Old 06-10-2013, 11:09 AM   #1
BlackyRose
Drives: 2013 Raven FR-S
Which Drop-in filter fits the best?
There are so many threads on drop in filters. There are even threads that show how to dis-assemble the airbox for install. Overall, which filter fits the easiest and the best without having to cut/force it in the airbox?
BlackyRose is offline   Reply With Quote
Old 06-10-2013, 11:20 AM   #2
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
The only one I have tried is the Perrin. And yes, it had to be forced into the airbox. Other than that it's a great filter.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 06-10-2013, 11:26 AM   #3
Opposed
Drives: 2013 Asphalt FR-S
Any are fine. I can't see how would could actually feel the difference between drop in filters...I have a $350 intake that I can't fell any difference over stock to be honest.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 06-10-2013, 11:28 AM   #4
Veritas
Drives: Sterling Silver Subaru BRZ Limited
Last week, I installed the K&N drop-in filter for the first time. Considering that I didn't have previous experience, I'd say it fit really well. You definitely just have to read online instructions and make sure it aligns correctly
Veritas is offline   Reply With Quote
Old 06-10-2013, 11:35 AM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Arguably the TRD filter has the best fitment since it uses the same format of gasket/seal as the stock paper filter - the hard layered indented areas that line up exactly with the airbox's plastic. (Versus silicone gaskets that don't have an exact of fit)
Originally Posted by humfrz
I'm old and lazy
Old 06-10-2013, 03:04 PM   #6
JDMrolla
JDMrolla's Avatar
Drives: AE86 and white FRS
Blitz
JDMrolla is offline   Reply With Quote
Old 06-10-2013, 07:52 PM   #7
siXXtoes
Ohh Snap
siXXtoes's Avatar
Drives: Argento FR-S
my Zeta works great
P&L EL headers and over-pipe, ARK Grip front-pipe and cat-back exhaust, Delicious Tune, Rays Gram Lights 57DR 17x9 +35 wrapped in Bridgestone RE11a's
SoCal SD 86 Club Admin
https://www.facebook.com/groups/socalsd86/
siXXtoes is offline   Reply With Quote
Old 06-14-2013, 08:33 PM   #8
FRS-Jonathan
FRS-Jonathan's Avatar
Drives: 2013 6spd manual Scion FRS
My HKS dropped right in
FRS-Jonathan is offline   Reply With Quote
Old 06-15-2013, 07:10 AM   #9
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Get a trd for a matrix 05, fits perfect, and built like a kn or afe, its not a paper filter
Silverdub is offline   Reply With Quote
Old 06-16-2013, 12:16 PM   #10
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
uhh, wait -- so you have to oil up a TRD filter as well ?
ive seen some issue with the oil getting on some sensors - I was hoping just to use a paper drop-in if possible --- I thought the TRD was like that...
am I wrong ? thanks guys.
rikdrt1 is offline   Reply With Quote
Old 06-16-2013, 06:34 PM   #11
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I never oiled it
Old 06-17-2013, 12:29 AM   #12
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
K&N took 1 minute to fit. jesus drop in filters are NOT a scary idea and take little effort to install.
Old 06-17-2013, 03:32 AM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, oiling is not a problem.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-17-2013, 05:57 AM   #14
roddy
roddy's Avatar
Drives: '13 Ultramarine
The JDM TRD filter (as in the picture above) is built like the stock filter and doesn't require oil. The TRD filter that we get over here is an oiled cotton gauze filter much like a K&N. The filter comes pre-oiled and will not need oil until it is cleaned. The sensor problem you speak of happens when the filter is over oiled and installed (more or less) dripping wet. This can cause the MAF sensor to become fouled. Even if this did happen, the fix is easy...simply remove the sensor, spray with electric contact cleaner, dry, and re-install. Good to go.
The Best Drop in Air Filter? FT-86- Engine, Exhaust, Transmission 46 06-05-2014 07:54 AM
DIY drop-in filter? aceangel Engine, Exhaust, Transmission 18 04-25-2013 10:42 AM
Trd drop in filter Vino Engine, Exhaust, Bolt-Ons 3 04-14-2013 11:08 AM
best drop in air filter? Elgancho Engine, Exhaust, Transmission 15 04-09-2013 11:59 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
