Old 06-17-2013, 06:39 PM   #57
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by jakev9041 View Post
I'm a pilot and no pilot will EVER trust their fuel gauges, visual check is a must. Further, every tank has a certain unusable fuel quantity as in there is a certain volume of fuel remaining in the tank that cannot be used to supply the engine, airplane manufacturers have to publish these numbers in the pilot operating handbook, and some even put it in the brochure. Just look at this web site: http://www.diamondaircraft.com/aircraft/da42/specs.php
Fuel capacity, total / usable 79 gal / 76.4 gal
Cars are no different, but manufacturers have not ever published or made known the usable fuel, so a word to the wise: a certain % of the total fuel capacity of your fuel tank is unusable & to drill it in, any pilot who trusts a fuel gauge ought not to be a pilot.
I wasn't referring to fuel gauges. I was just referring to the general aviation idea that if you're unsure of your position, trust your gauges. Not necessarily fuel gauges.
DoomsdayJesus is offline   Reply With Quote
Old 06-17-2013, 06:44 PM   #58
DoomsdayJesus
Originally Posted by BlueDubbinTDI View Post
Mine comes on, I fill up, and its always 10.6 before the pump clicks. That's a shitload left so I feel you OP. Granted I've only filled up twice since Ive had her lol. 24 and 25mpg average :/
Your mileage will get a lot better after the engine break-in.
Originally Posted by RurumariGhost View Post
I fill up at 1/4. I worry about suspended particulates getting into the engine if i go much lower. Given I buy high quality gas and am probably being ocd, but better safe than stranded
That's why we have fuel filters.
Old 06-17-2013, 07:44 PM   #59
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Sarlacc View Post
That is a shame, I had thought they would design the fuel tank with high G-forces in mind.
Impossible for a street car, for packaging and weight distribution reasons.
Usually for a high-performance street car, there would be a dry sump oil pump but nothing special for fuel. No manufacturer would assume you to run aggressively on a near-empty tank...
-alex
Old 06-18-2013, 01:27 PM   #60
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Thought I would push the limits. My Torque App reading the OBD2 data stream said there was 2.2 gallons left when the low fuel light came on @ 410 miles. When I filled up @ 437.3, the OBD2 said 1.6 gallons remaining. Took 11.983 gallons with 2 clicks of the pump to fill it up.
Apparently, I need to use a few more rev's.....
ntron1 is offline   Reply With Quote
Old 06-18-2013, 02:15 PM   #61
jakev9041
jakev9041's Avatar
Drives: 2013 Subaru BRZ
@ Doomsday Jesus, modern day pilots entrust the go perfectly straight machine, aka the GPS! But I understand what you meant now.
jakev9041 is offline   Reply With Quote
Old 06-18-2013, 02:54 PM   #62
ntron1
Sarcastic Bastard
Originally Posted by Marchy View Post
flat roads must be nice lol
Change elevation by 700 feet twice every day and very little traffic. Some days I can make the 17.5 mile run to work and never touch the brakes or downshift to reduce speed. Neutral on the way down accelerating from 45 to 70 without touching the pedal. Much more being 47 and having a real go fast car to play with that struggles to get 17 mpg on a good day. The BRZ is just a casual daily driver.
Old 06-19-2013, 08:50 AM   #63
For those of you pushing this to the limit, you might want to pick up some of this from Woot today.
Of course, after reading the CAUTION below, I think I'd rather push my car than take a chance on this stuff.
Old 06-19-2013, 11:02 AM   #64
DeeezNuuuts83
Drives: 2006 Evo IX SE
For that price, you might as well just buy a little red tank with real gas.
DeeezNuuuts83 is offline   Reply With Quote
The Following User Says Thank You to DeeezNuuuts83 For This Useful Post:
Marchy (06-19-2013)
Old 06-20-2013, 07:27 AM   #65
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Ha...break in...since this is a lease I've decided to give the middle finger to the break in period and throttle it out probably every other day. She's got 900 miles on her. Should I still expect to see better mileage around the 2000 mark?
Old 06-20-2013, 11:27 AM   #66
BlueDubbinTDI
Shooting for a new low atm. Currently at 29.9mpg (automatic) on the avg clock halfway through the tank. Here's to hoping I havnt screwed the break in ability of this car lol. However I have seen some 21.8 fuely averages around the forums so atleast its not that bad.
Old 06-20-2013, 01:28 PM   #67
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
Is this early fuel light warning a Subaru thing? Of the 14 cars I've owned, I've never seen a fuel light go on so early either... only happens with my 04' WRX and my BRZ.
996garage is offline   Reply With Quote
Old 06-20-2013, 02:00 PM   #68
qoncept
qoncept's Avatar
The light on my 04 WRX didn't come on so ridiculous early. Or, at least, the gauge read nearly empty. Best I ever did was 375 on a tank.
qoncept is offline   Reply With Quote
Old 06-20-2013, 03:28 PM   #69
.. Should I still expect to see better mileage around the 2000 mark?
mines stayed about the same over nearly 5k miles,
I've documented my fuel usage in my Owner's Journal. I would say there hasn't been a significant increase over the near 20K miles I have on it, although the average has risen over time. In the first 3,000 miles I average right around 31.8, and in the next 17,000 miles I've averaged 32.5. Nearly all the driving has been straight commuter "stuff", and spirited road driving on occasion.
Marchy (06-20-2013), WolfpackS2k (06-21-2013)
Old 06-20-2013, 07:29 PM   #70
DoomsdayJesus
The Avg. MPG clock is pretty generous. My fuelly fill-ups show actual MPG at least 1-1.5 MPGs lower on a regular basis. I could actually adjust average MPG on my Outback with the easter egg menu, but I haven't seen anything on how to adjust it on my BRZ.
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 08:33 PM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 03:56 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
