Old 06-23-2013, 11:48 PM   #99
angelm3
angelm3's Avatar
Had the car for 3 months and currently have 13k miles . Coolant is below the low mark .I hope there is a loose hose somewhere and not a headgasket issue .
angelm3 is offline   Reply With Quote
Old 06-24-2013, 12:03 AM   #100
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
You would figure that after all these years. They should of switched to metal headgaskets.
Muaddib is offline   Reply With Quote
Old 06-24-2013, 01:15 AM   #101
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
You also have to remember that coolant is 50% water and that system is not sealed. It is possible some of it evaporated.
Sent from my Q10
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Opie (06-25-2013)
Old 06-24-2013, 02:38 AM   #102
Dezoris
Dezoris's Avatar
Sent from my Q10
Thats something else for people to be aware of, if you are in warm climates in traffic and a lot of idle situations your coolant will hit 220ish on the stock radiator. Which puts you at the cusp of some evaporation of water. Get yourself some type of OBD2 tool and monitor your coolant temps. See where they peak. If you are seeing higher temps than 220F do a pressure test of your cooling system. Could be as simple as a small leak. Or even air in system, bad cap. Dont jump to worst case.
Old 06-24-2013, 02:41 AM   #103
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Mine was the same. I bought a jug of coolant and topped it off to about 1/4" above full mark back in April at 16000km and now have 28k and showing 1.25" lower than when I filled it up. The only thing that come to my mind is that the factory bleeding method to get the air out is suspect as this system is very similar to my old nissan 300zx turbo (Z31) and that was a bitch to bleed! The reason I suspect it to improper bleeding is that it hasn't moved since bleeding and I haven't had to top it off since either and if it were to be a head gasket I would think that the level would drop much faster.
Gords_zenith is offline   Reply With Quote
Old 06-24-2013, 03:44 AM   #104
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
First few months I had the coolant smell, at weird times.. Like a quick run to the store, but not a long run to work.. And other times after a hard run, but no smell just putting around town.. It was never consistent.. I'll be keeping a eye on this thread and checking coolant tomorrow... It's been hot here in Vegas, and while I check my oil regularly I haven't checked coolant... If it has been low I hope my services at the dealership have been filling it up properly
Gixxersixxerman is offline   Reply With Quote
Old 06-25-2013, 01:44 PM   #105
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Just wanted to let you guys know that I picked up the car this morning. I'll post the entire parts list later tonight.
Ill hold off giving any reviews of the car until I get some more miles on it, but I will say that I missed it dearly
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
vtmike (06-26-2013)
Old 06-25-2013, 01:54 PM   #106
xjohnx
Grip>Slip
xjohnx's Avatar
Nice! Did you ever see the blackbox data?
Old 06-25-2013, 04:34 PM   #107
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Nope. My paperwork also didn't say a thing about an overrev or goodwill work.
I'm going to search for my cable for the Techstream once I get home and see if I cab find where it would be. I need to update the TPMS sensor IDs anyway.
Besides that, I went for a drive on my lunch break. Maybe its my imagination, but it feels like it has more power above 4k rpms. But that might just be because I'm used to that pos Prius.
Parting out HERE
Old 06-25-2013, 04:43 PM   #108
Dezoris
Dezoris's Avatar
Given your issues I am sure it makes a big difference.
And I was stuck with a Prius and then Corolla, it makes you wonder how anyone could spend that much money on those cars. Absolutely as exciting as watching toilet overflow full of turds.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
civicdrivr (06-25-2013), Turkish (09-01-2013)
Old 06-25-2013, 04:51 PM   #109
xjohnx
Grip>Slip
xjohnx's Avatar
Nice. Interested in hearing what happened with the black box info/what kind of lip the service dept gave you.
Old 07-01-2013, 12:54 AM   #110
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Long overdue parts list:
110011 CYL HD SUBASSY (W/O ALL VLV)
1 SU003-00328 PMP AY-FUEL, H PRS
1 SU003-00342 PIPE AY-FUEL DLVY
1 SU003-00347 GSKT-FUEL PIPE
2 SU003-00290 GSKT-INT MANIF
1 SU003-00316 GSKT-THROT CHMBR
6 00279-0W201-01 OW20 BULK OIL-W
1 SU003-00311 FILTER
1 SU003-00115 HEAD ASSY-CYL LH
1 SU003-00099 GSKT-CYL HEAD, 2
1 SU003-00196 VALVE-INT
2 SU003-00278 ROCKER CP-VALVE
1 SU003-00182 CAMSHAFT CP-INT LH
1 SU003-00182 CAMSHAFT CP-EXH LH
1 SU003-04240 PIVOT-ROCKER ARM
1 SU003-00281 GSKT-ROCKER COVERLH
1 SU003-00282 COVER-VALVE ROC LH
1 SU003-04237 CARR AY-CAMSHAFT
1 SU003-00289 COVER-COLLECTOR
1 SU003-00221 SHIM-VALVE
1 SU003-00220 SHIM-VALVE
1 SU003-00222 SHIM-VALVE
1 00295-00103 FIPG OIL PAN
1 00272-GTBC1 GT SUPER LLC BLUE
002449 ENGINE OIL 11679 WT
The car feels great. One thing that I noticed though - below 4k rpms the car felt very sluggish. It had a very on/off feel to the powerband. I say felt because I figured out what the issue was yesterday. They replaced the little cover that goes on the intake manifold. The problem was that I had trimmed the cover for the vacuum line running to the AOS. The line was pinched due to the cover. Fifteen minutes of trimming/filing and its back to the way it was, and the car feels peppier below 4k now.
Parting out HERE
The Following 3 Users Say Thank You to civicdrivr For This Useful Post:
DylanFRS (07-03-2013), Lonewolf (07-01-2013), vgi (07-01-2013)
Old 07-03-2013, 10:20 AM   #111
Septic
Septic's Avatar
Drives: FRS Whiteout AT
To any of the posters besides Civicdrivr who were also experiencing low coolant levels, what was your outcomes? The coolant level on my FRS is low, and I am taking it to the dealer. Rather than just fill it up, I figured I would just take it in so that I have documentation in case anything arises later on.
@civicdrivr - thanks for all the info in this thread. Glad you have been reunited with your FRS. You have my sympathies of dealing with Priority service department; been there, done that.
Septic is offline   Reply With Quote
The Following User Says Thank You to Septic For This Useful Post:
civicdrivr (07-03-2013)
Old 07-03-2013, 10:24 AM   #112
OrbitalEllipses
Drives: Attitude
That can't be cheap. Can anyone run the numbers on the parts used in the repair of @civicdrivr's vehicle? I've often wondered what a new head would cost...
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
