| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#57 | |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
#58 | |
That's why we have fuel filters. |
#59 | |
Drives: 2005 Toyota Camry
Usually for a high-performance street car, there would be a dry sump oil pump but nothing special for fuel. No manufacturer would assume you to run aggressively on a near-empty tank... -alex |
#60 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Thought I would push the limits. My Torque App reading the OBD2 data stream said there was 2.2 gallons left when the low fuel light came on @ 410 miles. When I filled up @ 437.3, the OBD2 said 1.6 gallons remaining. Took 11.983 gallons with 2 clicks of the pump to fill it up.
Apparently, I need to use a few more rev's..... |
#61 |
Drives: 2013 Subaru BRZ
@ Doomsday Jesus, modern day pilots entrust the go perfectly straight machine, aka the GPS! But I understand what you meant now.
#62 |
Sarcastic Bastard
Change elevation by 700 feet twice every day and very little traffic. Some days I can make the 17.5 mile run to work and never touch the brakes or downshift to reduce speed. Neutral on the way down accelerating from 45 to 70 without touching the pedal. Much more being 47 and having a real go fast car to play with that struggles to get 17 mpg on a good day. The BRZ is just a casual daily driver.
#63 |
For those of you pushing this to the limit, you might want to pick up some of this from Woot today.
![]() Of course, after reading the CAUTION below, I think I'd rather push my car than take a chance on this stuff.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#64 |
Drives: 2006 Evo IX SE
For that price, you might as well just buy a little red tank with real gas.
| The Following User Says Thank You to DeeezNuuuts83 For This Useful Post: | Marchy (06-19-2013) |
#65 |
Drives: 2013 FR-S, 2012 MCS
Ha...break in...since this is a lease I've decided to give the middle finger to the break in period and throttle it out probably every other day. She's got 900 miles on her. Should I still expect to see better mileage around the 2000 mark?
#66 |
Shooting for a new low atm. Currently at 29.9mpg (automatic) on the avg clock halfway through the tank. Here's to hoping I havnt screwed the break in ability of this car lol. However I have seen some 21.8 fuely averages around the forums so atleast its not that bad.
#67 |
Drives: 03' NSX & 13' BRZ 6spd Ltd white
Is this early fuel light warning a Subaru thing? Of the 14 cars I've owned, I've never seen a fuel light go on so early either... only happens with my 04' WRX and my BRZ.
#68 |
The light on my 04 WRX didn't come on so ridiculous early. Or, at least, the gauge read nearly empty. Best I ever did was 375 on a tank.
#69 | |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Marchy (06-20-2013), WolfpackS2k (06-21-2013) |
#70 | |
| Low Fuel Light. | Draco-REX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 64 | 11-07-2015 08:33 PM |
| Will installing sub frame and tranny mount bushings cause premature wear? | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-16-2013 03:56 PM |
| Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) | R2RO | Issues | Warranty | Recalls / TSB | 3 | 02-04-2013 10:06 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
