Old 05-15-2013, 09:20 AM   #15
frslee
Just drive it
Drives: 13' FR-S
Originally Posted by smbstyle View Post
just to clarify; drilling IS required for SRP pedals, NOT required for Cusco.
Oops, thanks for clarifying it.
Yes, I have cusco one.
frslee is offline   Reply With Quote
Old 06-04-2013, 09:28 PM   #16
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Just wanted to post a HUGE thanks for this DIY; saved me a ton of time, and had no idea how easy the pedal removal was. Took a total of 2 minutes to take it out and 2 to put it back in.
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
Doborder (06-05-2013)
Old 06-24-2013, 01:20 PM   #17
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Good to hear positive feedback on the Cusco unit, just got mine.
I use the same technique for "heel toe", basically roll my foot over to the throttle to blip it, and am not a true heel-toer. I've had more control with brake and throttle pressure that way, and it's been working fine for several years of DE's and Club Racing.
I had the SRP pedals in my CTS-V, and they were nice, but I just did not like the idea of drilling anything, which is why I went with the Cusco piece. They both look very similar, but I think the SRP pedal actually has a more pronounced lip on the left side.
I tried the Cusco pedal, it sits too high for heel toeing on the track, stock position is perfect, hence i returned it and got SRP and cant be happier
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
Doborder (06-24-2013)
Old 06-24-2013, 07:03 PM   #18
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
SRP is awesome
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 06-24-2013, 07:27 PM   #19
oofie
Where did you guys order your srp pedals? Also, what needs to be drilled? The srp pedal?
oofie is offline   Reply With Quote
Old 06-24-2013, 07:57 PM   #20
OrbitalEllipses
Drives: Attitude
http://www.srpracing.com/cat-brz.cfm
The OEM pedals need to be drilled after you pop off the sport pedal covers. It's a bitch and a half.
oofie (06-24-2013)
Old 06-24-2013, 08:30 PM   #21
oofie
Thanks! I assumed the pedals installed right now are the base pedals, I haven't thought about them being just clipped/installed on top of the base pedals.
Old 08-27-2013, 02:23 AM   #22
Godzilla35
Drives: Nissan GT-R
question about the SRP and the Cusco gas pedals... how high do they sit with respect to the brakes? (when none of the pedals are depressed) About level or higher?
I like both so I'm trying to figure out which to get.
Godzilla35 is offline   Reply With Quote
Old 08-27-2013, 03:00 PM   #23
smbstyle
smbstyle's Avatar
They will both be the same; they both just cover the factory metal pedals. If you look at the level of the factory pedal, the gas pedal sits lower than the brake and clutch.
Old 08-27-2013, 05:48 PM   #24
emutcfut
Drives: 2013 Argento
They are not the same. The SRP requires removal of the factory metal cover, or at least that's how it is supposed to be installed. However, even with factory cover removed it will still be slightly higher than the factory cover as the SRP is thicker by about 2mm.
emutcfut is offline   Reply With Quote
Old 08-27-2013, 07:30 PM   #25
smbstyle
smbstyle's Avatar
Ok, let me clarify. NEITHER will be level or above the height of the brake or clutch pedal, as the gas pedal itself is significantly lower than the rest of the pedals.
Old 08-28-2013, 03:01 AM   #26
Godzilla35
Drives: Nissan GT-R
yeah, you didn't understand or answer my question
The SRP installs in PLACE of the stock pedal.
The CUSCO installs on TOP of the stock pedal.
I want to know what the final NET height of both pedals are because I want the one that is closest to being even with the brakes so I can heel-toe easier.
None of the options look the best (as they don't match stock), and they both seem like they have pros and cons. I like how the Cusco sits higher but I like how the SRP has a wider side.
Old 08-28-2013, 08:01 AM   #27
smbstyle
smbstyle's Avatar
Your question was "how high do they sit with respect to the brakes? (when none of the pedals are depressed) About level or higher?" - and I answered neither - the gas pedal sits significantly lower than the brake/clutch pedal.
The Cusco sits higher, but there is some room for play, so if you are wanting the gas pedal to be closer to the brake pedal, which the SRP pedal offers with the wide side, you can simply adjust the Cusco pedal off to the side. I liked that adjustability of the Cusco. I also did not like the idea of drilling the pedal. I had SRP pedals on my CTS-V and they were good, but it's nice to be able to adjust the pedal if I need to.
Godzilla35 (08-31-2013)
Old 08-29-2013, 04:01 AM   #28
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
After trying to install the cusco pedal for close to 30mins I gave up, logged in to this forum to look for installation tips....and found this thread. Went back to the car to try this method and finished the job in 15 mins. LoL.
Fizz is offline   Reply With Quote
Cusco Sports Accelerator Pedal Install + Review CrazyWookiee Cosmetic Modification (Interior/Exterior/Lighting) 25 03-27-2014 11:45 AM
Pedal Recommendation? swift996 Tracking / Autocross / HPDE / Drifting 24 04-09-2013 07:57 PM
Pedal adjustments supramkivtt2jz DIY (Do-It-Yourself) Guides 3 03-31-2013 05:56 AM
Gas pedal tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-22-2012 09:42 AM
JDM Gas Pedal for HeelToe dunphyjp Cosmetic Modification (Interior/Exterior/Lighting) 20 08-21-2012 01:57 PM
