go_a_way1
Old 06-26-2013, 04:43 PM   #1555
jshadeck
jshadeck's Avatar
Yea i bought 5mm spacers to throw on at the first site of rubbing. But if they didnt rub after the last 2000 miles the way i drive, they wont ever lol
jshadeck is offline   Reply With Quote
Old 06-28-2013, 05:55 PM   #1556
Drzdude
Drzdude's Avatar
Drives: 2014 Subaru Wrx
For Enkei RS05RR's running in 18x8.5 front and 18x9.5 back what offset and tire size is recommended? How much should the car be lowered front and back. Thanks!
18x8.5 +32 with 225/40/18
18x9.5 +39 with 255/35/18
with KW V3 coilovers ?
or like
18x8.5 +40 front with 225/40/18
18x9.5 +40 rear with 255/35/18
Drzdude is offline   Reply With Quote
Old 07-07-2013, 07:59 PM   #1557
AutismIsAKiller
Looking at the Volk TE37RT wheels I am going to buy them individually so I can use all of one size or stagger them if it's needed. I am also willing to used wheel spacers
of whatever size is needed. They are....
17x9.5 +40 offset
18x10 +44 offset
What size tires I am about 1.5 inch lowered and I don't mind stretching for them to fit?
AutismIsAKiller is offline   Reply With Quote
Old 07-09-2013, 06:30 PM   #1558
orod35
orod35's Avatar
Drives: silver 2013 scion frs
i just bought a set of 17x8 oz superleggera rims. et 35 all around. will this be ok on my frs? stock height. also how can i find out personally for futre reference
orod35 is offline   Reply With Quote
Old 07-09-2013, 07:01 PM   #1559
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Yes, it will be OK.
Future reference = read this thread and grab a measuring device and/or online calculator.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 07-09-2013, 07:05 PM   #1560
ill86
ill86's Avatar
Drives: iG FR-S
17x9.5 +40 offset
18x10 +44 offset
If you're buying wheels , buy the correct width / offset and skip the spacer.
Tires for 9.5" and 10" can be found by reading or searching this thread.
Old 07-09-2013, 07:08 PM   #1561
ill86
ill86's Avatar
Drives: iG FR-S
or like
You answered your own question. ^
For additional info please
Old 07-09-2013, 08:04 PM   #1562
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Why this thread isn't sticky anymore ?!
adprokid is offline   Reply With Quote
The Following 2 Users Say Thank You to adprokid For This Useful Post:
ill86 (07-09-2013), NorseLegend (07-09-2013)
Old 07-09-2013, 08:36 PM   #1563
loogs
Drives: on cruise control
Originally Posted by Lee358 View Post
So i put on my rpf1 17x9 +45 today... Is is safe that the tire is so close to the coil?..............
exactly what i have. its okay as long as its not touching. my coils arrive next week so i wont have to worry anymore.
plus, on full wheel lock, my rims hot the tie rod. you should have that same problem so keep the full wheel turn to a minimum
loogs is offline   Reply With Quote
Old 07-09-2013, 11:13 PM   #1564
mashal
DADA
mashal's Avatar
Drives: 2013
Will this be a flush fit? Running stock suspension just looking for a little fill.
Don't know much about tires and wheels
mashal is offline   Reply With Quote
Old 07-09-2013, 11:29 PM   #1565
NorseLegend
A Very Annoying Person
Drives: Subaru Impreza :( Hopefully BRZ
I'm pretty sure I've done my math right this time;
Work Meister SR1 Standard 5x100, 18x9.5 -20 w/ 255/35r18, all corners
Looking for about 2in/50mm poke in in back, little bit more is going to be up front, lowered half an inch, no more than an inch though.
Anyone know what that would be like?
NorseLegend is offline   Reply With Quote
Old 07-10-2013, 12:27 AM   #1566
djdnz
1337
Drives: 2013 BRZ WRB S/C
The wheels will be 13mm more flush than stock, but not "flush" To achieve a flush with these wheels look you will need a 10mm spacer in the front and 15mm in the back. The tires are very large for our cars, 5% error in your spedometer and higher effective gearing.
Stock green, your proposed setup orange (ignore the suspension in the picture, it is not reflective of our cars):
djdnz is offline   Reply With Quote
The Following 2 Users Say Thank You to djdnz For This Useful Post:
ill86 (07-10-2013), mashal (07-10-2013)
Old 07-10-2013, 12:52 AM   #1567
ill86
ill86's Avatar
Drives: iG FR-S
Wheel selection, OK. Will fill a bit but def not poke.
Tires included with wheels, bad selection for 86. Tire is too tall. 225/40 is a better choice.
The Following User Says Thank You to ill86 For This Useful Post:
mashal (07-10-2013)
Old 07-10-2013, 12:58 AM   #1568
ill86
ill86's Avatar
Drives: iG FR-S
9.5 -20
Rough estimate :
70mm-75mm front poke
50-60mm rear poke
NorseLegend (07-10-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
