fiberglass job that will fit any 10" driver"
Integrity Concepts is offline   Reply With Quote
The Following User Says Thank You to Integrity Concepts For This Useful Post:
Murseman27 (06-14-2013)
Old 06-07-2013, 02:51 PM   #226
mottor
mottor's Avatar
I think the biggest argument for the JL is that it is further out of the way in the largest part of the trunk, which is the corner that many other boxes occupy. I personally consider that corner of the trunk to be more usable space than the 2" that the stealthbox occupies all the way to the back seat. This is especially true if you were to try to pack a lot of luggage or something in the trunk. It's easier to fit a bunch of solid square items against a flat edge than it is to fit them around a rounded corner.
No offense intended, just suggesting a use case where the user might prefer the JL product.:happy0180:
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub
mottor is offline   Reply With Quote
The Following User Says Thank You to mottor For This Useful Post:
Redmist (06-15-2013)
Old 06-07-2013, 03:19 PM   #227
Integrity Concepts
Drives: Concepts
No offense taken. Thanks for the constructive input!
Our enclosure doesn't come past the opening of the trunk so it shouldn't restrict the loading of luggage, and other than the 2.5" it comes out further than the Stealthbox at the opening, we actually figured that corner space to be fairly useless especially for square items. If all the space was really needed for transporting something, our enclosure can be removed in 30 sec., and the JL Stealthbox cannot.
When we were designing the enclosure and wanted to have it work for more than just a slim woofer, we were limited on places locate it. We saw a real benefit to the tuners if we stayed away from the strut tower bar location. We also based it off of this golf club pic in which you could have a pair of our enclosures and still pull this off with plenty of room to spare at the front of the trunk:
Old 06-07-2013, 04:42 PM   #228
mottor
mottor's Avatar
Do you have pictures from the same angle with each of your enclosures? My mind isn't really made up on what I'm going to get, so I'm always willing to consider another product. How does yours attach to the inside of the trunk? I'm more worried about how secure a box is than difficulty of attachment or modifying the inside of the trunk.
Old 06-07-2013, 05:25 PM   #229
Integrity Concepts
Drives: Concepts
I do no not have the exact angle but these may help:
10" Passenger Side
10" Passenger Side
8" Passenger Side unfinished (smaller than the Stealthbox)
mottor (06-07-2013)
Old 06-14-2013, 11:52 PM   #230
rbizzle004
Here it is. Name:  ImageUploadedByTapatalk 21371264711.356476.jpg
Size:  82.4 KBName:  ImageUploadedByTapatalk 21371264723.772362.jpg
rbizzle004 is offline   Reply With Quote
The Following User Says Thank You to rbizzle004 For This Useful Post:
Old 06-17-2013, 01:47 AM   #231
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
Glad I went with the Integrity Concepts box. Decision made much easier based on JL $1,250 price for Australia.
Gir is offline   Reply With Quote
Old 06-20-2013, 02:47 AM   #232
Oc Ca
Drives: subaru limited brz pearl white
Found a vendor to hook up the box for under 500.
Orange county ca
Oc Ca is offline   Reply With Quote
Old 06-20-2013, 12:31 PM   #233
mottor
mottor's Avatar
Orange county ca
How much under $500? Do you have a guaranteed amount? Are they going to start a group buy on the forum?
NorCalGirl (06-20-2013)
Old 06-20-2013, 04:46 PM   #234
Oc Ca
I'll have to find out exact. I'll get back to you guys
Old 06-30-2013, 10:24 PM   #235
Oc Ca
Ask for Boh. Paid 480.00 for the box and sub
The Following 2 Users Say Thank You to Oc Ca For This Useful Post:
KGFRS86 (07-03-2013), Pneub (07-03-2013)
Old 07-01-2013, 01:29 PM   #236
Chee-Hu
Chee-Hu's Avatar
Have you installed it? If so, how's the sound quality? TIA
Chee-Hu is offline   Reply With Quote
Old 07-01-2013, 01:46 PM   #237
Oc Ca
Sounds great
The Following User Says Thank You to Oc Ca For This Useful Post:
Chee-Hu (07-05-2013)
Old 07-03-2013, 02:44 PM   #238
DNAPoPo
GreddyBRZ meets GreddyFRS
DNAPoPo's Avatar
Drives: SSM Limited BRZ
Sounds great
Swing by our meet sometime! I would love to hear it if you get a chance as I am local. Thanks in advance!
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club
Tuesday Night Irvine DJ Meet Thread
Irvine FR-S & BRZ Car Meet(FaceBook)
DNAPoPo is offline   Reply With Quote
Wheel Directory: XXR 527 18x8.75 +35 Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 06-11-2016 03:40 PM
Stealth Bulbs? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 27 05-11-2016 09:06 PM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 05:34 AM
Stealth bulb for side marker? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 9 12-05-2012 07:02 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 10:45 PM
