Old 12-25-2012, 07:55 PM   #1
Longhorn248
Hook 'em
Longhorn248's Avatar
DIY: Auto dimming rear view mirror install
Alright this is my first DIY, so if you think it sucks then write one yourself
This DIY is for a genuine Subaru auto dimming rear view mirror with directional compass included. I'm not 100% sure if this will also work with the homelink mirror, but I don't see what would really be any different other than additional pins in the connector.
If you're thinking of purchasing this and paying the dealer to install it STOP. It's incredibly easy, the directions are easy to understand, and now I'm giving you a bunch of pictures so you don't screw up.
This is everything that comes in the kit. You will also need a phillips head screw driver, a flat head screw driver, a 10mm wrench, and a T20 Torx driver.
Start by using a 10mm wrench to disconnect the negative side of the battery. I placed a thick piece of cardboard between the cables and battery to keep them separated.
Turn the mirror mount 90 degrees to the right and simply slide the mirror down and out of the retaining clip.
Using a flat head screw driver remove the retaining clip and discard. NOTE: I outlined in red where the retaining clip is since it was washed out with the camera flash.
Install the new retaining clip and then slide the mini mounting plate up under the clip until it stops.
Install the mounting adapter on top of the original mounting piece secured to the windshield. Secure this using a phillips head screw driver and the two provided screws. This should easily line up with the mini mounting plate installed in the previous step.
Using a flat head screw driver, gently pry down the over head light and then using your fingers pull down until it pops out of the hole. Be sure to pull from the side of the light closest to the rear of the car.
Connect the grey connector to the unused connector under the headliner. You may have to reach pretty far into the headliner to do this, but there should be a connector in there. Then thread the cable up over the edge of the headliner so it's hanging down by the windshield.
Connect the black connector to the back of the new mirror.
Slide the mirror onto the mounting adapter and secure using a T20 Torx driver.
Install the cable cover from the mounting adapter to the headliner leaving some cable for mirror adjustment.
Reattach your battery, then while holding a card over the sensor on the back of the mirror turn on the car. The mirror should dim, then remove the card and it should now lighten.
The mirror will initially show a "C" rather than a compass direction. To calibrate, drive in a 360 circle under 5 mph until the mirror calibrates itself.
Finished install.
Post in the thread, or shoot me a PM if you have any questions.
Longhorn248 is offline   Reply With Quote
The Following 13 Users Say Thank You to Longhorn248 For This Useful Post:
FiRStsc10n (06-29-2013), l0aded (01-29-2013), Lokutus (01-30-2013), Michael (04-11-2014), Myv (10-18-2013), normancw (12-25-2012), Optimus Prime (10-26-2013), Rokkinpo (12-27-2012), ScionFamily (02-07-2013), shaoster (01-22-2013), SkAsphalt (01-30-2013), YMAA (09-30-2013), zoomzoomers (09-04-2013)
Old 12-25-2012, 08:05 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
Great job !
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
Longhorn248 (12-26-2012)
Old 12-26-2012, 10:47 AM   #3
greighn
greighn's Avatar
Drives: Scion FR-S
Yes, great job! Does anyone know if our FR-S's have the wire in the headliner for this?
greighn is offline   Reply With Quote
The Following User Says Thank You to greighn For This Useful Post:
Old 12-26-2012, 01:55 PM   #4
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
yes i would really like to know if we have that connector hidden in there????????
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
Old 12-26-2012, 01:58 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I would imagine that the FR-S would have the wire but you can easily check. The light is really easy to remove..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-26-2012, 05:25 PM   #6
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
The connector is there. I've found it. It's taped up so you just have to cut or snap the tape to get the connector where it needs to be.
To the OP, where did you buy your mirror and for how much? As low as this car is, this is something that I need to do.
Thanks!
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
The Following User Says Thank You to FRSpdDmn For This Useful Post:
Old 12-26-2012, 06:52 PM   #7
Longhorn248
Hook 'em
Thanks!
The one on my car felt taped up inside the headliner as well, but the cable was still able to reach the mirror so I didn't worry about moving it.
It was actually a Christmas gift, but I'm 99% certain this is where it was purchased: http://www.subarugenuineparts.com/pr...oducts_id=1879
About $140.
The Following 2 Users Say Thank You to Longhorn248 For This Useful Post:
FRSpdDmn (12-27-2012), Rokkinpo (12-27-2012)
Old 01-19-2013, 02:34 PM   #8
Lokutus
Drives: Scion FR-S AT Asphalt
Thanks to OP! Bought the parts at the link above.
Instructions were awesome... Hardest part was pushing the connector cable through the inside of the dome light to the windshield. There's a plastic enclosure that you have to stretch a bit to get the connector head through it.
Compass calibration and home link setup was easy.
Lokutus is offline   Reply With Quote
Old 01-19-2013, 03:00 PM   #9
Squishy86
Squishy86's Avatar
Drives: Your Car
Requesting confirmation on the FRS being compatible with both the auto-dimming AND homelink set-up.
Squishy86 is offline   Reply With Quote
Old 01-19-2013, 11:08 PM   #10
Lokutus
Confirmed. I have a Scion FR-S and the part worked perfectly.
Old 01-22-2013, 10:01 AM   #11
shaoster
Drives: Toyota 86 GTS Man
Nice guide. Time to go shopping for that mirror.
shaoster is offline   Reply With Quote
Old 01-23-2013, 03:25 PM   #12
Imrac
Drives: 13 SWP BRZ Prem
FYI, the mounting adapter does not come with the kit unless it specifically states... Found that out the hard way after swinging by the local dealership and picking up a mirror. They wanted 10 dollars for the mounting adapter, after already paying 40 dollars more than I can get the entire kit online, I just returned it and will be ordering online.
Imrac is offline   Reply With Quote
Old 01-23-2013, 08:20 PM   #13
iiviiystyle
Drives: White out Fr-s
Guys is there a homelink button on this particular model? I just see a power button. I might do this mod and thanks for the DIY.
iiviiystyle is offline   Reply With Quote
Old 01-23-2013, 10:16 PM   #14
Lokutus
Yes, there are 3 home link buttons in addition to compass and on/off.
The compass led is red matching the dash gauge light.
Installed Auto Dimming/Homelink mirror DEC1 Cosmetic Modification (Interior/Exterior/Lighting) 71 09-10-2020 10:46 AM
Fuse Location for Auto Dimming Mirror Harness tonytduc Scion FR-S / Toyota 86 GT86 General Forum 11 11-27-2013 09:46 AM
auto-dimming mirror white devil Cosmetic Modification (Interior/Exterior/Lighting) 5 10-05-2012 01:05 AM
Auto Dimming Homelink/Compass Mirror Part Number R0ME0 BRZ First-Gen (2012+) — General Topics 5 04-19-2012 01:19 PM
question about tinted windows with auto dimming mirror... Norcalmav23 BRZ First-Gen (2012+) — General Topics 13 04-06-2012 08:37 PM
