Old 06-17-2013, 10:37 AM   #15
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
My Cosworth fit great and doesn't use any oil.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 06-18-2013, 12:09 PM   #16
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Oil is only an issue for people who f*** up
The Following User Says Thank You to SkAsphalt For This Useful Post:
supramkivtt2jz (06-18-2013)
Old 06-18-2013, 12:31 PM   #17
qoncept
qoncept's Avatar
Arguably the TRD filter has the best fitment since it uses the same format of gasket/seal as the stock paper filter - the hard layered indented areas that line up exactly with the airbox's plastic. (Versus silicone gaskets that don't have an exact of fit)
OT, but what is "sound changer" ?
qoncept is offline   Reply With Quote
Old 06-18-2013, 01:17 PM   #18
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You know how there is a sound tube that runs inside of the cabin? Inside of that tube is a piece that basically shapes the air rushing through it and creates the sound you hear. The sound changer replaces the piece inside of the tube and offers you 3 alternatives
Mute
Louder
Loudest
Old 06-18-2013, 02:58 PM   #19
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Don't waste your money on the sound charger, they simply have different thickness of foam in the different colors for noise levels.
Red tube has no foam, so if you want a louder sound in your car simply remove your OEM charger (Grey) and pull the foam out.
Gives a better sound in the cabin.
The TRD DIF is extremely expensive with no real gains.
Afe momentum pro dry - great filter
Works oiled filter - good
k&N - good
Zeta stage 2 - great
I've dyno tested the above all give 4 to 6 whp gains.
Ryan86 is offline   Reply With Quote
Old 06-18-2013, 03:21 PM   #20
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
K&N Filter here.
Old 06-18-2013, 03:35 PM   #21
ramiram1984
Drives: 2016 STi DGM
Can always go stock
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 06-18-2013, 03:51 PM   #22
ST185RC
Drives: White Out FR-S
I went with things on the intake side that has been dyno'd to show at least some gain without adversly affecting what it would have been if the stock part was in their place. Both Perrin Drop-in and intake duct have been pretty much direct fit, less hesitation, idle dip is less apparent, and the annoying intake sound is now gone and my car lost about 1.2lbs off the front. Before shipping and taxes, it came out to under $180. Pretty good for getting rid of some idling issues while improving pretty much over the whole rev-range, if you ask me.
TRD sound changer to me was a joke, really. 0 performance gain, you can have the same effect of all 3 changes with a little know-how (gut your stock tube for the red one from the DIY on this forum, or just plug the sound hole for the effects of the blue one, green one is somewhere in between). Like someone already said in this thread, don't do it.
ST185RC is offline   Reply With Quote
Old 06-18-2013, 10:03 PM   #23
lxsedan
Drives: 2013 BRZ SWP
dropped the k&n in tonight, pretty straight forward, no problem with fit.
lxsedan is offline   Reply With Quote
The Following User Says Thank You to lxsedan For This Useful Post:
SkAsphalt (06-19-2013)
Old 06-19-2013, 02:17 AM   #24
8686
8686's Avatar
Drives: 86
Did you feel any gain from it? I am thinking to buy one
8686 is offline   Reply With Quote
Old 06-19-2013, 02:43 PM   #25
Black Tire
Black Tire's Avatar
I really did feel that I gained power by installing this filter. That said, I also installed a Perrin Inlet Tube at the same time, and the stock filter was quite dirty. The first photo shows the stock filter in white complete with captured insect. The second shows the Cosworth filter and Perrin Inlet Tube ready to be installed. The dates are off because I took out the air filter and inlet tube when I installed a Perrin Lightweight Crank Pulley, when I took the second photo. The Cosworth filter with the Perrin Inlet Tube seemed to increase power even before installing the Perrin Lightweight Crank Pulley.
Old 06-22-2013, 03:30 AM   #26
Chef
Culinary Touge Artist
Chef's Avatar
Drives: Ultramarine FR-S
I got the aFe dry drop in filter.
Chef is offline   Reply With Quote
The Best Drop in Air Filter? FT-86- Engine, Exhaust, Transmission 46 06-05-2014 07:54 AM
DIY drop-in filter? aceangel Engine, Exhaust, Transmission 18 04-25-2013 10:42 AM
Trd drop in filter Vino Engine, Exhaust, Bolt-Ons 3 04-14-2013 11:08 AM
best drop in air filter? Elgancho Engine, Exhaust, Transmission 15 04-09-2013 11:59 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
