Old 07-02-2013, 06:47 PM   #15
Carwhisperer
Drives: A lot of supercars.
Originally Posted by Element Tuning View Post
Yeah your problem is really 12 as that long hard left starves the siphon so your surge tank isn't being filled. The reason you feel it is because it takes time for the surge tank to empty....you're running what's left in there. The siphon just can't fill the surge back up fast enough by the time you hit 12.
The fix we do on the Subaru Impreza is to replace the siphon side of the tank with a fuel pump. This way you will keep the surge tank full much more aggressively.
The popping sound is the engine running lean and misfiring. You may need to be full at Button Willow. Next time start full and follow uo with us.
Holy shit. Ive had the same issue with my car and DI seals. 2 different DI's went out within a month of each other.
Carwhisperer is offline   Reply With Quote
Old 07-02-2013, 09:03 PM   #16
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
By the way I am running a pump on the siphon side on my FRS race car and I can run very low without fuel starvation now even with slicks and downforce.
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
Wayno (06-30-2015)
Old 11-20-2013, 04:35 PM   #17
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Can you provide a link to the post/part(s) required to fix this? I was out at the track this past weekend and kept running into the same issue... sweeper to the left with a transition to right and, boom, complete loss of power due to fuel starvation. Had all the nannies off. Definitely want to get the issue squared away before next track day. Thanks!
cobrabyte is offline   Reply With Quote
Old 06-30-2015, 02:45 AM   #18
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Bump. If it's a simple solution, what are the parts needed? thanks
Old 07-04-2015, 04:28 AM   #19
FRS Justin
Drives: 2013 Asphalt FRS
It's fuel starvation and I've been experiencing it when there is a long left to right transition. To the people that haven't experienced it, I say you're not going fast enough It's a problem with the saddle tank setup and siphon system. I only get it at one track with high gas levels so it's not a problem everywhere.
I agree fuel starvation and not only will it happen in corners it will on a hard launch too. One night at the drag strip it happen to us and about 4 out of 7 passes the car fell on its face going into second gear, I even had a half tank of fuel. I was pulling 1.17G's on the launch and the fuel system couldn't stand it. So it looks like 1G in any direction you are going to run into it.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-04-2015, 08:40 AM   #20
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Old thread but new issue for me. At least 3 times at Sebring, twice at T11 sweeping left and once at 7 the hairpin right I had the limiter kick in just under 6K. Backed off the gas and everything was fine again. This happened first 2 sessions on Sat and never again.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Engine cutting power after hard cornering... Video inside CSG Mike Engine, Exhaust, Transmission 4 08-21-2012 08:06 AM
engine power bill323 Scion FR-S / Toyota 86 GT86 General Forum 25 08-06-2012 02:39 PM
Casey Stoner high speed cornering at 1000fps tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 6 08-01-2011 04:20 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 05:49 PM
