Old 05-11-2013, 11:08 AM   #1
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
DIY SRP pedal install
This is a relatively simple install for those that want the SRP pedal for easier heel toe. I didn't find any DIY on how to remove the accelerator pedal from the car so I figure I contribute and write something up.
1. Get under the dash and you will find this---
The red circles are the two 10mm bolts you have to remove
Unattach the plug in the red square and then you can disconnect the entire accelerator pedal complex out of the car
The next part I did not take pictures because it is pretty self explanatory-
You use a screw driver to pull the tabs off OEM pedal cover (on the back of the pedal) and then you attach the new SRP pedal with two supplied screws
DONE!
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Last edited by Doborder; 05-11-2013 at 11:10 AM. Reason: spelling and language error
Doborder is offline   Reply With Quote
The Following 8 Users Say Thank You to Doborder For This Useful Post:
Chrisgalactic (11-01-2015), DocWalt (10-22-2015), Fizz (08-29-2013), LXXXV1 (03-04-2016), nofferman (05-03-2014), orthojoe (05-12-2013), ProjectD (06-19-2013), RehabJeff86 (06-24-2013)
Old 05-11-2013, 01:52 PM   #2
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Is it a worthwhile upgrade?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 05-11-2013, 06:07 PM   #3
Doborder
Godzilla Konvert
Doborder's Avatar
don't know yet, it hasn't made a huge difference on the street, but I will be at the track in a few weeks and report back
CO>CA Cartel
Old 05-13-2013, 03:12 AM   #4
MmmDieselFumes
MmmDieselFumes's Avatar
Drives: .
I bought the cusco one (basically same exact thing, but you retain your stock pedal, so it "raises" the pedal height slightly, which is kind of a nice thing). I really like these wider pedals. If you're like me and you are not any kind of contortionist, it's somewhat difficult to turn your foot 90º to do a true heel-to-toe maneuver, so you wide up doing more of a right-side-of-foot-to-big-toe. These pedals makes "heel-to-toe'ing" MUCH easier.
MmmDieselFumes is offline   Reply With Quote
Old 05-13-2013, 09:16 AM   #5
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Good to hear positive feedback on the Cusco unit, just got mine.
I use the same technique for "heel toe", basically roll my foot over to the throttle to blip it, and am not a true heel-toer. I've had more control with brake and throttle pressure that way, and it's been working fine for several years of DE's and Club Racing.
I had the SRP pedals in my CTS-V, and they were nice, but I just did not like the idea of drilling anything, which is why I went with the Cusco piece. They both look very similar, but I think the SRP pedal actually has a more pronounced lip on the left side.
smbstyle is offline   Reply With Quote
Old 05-13-2013, 09:18 AM   #6
frslee
Just drive it
Drives: 13' FR-S
Dang it. I didn't know you can disassemble the gas pedal... I stuck myself under the dash and tried to fit the cusco pedal. It was pain in the ass...
I think it's worth it if you're trying to easily heeltoe in this car. I'm still learning how to.. but it is a lot easier now to hit the gas pedal than before while braking.
frslee is offline   Reply With Quote
Old 05-13-2013, 02:34 PM   #7
smbstyle
smbstyle's Avatar
One question when removing and then installing the pedal - what are the factory torque specs for the 10mm bolts?
Old 05-13-2013, 02:37 PM   #8
OrbitalEllipses
Drives: Attitude
Got the matching set including the dead pedal. Cut out a bit too much carpet for that unfortunately...but screw Subaru for gluing the pedal to the carpet, that's stupid. Gas pedal is supremely useful, way easier to heel toe.
Gudentite! Hand tight, then just a little more...but don't gorilla it.
BRGLR (10-01-2017)
Old 05-14-2013, 06:58 AM   #9
mike2100
mike2100's Avatar
Drives: 23 BRZ
I've had my SRP pedals on since September and I love them. There's enough grip that you can heel toe in flip flops but not so much that you can't do it in boots. My feet don't ever slip, even when my shoes are soaking wet.
mike2100 is offline   Reply With Quote
Old 05-14-2013, 08:49 AM   #10
frslee
Just drive it
Drives: 13' FR-S
heeltoe is still a challenge for me.
Sent from my slushbox
Old 05-15-2013, 12:38 AM   #11
Doborder
Godzilla Konvert
Doborder's Avatar
That is why I posted the DIY
I'm hoping to save people some time under the dash
CO>CA Cartel
Old 05-15-2013, 01:08 AM   #12
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Drilling required though right? It's not that clear in your DIY.
Phaedrus29 is offline   Reply With Quote
Old 05-15-2013, 09:03 AM   #13
frslee
Just drive it
Drives: 13' FR-S
No drilling required. 2 brackets that are provided hold the new pedal and old pedal together.
Old 05-15-2013, 09:13 AM   #14
smbstyle
smbstyle's Avatar
just to clarify; drilling IS required for SRP pedals, NOT required for Cusco.
Cusco Sports Accelerator Pedal Install + Review CrazyWookiee Cosmetic Modification (Interior/Exterior/Lighting) 25 03-27-2014 11:45 AM
Pedal Recommendation? swift996 Tracking / Autocross / HPDE / Drifting 24 04-09-2013 07:57 PM
Pedal adjustments supramkivtt2jz DIY (Do-It-Yourself) Guides 3 03-31-2013 05:56 AM
Gas pedal tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-22-2012 09:42 AM
JDM Gas Pedal for HeelToe dunphyjp Cosmetic Modification (Interior/Exterior/Lighting) 20 08-21-2012 01:57 PM
