Old 04-17-2013, 03:58 PM   #29
xwd
Lots of STi guys who do a lot of tracking end up using surge tanks. I used one of these in my 02 WRX so I could run almost no gas in the tank. You would be surprised what a small tank like that can do even for long sweepers.
http://www.hyperflow.com.au/index.ph...d=hyast-wrx001
Long sweepers do cause more issues. I think Phil @ Element Tuning (who seems to have disappeared) was getting minor fuel starvation last year even in a stock car when he first started running his car with big slicks.
Old 04-17-2013, 04:01 PM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
No thanks on a higher mounted aftermarket fuel cell. I would rather see a new fuel pump bucket solution. I know you guys are not the only two out there running 10/10ths on track. Has anyone else had this issue?
Originally Posted by Huehuecoyotl View Post
its going to be in stock location...rip out old tanks, put in new
by now you know, I go to try and test out whomever's solutions I like* and I think I am liking this alot
See below:
Originally Posted by Dustin@Dynosty View Post
And just FYI, we are finishing up the last little pieces to our fuel system that will allow you to drop this monster in the tank and not have to worry about double o-rings or running out of fuel
http://www.ft86club.com/forums/showp...1&postcount=17
And some posts down:
If the machine shop stays on target, we will have the production version pieces in middle of next week and we will do a final test to verify nothing changed from the prototypes and then we will release to the public. This will be full feed and return lines with rails, regulator and fuel lines for those really looking to push the limits with out having to run an additional external tank.
Old 04-17-2013, 04:05 PM   #31
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
for me its long sweeper on throttle-->[brake]greater than 110 degree left[accel]-----> straightway that seems to be a good test model
I considered a surge tank but its really a band aid, and becomes a smaller and smaller bandaid as you make more and more power and add more and more G's, if you dont fix the problem with the main tanks, the surge is kinda temporary fix and yes, I agree 100% it could well be the solution to- this all needs to be tested
I dont think this is the same tank in this car as in STI
Huehuecoyotl is offline   Reply With Quote
Old 04-17-2013, 04:06 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by FRSPirate View Post
Yeah, heard about the fuel cell foam in bikes as well.
Quick search has a lot of people raving about this stuff:
http://www.fuelsafe.com/store/foam-baffling.html
I have read that you may need to replace it more frequently and that you may need to run another filter but it may be related to cheaper foam. Everything else i have read, the guys linked above are still the first choice in foam baffling. Most complaints are about the cheap stuff from Jegs and Summit.
I would suspect all foam will deteriorate eventually. We've had it happen in fuel cells using good foam, but it took several years to do so.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-17-2013, 04:12 PM   #33
xwd
I'm sure it's not the same tank. I've seen guys in WRX/STi's use them in cars pushing 600WHP and other cars even more. That's using a setup with say dual Bosch 044 pumps. It's a solution if you don't feel like using an actual fuel cell.
Foam deteriorates, I wouldn't use it in anything but an actual fuel cell which you can take it out easily. And don't use it with E85. I've heard of guys using wiffle balls with success. Not sure you could put those in the tank though.
Old 04-17-2013, 04:14 PM   #34
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
@Huehuecoyotl I appreciate your in depth testing on not only this issue but many others ranging from pentosin to Vortech. I know my question is off topic so I apologize..you mention that you're not satisfied until you have it running like a fine tuned watch on the track. I grew up racing dirt bikes and shifter karts so I can appreciate that but in my old age, dyno tuning for 93 and E85 is about as far as I go. So my question lies within your lap times. I'm sure you frequent a local track and I know you started tracking the car when it was almost new. Where were your lap times then and where are they now after FI, suspension, etc? Just curious to see the improvement in time on a track in comparison to the mods you have completed. If you have another thread discussing that already, link me up.
Thanks again,
Chad
chadstyle is offline   Reply With Quote
Old 04-17-2013, 04:22 PM   #35
Huehuecoyotl
Thanks again,
Chad
Youre very welcome, I do the testing for myself, but know its a community service too.
Even tuning for 93 or e85, what we do to say we're done on a dyno and what we learn on the track after many logs allows my tuner to build a file for me(and likely you and other customers) thats made using real world data, in a far from ideal set of conditions vs a dyno room.
