Old 06-09-2013, 09:52 PM   #29
AznBRZer
Drives: 16 CBS WRX Limited
Originally Posted by Avo1789 View Post
I too, am having slight vibrations on bumpy parts of the road. Its not terrible, but i do notice it. I also did not over tighten the screws... any advice?
Update: I realized that the bracket is self tapping, and after another look it was indeed stripped. I'm about get another mounting kit and try again!
Any updates? I'm debating going back to the dealer to get the vibration taken care of if it's stripped, but I'm not sure if it'll make a difference.
AznBRZer is offline   Reply With Quote
Old 06-13-2013, 08:16 PM   #30
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
After my second install attempt, I still have the rattles! Someone who has installed the mirror without rattles needs to chime in. I thought I did everything right as far as not over tightening. The problem is that there is some movement in between the big black bracket and the windshield...
Avo1789 is offline   Reply With Quote
Old 06-16-2013, 03:00 PM   #31
Retro86
Retro86's Avatar
Drives: Awesome
Originally Posted by Longhorn248 View Post
The mirror will initially show a "C" rather than a compass direction. To calibrate, drive in a 360 circle under 5 mph until the mirror calibrates itself.
Finished install.
Post in the thread, or shoot me a PM if you have any questions.
calibrated!
[ame="https://www.youtube.com/watch?v=CpMQkNbNXRI&feature=youtube_gdata_player"]https://www.youtube.com/watch?v=CpMQkNbNXRI&feature=youtube_gdata_player[/ame]
Retro86 is offline   Reply With Quote
The Following User Says Thank You to Retro86 For This Useful Post:
jacobzking (06-30-2013)
Old 06-16-2013, 07:38 PM   #32
ts87
^^^^^ LOL LIKE!
ts87 is offline   Reply With Quote
Old 06-28-2013, 08:29 PM   #33
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
mirror adapter plate fix
I also thought I was careful not to over-tighten the two screws into the adapter plate, but mine didn't grab well either. I took it apart and it seemed to me like the adapter plate holes were not a good fit for the screws used. I tried some nuts on the screws and they seemed to be 1/2 inch long 8-32 (but they might also be a nearby metric equivalent). So, to fix my mirror rattle I simply bought some 1/2" flat-head 10-32 screws and a 10-32 tap at home depot (the tap came with a pilot drill bit that I didn't use). I used the tap to properly thread the holes first, then re-assembled using the bigger screws and ta-da, a nice firm grip to the plate. I will see if this permanently fixes the rattle: I expect it will.
DSPographer is offline   Reply With Quote
Old 06-29-2013, 02:16 AM   #34
delusional
B R Z
delusional's Avatar
Drives: BRZ 6MT Limited
the mirror actually fell off on me about 2 months ago. it all started with vibrations and kept getting worse and worse. went to the dealership and they fixed it right up. but seems to be happening again. slight vibrations as of now.
delusional is offline   Reply With Quote
Old 06-29-2013, 05:58 PM   #35
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Possible pics n drawings like a hot to?
Marcoscrdo is offline   Reply With Quote
Old 06-29-2013, 08:58 PM   #36
antlers
White Guy
antlers's Avatar
Drives: 2005 Subaru WRX STI
Im with delusional. My mirror fell off completely the other day. Tried re tightening them but they wouldn't grab. I ended up drilling out the holes with a #19 bit and tapping with a m5x80 tap. I also bought longer screws and put some nail polish on the threads before install. So far so good.
antlers is offline   Reply With Quote
Old 06-29-2013, 10:08 PM   #37
mistressmotorsports
Originally Posted by hostkiller View Post
Nice DIY write up OP! I will be doing it when my work is not so busy......
If you are looking for the mirror with homelink function you should be looking at this: http://www.subarugenuineparts.com/pr...oducts_id=1880
Does this part number come with the mounting adapter? Or if not, what is the part number that is needed to convert from a base mirror?
mistressmotorsports is offline   Reply With Quote
Old 06-30-2013, 09:13 AM   #38
Foobar
SLO NO MO
Foobar's Avatar
Comes with the mirror but if you need an extra or don't need the mirror, the part is usually under 10 bucks:
http://www.colonialsubaruparts.com/P...ode=H501SSA040
Sent from my Nexus 4 using Tapatalk 2
Old 06-30-2013, 05:33 PM   #39
Longhorn248
Hook 'em
Longhorn248's Avatar
Back to check in on this thread!
I'm actually in the same group as you guys, the mirror was vibrating while driving and actually started to rattle. I ended up replacing the two black screws that actually appeared to be slightly stripped. Hopefully this fixes the issue otherwise I'll be drilling and tapping the mounting plate as well.
Longhorn248 is offline   Reply With Quote
Old 07-01-2013, 02:24 PM   #40
Avo1789
Avo1789's Avatar
I noticed the problem with mines is that the black bracket itself is not tightly fitted onto the windshield. I'll try to post a video to show you guys. If you try moving the mirror slightly pay attention to the movement of the bracket...
Old 07-08-2013, 04:59 AM   #41
Colombo
Drives: '13 BRZ
I used this for a homelink mirror without a hitch. Thanks for the write up.
Colombo is offline   Reply With Quote
The Following User Says Thank You to Colombo For This Useful Post:
TommyFive (07-08-2013)
Old 07-08-2013, 05:34 AM   #42
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Only after rebuild a new thread (5mm x 0.8) and 2 new screws it sems all ok, but fitting isn't very fine on the mounting plate. I'll accomodate later.
Trap63 is offline   Reply With Quote
Installed Auto Dimming/Homelink mirror DEC1 Cosmetic Modification (Interior/Exterior/Lighting) 71 09-10-2020 10:46 AM
Fuse Location for Auto Dimming Mirror Harness tonytduc Scion FR-S / Toyota 86 GT86 General Forum 11 11-27-2013 09:46 AM
auto-dimming mirror white devil Cosmetic Modification (Interior/Exterior/Lighting) 5 10-05-2012 01:05 AM
Auto Dimming Homelink/Compass Mirror Part Number R0ME0 BRZ First-Gen (2012+) — General Topics 5 04-19-2012 01:19 PM
question about tinted windows with auto dimming mirror... Norcalmav23 BRZ First-Gen (2012+) — General Topics 13 04-06-2012 08:37 PM
