Old 04-17-2013, 08:17 AM   #1
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Left Hand turn fuel starvation on WOT
I'm getting what feels like hiccup fuel starvation in/just after fast left hand turns followed by WOT, like 110 degree corners right after a sweeper into a straight, never when on a full tank, but consistently at 3/4 tank and below. Wondering if anyone else is having this. I dont recall it being NA, so I will be asking folks who track that go FI, cant replicate on the street, just not the same traction as rcomps on a track. LMK. I have this on two different tracks different fuel sources. Can make it happen on a cold pump.
I'm FI at 10psi on OE fuel system. I know folks will say go to higher output pump, but not sure thats diagnosing problem.
Oil temps were high both full tank and not full tank, both times it happened. Went to gas station filled up car with car and oil way hot, and no issues, so its not an hot oil temp driven event
Can not replicate with street tires
Must have R-comps, must be driving at 10/10s
WOT thru sweeper --->STAND ON BRAKES--->downshift--->Turn FEVERISHLY(feathering throttle to rotate rear end at break neck speed) --->then milliseconds right after apex go full WOT and go wide onto a straightway(INSERT hiccup)WOT at top of 2nd gear,sometimes event at beginning of 3rd, then this straight goes to 4th then another silly hard left, but no sweeper before it. and it doesnt happen there at all.
feels just like what happens when you make too fast a turn on a low fuel tank
I wasnt logging fuel rail pressure, next time...
anyone else?
Huehuecoyotl is offline   Reply With Quote
Old 04-17-2013, 10:10 AM   #2
orthojoe
Welcome to the world of aftermarket power.
Sounds like fuel starvation to me. Your fuel pressure log would confirm. Larger fuel pump isn't the solution. A surge tank is. Been there. Done that. It's a slippery slope because there are other potential issues with running a surge tank.
Thanks for posting the info. This is valuable information to know.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 04-17-2013, 10:19 AM   #3
ft_sjo
Drives: GT86
If it's not doing it when the tank is full then it should be fairly obvious what's happening.
You're going to need either an improved swirl pot in the tank, or look at an external one.
Old 04-17-2013, 10:20 AM   #4
HunterGreene
Hail Magnet
HunterGreene's Avatar
Ok, I have a really stupid question, because I think I already know the answer (Which is: yes, they are)--you have the nannies off, right?
Old 04-17-2013, 10:31 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i think you need more NOS.
Old 04-17-2013, 11:16 AM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
10/10ths at a DE eh. I would like to see an EcuTek log file to diagnose what the issue is.
Old 04-17-2013, 11:36 AM   #7
Fuel starvation.
@robispec has a similar problem on left sweepers; he's on E85. I've discussed the issue extensively with him but will let him go into more detail. We have some speculation on the causes and fixes, and he'll be testing it shortly.
Do you have ANY datalog from when you get the starve? I may be able to extrapolate something from it.
Off topic, but this can be fixed via proper suspension balance (front/rear rates) and/or a 2 way LSD. You can alter it with sways, damping changes, or tire pressures, but those are all bandaid fixes.
Old 04-17-2013, 12:00 PM   #8
Huehuecoyotl
Fuel starvation.
csg, the car handling fine,TOO fine perhaps
... its a fast corner in both cases...pm me your email address and I send you logfile to look at
something needs to be done to allow the 'bowl to fill faster
I'm not babying it when it happens
Old 04-17-2013, 12:22 PM   #9
mike @t counterspacegarage d0t com
Old 04-17-2013, 12:40 PM   #10
robispec
Drives: Black frs project
I think the car is not returning enough fuel to keep scavaging the fuel sloshed to the off side tank sump. the stock system does this using an "eductor" pump aka running extra fuel (the fuel exccess or the return fuel) by a nozzel set at an angle to the liquide flow wich pulls the fuel out of the rt sump and into the fuel pump antistarvation can.
robispec is offline   Reply With Quote
Old 04-17-2013, 12:43 PM   #11
ftc~brz
Done
Drives: WRB BRZ
saw something on sprtsguys build about the tube inside the pump being pinched? just throwing it out there...
ftc~brz is offline   Reply With Quote
Old 04-17-2013, 12:47 PM   #12
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
I wonder if this is what killed the fuel supply to my car on a skid pad last month. I was also going left. Car wouldn't restart for 5 hours.
Scott
naikaidriver is offline   Reply With Quote
Old 04-17-2013, 12:49 PM   #13
CBR600RR
Drives: Raven Black
have you considered getting fuel foam? it is more known in the morotcycle racing world to keep the fuel from sloshing back and forth and upsetting the bike in switchback turns.
teh foam comes in little cubes and is simply stuffed into the fuel tank right up to the brim. it displaces next to no volume of the tank too.
I am guessing that since it isn't happening to you at a full tank that fuel sloch is your problem, and since you are FI your pump is consuming fuel so fast that it is getting air when the fuel sloshes.
Old 04-17-2013, 12:52 PM   #14
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
That reminds me why I changed my mind about wanting a Cayman: too many reports of engines blowing up in left turns. Search '987.1 oiling issues'.
Most are on the track w/ sticky tires but some are off-ramps etc on the street.
jack43 is offline   Reply With Quote
Left hand drive GT86 exist? hotmetal Scion FR-S / Toyota 86 GT86 General Forum 62 01-04-2018 01:22 AM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 11:19 AM
AT holding 2nd gear to high revs during a long left turn EK_Golfer Scion FR-S / Toyota 86 GT86 General Forum 9 03-01-2013 10:35 AM
Left hand drive cars in Australia Kevstra AUSTRALIA 27 01-24-2013 07:30 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 10:14 AM
