go_a_way1
Old 05-10-2013, 02:19 PM   #1303
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by xero404 View Post
guess i'll try to stretch the 225 rival then lol. wish there were more grippy tire choices in 235. or just bite the bullet and get coils already.
Seems to me that 9" width is perfect for this car when running a square setup.
If you're going to be close to the strut, you can use the lower strut mount hole for a camber bolt. It won't be a huge different, but will get you a teeny bit more clearance than running a camber bolt in the top hole. I think the top one is 16mm and the lower one is 14mm. Best to look it up, my brain is fuzzy.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-10-2013, 06:35 PM   #1304
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
There are plenty of tires in 235 that are "grippy".
Are you tracking the vehicle or just need street rubber?
For example- Yokohama S-Drive or AD-08.
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
xero404 (05-10-2013)
Old 05-10-2013, 06:54 PM   #1305
xero404
Completely forgot about the AD08s and the Michelin PSS for 235s. As long as they make it to my 14mi commute to the train station i think the stretch is fine. Plans are for light track duty once a quarter and autocross once a month.
Talking to autocross people get me into the sticky meaty mood while the ricer in me just want to stretch . I think the AD08 will get me into the best of both worlds. Thanks for the heads up!
xero404 is offline   Reply With Quote
The Following User Says Thank You to xero404 For This Useful Post:
ill86 (05-10-2013)
Old 05-10-2013, 07:02 PM   #1306
ill86
ill86's Avatar
Drives: iG FR-S
You're welcome. I've used several sets of ad-08 on my Z33 and ZZT231.
I just installed 255/40 S-Drives in the 86 and they are amazingly good on track. Perfect street and light duty track tire. A little better wear than ad-08. But not as sticky and temperature (track) resistant.
Old 05-11-2013, 01:34 AM   #1307
Touge86
Touge86's Avatar
Drives: 2013 DGM BRZ M/T
So, still can't decide what size rims I want to go.. I'm looking to get the most outta my new shoes performance wise.. both on track and street/canyons.
My options are:
17x8.0 +37
17x8.5 +48
18x8.0 +45
18x8.5 +33
18x9.5 +40
Any advice? Appreciated..
Edit: Also am looking to lower my car by and inch or more on some coilovers, does a higher offset increase the chance that it'll rub?
Touge86 is offline   Reply With Quote
Old 05-11-2013, 01:37 AM   #1308
jshadeck
jshadeck's Avatar
Will this fit? (width, offset and tire size Qs)
My options are:
17x8.0 +37
17x8.5 +48
18x8.0 +45
18x8.5 +33
18x9.5 +40
If you are looking for 100% performance only, id suggest 17" and since its only 1/2" diff just pick the lighter/stronger ones as either will run the same sizes of tires for the most part
Higher offset will suck the wheels further into the wheel well, more clearance to the fender, less clearance to the suspension
jshadeck is offline   Reply With Quote
The Following User Says Thank You to jshadeck For This Useful Post:
Touge86 (05-11-2013)
Old 05-11-2013, 01:49 AM   #1309
jshadeck
jshadeck's Avatar
the 17x8.0 and 17x8.5 will run the same size tire? and what does the difference in offset do? just more poke, right?
8 +37 and 8.5 +48 should both fit ABOUT the same, +48 is the stock offset, so picture it this way, the 8.5 adds .75" to the inside and outside of the stock rim evenly. The 8 37 would poke out of the wheel well 11mm but would be .25" less width on each side (11mm is .4") so... From the stock wheel, poke out .4" plus .5", basically the same outside poke, but would leave more clearance inside ( which isnt necessary as either of these is not tight fit)
And yes, tread width and wheel width can be mix matched. U can easily run anything from a 225 through a 255 (or even more or less if u want) on either rim (if u look at tire specs they usually suggest a range for fitment, such as specs for a 225 tire might say "fits 6.5 to 8 inch rims") there are reasons not to go tooo far in either extreme, but 8/8.5 u wont be limited cause of that half inch
Old 05-11-2013, 01:56 AM   #1310
jshadeck
jshadeck's Avatar
Btw though, the 18x9.5 would allow a wider tread option, so if u plan on adding power and u think ull need >255 or so, u MIGHT consider these
But. A 9.5 +40 will be kinda close to the front suspension (stock) and will poke past the fender a tad, so lowering much ud need to pull the fenders or run camber id think
Old 05-11-2013, 10:00 AM   #1311
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Sorry but this is incorrect. The offset is relative to only the inside of the wheel, so the extra 1.5 will be added to the outside. Inner clearance is exactly the same.
Slick is offline   Reply With Quote
Old 05-11-2013, 11:04 AM   #1312
jshadeck
jshadeck's Avatar
Wrong. Offset is the distance from the face of the mounting hub to the center of the rim
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old 05-11-2013, 11:10 AM   #1313
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Would this fit? Front - 18x9.5 +28, Rear - 18x9.5 +15?
JackSmiley is offline   Reply With Quote
Old 05-11-2013, 11:14 AM   #1314
jshadeck
jshadeck's Avatar
That would poke, alot. My 9.5 +38s poke a fair amount, those would be almost another inch poked out of the fenders than mine. I hope u have the rb kit
JackSmiley (05-11-2013)
Old 05-11-2013, 11:19 AM   #1315
jshadeck
jshadeck's Avatar
Old 05-11-2013, 11:39 AM   #1316
JackSmiley
JackSmiley's Avatar
not gonna do RB til i go FI. so the FRS Project Calculator isnt accurate huh?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