Up till this point it has run like a watch, so I didnt have this issue with the my lower power levels, so each time I go up in power I try to track in between, for my own benefit,again.
As I dont have the baselines you want on hand, what we will do is take my wifes car which is a bone stock BRZ with a TRD drop in, vs mine 'well built' on a day I'm renting a transponder(I dont when I am just tuning,testing and logging) I want to share that data too!
Old 04-17-2013, 04:26 PM   #36
robispec
Drives: Black frs project
I believe the issue is from their respective cars having higher rates of consumption (boost in one case, E85 in the other).
I'm honestly surprised that a stockish car has starvation issues. We ran at ACS with no issue, even with the gas light on (14 degree banked turn, sustained for over 10 seconds, nearly 2G lateral)
@ acs I starve in the rock garden before the straight
@ brp 13 ccw coming off the riverside into the bus stop
@ chuckwalla going through the huge lefthander (3-4 i think).
all big FLAT lefthanders no issues in the banking at all.
All can be managed by a short shift to 6th but the power is not there...then
robispec is offline   Reply With Quote
Old 04-17-2013, 04:29 PM   #37
CSG Mike
CSG Mike's Avatar
We should see if the aftermarket pump still has the issue when you're running a 91/100 octane map... or have you already done this?
Old 04-17-2013, 04:35 PM   #38
Huehuecoyotl
its the piping flo and return rates not the pump itself
I too am consistent @ FIR West before the straight when doing CCW and @ amp after the 180turn CW-both Flat as a pancake
My bet is a pump wont cure this...I will be game to see what Dynosty is up to but they been making power, not sure if they have the same G force induced stuff we're seeing in only the flat in same conditions of use, different pumps, different tunes, different fuels, this isnt a fuel supply issue thats pump limited, its limited by return rate I think
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
robispec (04-17-2013)
Old 04-17-2013, 04:49 PM   #39
robispec
don't run 91 at the track...lol
e85 ftw lol
but will need to at chuckwalla... or have a 2 second margin! car only makes about 12 more WHP but the temps are all cooler!
Old 04-17-2013, 04:55 PM   #40
CSG Mike
CSG Mike's Avatar
Don't have the budget to run 100
Old 04-17-2013, 05:24 PM   #41
orthojoe
Originally Posted by jack43 View Post
That reminds me why I changed my mind about wanting a Cayman: too many reports of engines blowing up in left turns. Search '987.1 oiling issues'.
Most are on the track w/ sticky tires but some are off-ramps etc on the street.
Those oiling issues were fixed with the 9A1 DFI engines. Yes, it was a problem if you were running serious rubber. The 987.2s do not have oiling issues. I have datalogs to prove it.
those of you who have no clue what this is, go spend a bunch of time on the track and you will see this thing rear its ugly head, its systemic, not build specific
this will be something that anyone and everyone who tracks, as your skills and build increase, you will all need.
What makes you say this? While it is a design flaw in the fuel system, I think the reason you are running into problems is a) increased fuel consumption rate due to the supercharger you are running, and b) R comps pulling much higher Gs. These problems can also be track specific. Some track configurations cause problems, and some dont
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 04-17-2013, 05:54 PM   #42
Huehuecoyotl
Youre absolutely correct, I thought it but didnt write it , I meant anyone going for higher flo rates or FI plus track will see this- Robispec gets this with his NA e85 setup with aftermarket pump, so its nothing to do with Vortech, and anyone who draws extended fuel demand on the oe plumbing will see this ON THE TRACK, vortech pulls fuel thru the entire band, but I would bet a million bucks other FI cars, and other high fuel demand tuned NA cars, like Robi;'s will see this. I know Perrin has reports from one of his clients too, same thing, so its not just my build. Sorry for the mistyped thought, will go fix it
orthojoe (04-17-2013)
Left hand drive GT86 exist? hotmetal Scion FR-S / Toyota 86 GT86 General Forum 62 01-04-2018 02:22 AM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 12:19 PM
AT holding 2nd gear to high revs during a long left turn EK_Golfer Scion FR-S / Toyota 86 GT86 General Forum 9 03-01-2013 11:35 AM
Left hand drive cars in Australia Kevstra AUSTRALIA 27 01-24-2013 08:30 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 11:14 AM
