#29 |
Lots of STi guys who do a lot of tracking end up using surge tanks. I used one of these in my 02 WRX so I could run almost no gas in the tank. You would be surprised what a small tank like that can do even for long sweepers.
http://www.hyperflow.com.au/index.ph...d=hyast-wrx001 Long sweepers do cause more issues. I think Phil @ Element Tuning (who seems to have disappeared) was getting minor fuel starvation last year even in a stock car when he first started running his car with big slicks. |
#30 | ||||
I Love custom Turbo kits
Drives: Limited BRZ
http://www.ft86club.com/forums/showp...1&postcount=17 And some posts down: Quote:
#31 |
Drives: Perrin/VORTECH Supercharger TestBRZ
for me its long sweeper on throttle-->[brake]greater than 110 degree left[accel]-----> straightway that seems to be a good test model
I considered a surge tank but its really a band aid, and becomes a smaller and smaller bandaid as you make more and more power and add more and more G's, if you dont fix the problem with the main tanks, the surge is kinda temporary fix and yes, I agree 100% it could well be the solution to- this all needs to be tested I dont think this is the same tank in this car as in STI |
#32 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#33 | |
Foam deteriorates, I wouldn't use it in anything but an actual fuel cell which you can take it out easily. And don't use it with E85. I've heard of guys using wiffle balls with success. Not sure you could put those in the tank though.
#34 |
Drives: 2013 Subaru BR-Z Limited
@Huehuecoyotl I appreciate your in depth testing on not only this issue but many others ranging from pentosin to Vortech. I know my question is off topic so I apologize..you mention that you're not satisfied until you have it running like a fine tuned watch on the track. I grew up racing dirt bikes and shifter karts so I can appreciate that but in my old age, dyno tuning for 93 and E85 is about as far as I go. So my question lies within your lap times. I'm sure you frequent a local track and I know you started tracking the car when it was almost new. Where were your lap times then and where are they now after FI, suspension, etc? Just curious to see the improvement in time on a track in comparison to the mods you have completed. If you have another thread discussing that already, link me up.
Thanks again, Chad
#35 | |
Even tuning for 93 or e85, what we do to say we're done on a dyno and what we learn on the track after many logs allows my tuner to build a file for me(and likely you and other customers) thats made using real world data, in a far from ideal set of conditions vs a dyno room. Up till this point it has run like a watch, so I didnt have this issue with the my lower power levels, so each time I go up in power I try to track in between, for my own benefit,again. As I dont have the baselines you want on hand, what we will do is take my wifes car which is a bone stock BRZ with a TRD drop in, vs mine 'well built' on a day I'm renting a transponder(I dont when I am just tuning,testing and logging) I want to share that data too! |
#36 | |
Drives: Black frs project
@ brp 13 ccw coming off the riverside into the bus stop @ chuckwalla going through the huge lefthander (3-4 i think). all big FLAT lefthanders no issues in the banking at all. All can be managed by a short shift to 6th but the power is not there...then |
#37 | |
#38 |
its the piping flo and return rates not the pump itself
I too am consistent @ FIR West before the straight when doing CCW and @ amp after the 180turn CW-both Flat as a pancake My bet is a pump wont cure this...I will be game to see what Dynosty is up to but they been making power, not sure if they have the same G force induced stuff we're seeing in only the flat in same conditions of use, different pumps, different tunes, different fuels, this isnt a fuel supply issue thats pump limited, its limited by return rate I think |
| The Following User Says Thank You to Huehuecoyotl For This Useful Post: | robispec (04-17-2013) |
#39 | |
e85 ftw lol but will need to at chuckwalla... or have a 2 second margin! car only makes about 12 more WHP but the temps are all cooler! Last edited by robispec; 04-17-2013 at 05:15 PM. |
#40 |
Don't have the budget to run 100
#41 | ||
2013 Subaru BRZ
#42 | |
| The Following User Says Thank You to Huehuecoyotl For This Useful Post: | orthojoe (04-17-2013) |
| Left hand drive GT86 exist? | hotmetal | Scion FR-S / Toyota 86 GT86 General Forum | 62 | 01-04-2018 02:22 AM |
| Fuel Starvation issues? YAY OR NAY? | track_warrior | Tracking / Autocross / HPDE / Drifting | 23 | 10-22-2013 12:19 PM |
| AT holding 2nd gear to high revs during a long left turn | EK_Golfer | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 03-01-2013 11:35 AM |
| Left hand drive cars in Australia | Kevstra | AUSTRALIA | 27 | 01-24-2013 08:30 PM |
| Fuel Starvation | feldy | Tracking / Autocross / HPDE / Drifting | 1 | 06-09-2012 11:14 AM |
