go_a_way1
Old 06-10-2013, 02:18 PM   #1499
jshadeck
jshadeck's Avatar
Originally Posted by Verge View Post
do you have any pics so i can see how they fill out??
They poke. Especially in the front. And they are very close to the front spring and perch (if u drop and camber, good chance ud hit)
^ red arrow is pointing to the spring perch, pic taken from below/behind front wheel
jshadeck is offline   Reply With Quote
The Following User Says Thank You to jshadeck For This Useful Post:
Verge (06-11-2013)
Old 06-11-2013, 11:27 AM   #1500
-mos-
Drives: GTS86
Hi, can someone tell me if the be below will sit reasonably flush with a 1 - 1.5' drop.
Front - 18x8 ET40
Rear - 18x8 ET35
235 x 40 all round.
Cheers..
-mos- is offline   Reply With Quote
Old 06-11-2013, 04:38 PM   #1501
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Hello, I'm getting swift springs with 1" drop on front and rear.
My wheel size will be 18/8 +45 front and 18/9 +42 rear
I'm looking for meaty setup: 235/40 front and 265/35
Will they fit? Thanks I hope it does not rub too. Please quote me when replying my post. Thanks
hanabie is offline   Reply With Quote
Old 06-12-2013, 11:20 AM   #1502
p4png
Drives: frs
Hi, Sorry if this is a dumb question but I've tried searching but just not sure. I'm looking at Enkei Kojin 18x8 ET40 and my car is completely stock. I've seen someone do 17x8 ET40 but I don't know if the rim size matter or if the spokes will touch the brake... Also, tirerack has this for frs but the offset is 45. So I'm not too sure. Thanks for the help.
p4png is offline   Reply With Quote
Old 06-12-2013, 02:07 PM   #1503
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Front - 18x8 ET40
Rear - 18x8 ET35
235 x 40 all round.
Cheers..
Yes.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 06-12-2013, 02:08 PM   #1504
ill86
ill86's Avatar
Drives: iG FR-S
Yep. They will fit.
Old 06-12-2013, 02:09 PM   #1505
ill86
ill86's Avatar
Drives: iG FR-S
Yes. Easily fit.
The Following User Says Thank You to ill86 For This Useful Post:
p4png (06-13-2013)
Old 06-12-2013, 02:10 PM   #1506
ill86
ill86's Avatar
Drives: iG FR-S
does anyone know if WORK Kiwami CR Ultimate 5x100 18x9.5 +38 will fit on stock suspension? i wont be getting coilovers for at least 6 months so need to find out if stock suspension will work.
Dangerously close.
Verge (06-12-2013)
Old 06-12-2013, 05:13 PM   #1507
Verge
Verge's Avatar
Drives: 2013 Scion FRS
Originally Posted by ill86 View Post
Dangerously close.
decided not to do it and go a different direction lol
Verge is offline   Reply With Quote
Old 06-12-2013, 05:58 PM   #1508
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Folks, be sure to check out the wheel fitment chart in the stickies at the top of this subforum.
Lots of these setups are already documented in there, or close enough. I mean, if you see an offset higher than yours and one that's lower and they are both confirmed to work...yours will probably work, too.
You don't even have to read the whole sticky, just look at the chart and there are links to threads where people have done this or that wheel/offset/tire.
Of course, there are always differences here and there, but I keep seeing really conservative setups being posted up here for confirmation. Not a big deal for someone to reply "yep that works" but isn't it nice to not have to wait on someone else for an answer?
Of course, I highly recommend starting a thread or replying to that sticky if you can confirm a setup that's not already on that chart. Just helps it grow for the next guy/gal looking for answers.
That's all. Back to your regularly scheduled thread.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 06-12-2013, 10:00 PM   #1509
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
I'm thinking of getting Eibach Sportlines for my BRZ. I will be getting 18x8.5 +44 in the front and 18x9.5 +44 in the rear with 245/40/18 all around. Will I have problems in the rear at all?
ihaskrayon is offline   Reply With Quote
Old 06-14-2013, 12:36 PM   #1510
phloozy
phloozy's Avatar
Drives: Scion FR-S
I am not sure if I want to go wider in the rear or not. Here are my choices, I could use help. I will be running Eibach Sportlines for a 1.4 drop
18x9.5 +40 all around with 245/35 (too much front poke?)
or
18x8.5 +35 front with 225/40 and 18x9.5 +40 rear with 255/35 (not flush?)
Please help i'm very new to wheels/tires and doing as much research as possible.
phloozy is offline   Reply With Quote
Old 06-14-2013, 02:05 PM   #1511
jshadeck
jshadeck's Avatar
or
Please read back in this thread, hell even within the last 10 posts... It was stated by 2 of us and i provided pics, that a 9.5 +38 is close to suspension, so a 9.5 +40 will be even closer.
However, first u need to decide if u want staggered or not. Then decide fitment.
ill86 (06-16-2013)
Old 06-14-2013, 02:32 PM   #1512
phloozy
phloozy's Avatar
Drives: Scion FR-S
Thanks I just took a look now. you are talking about 9.5 in the front correct? I guess to be safe I will go staggered.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
