#743 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
I wonder if it is due to the range of FM frequencies we use here that the inline amp may be required - then again, don't know if it is going to work yet! Tuesday is the day.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#744 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Got the unit woot. Now to sort out how to wire it all up, don't suppose someone has a write up of what they did?
Do only two of the three connectors on the harness line up? Mines four pins short on the largest white connector Sent from my Nexus 4 using Tapatalk 2
Nolan
#745 |
Which unit?
#746 |
T7019A
@2forme Is the root files for this unit the same as your first post? I'm on page 20 trying to find them Sent from my Nexus 4 using Tapatalk 2
Nolan
#747 | |
Drives: Brz WRB - Europe LHD
I don't understand the meanings of "brake wire" and "reverse" wire on T7019A harness. I have a rear camera with RCA (OK) red/black 12v/ground cable: where to wire? and near RCA plug (on each side) a short wire (red):where to wire them? My rear camera comes with poor install sheet. Maybe this..... http://www.ft86club.com/forums/showp...&postcount=111 "cameras have dual taps on their power wire -- one near the camera and another near the HU. Rydeen's intention was that you power the camera by tapping your reverse lights wire (near the camera). The second lead would be available to provide the reverse gear signal to an aftermarket HU or monitor screen. But you can simply use the lead near the HU to power the camera (and insulate the lead near the camera)."
#748 |
Drives: Pegasus GTS86
Has anyone had a look at what is involved in changing the leds to red on the 7019?
Sent from my GT-I9505 using Tapatalk 2 |
#749 | |
)...I saw a wide mainboard (horizontal) and a panel board. I think that the job isn't complex...on front panel.
#750 | |
Drives: Toyota 86 GTS
http://www.carboncarsystems.com.au/m...20Tutorial.pdf Sent from my HTC_PN071 using Tapatalk 2 |
#751 |
@pheoxs I rooted my device using the same files @2forme posted. The root files are in post 1 on page 1 mate. Just follow his instructions EXCEPT you need to use a micro SD card and put it into the LEFT micro SD slot as the right one has nothing in it and you'll lose the micro SD card inside the unit like I did!
To wire it in just plug the stock plugs into the back of the unit. You only really need the main power one and antenna adapter (buy separately) plugged in with the blue antenna 12V wire connected to power from the adapter too. I have plugged in the two plugs with all the RCA plugs and iPod connection in as well but other than the iPod connector I have nothing connected to the RCAs etc but have left them plugged in for safe keeping.
| The Following User Says Thank You to nzer For This Useful Post: | Trap63 (06-15-2013) |
#752 | |
Nolan
#753 |
You did better than me, I left mine inside!
#755 |
LOL.
Got a friend that is an electronics whiz, @Tech, that may look at swapping out the green LEDs for me. If he does I'll make sure I get lots of photos as that will definitely void the warranty!!!
#756 | |
![]() Sent from my HTC One using Tapatalk 2 |
| Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) | JPxM0Dz | Canada Classifieds | 2 | 01-19-2013 11:51 PM |
| chinese man sues wife for being ugly: wins | wrxgoose | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 11-07-2012 10:58 AM |
| Counterfeit Chinese Airbags | @Art_Mighty | Other Vehicles & General Automotive Discussions | 11 | 11-03-2012 03:20 AM |
| JDM Vs. KnockOff | SIRvive | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 03-05-2012 05:32 PM |
| Gang of Chinese kick, yell, and drag a little caucasian boy | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 34 | 01-20-2012 10:47 PM |
