Old 04-01-2013, 08:21 AM   #113
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Well, similarly, Perrins oil hoses come with one clamp, I add a 2nd for my peace of mind @ the track, its your car, if your modding it, I think you should have an eye on all thats being done
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Mr.Jay (04-01-2013)
Old 04-01-2013, 09:09 AM   #114
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Originally Posted by Huehuecoyotl View Post
I couldnt PAY for work at a shop where they really could have sourced a hose clamp at under $1 each...just saying, best practices...
You really have an issue with zip ties? I think they work great for clamping hoses, and you will be hard pressed to find a shop that doesn't use them.
It is the shops that use NO CLAMPS on hosing that have the real problem. I have seen people lose motors because shops us no hose clamping at all, lets say on wastegate lines for instance.
No Limit Motorsport is offline   Reply With Quote
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
mad_sb (04-01-2013)
Old 04-01-2013, 09:23 AM   #115
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by cf6mech View Post
Running lower cr 9 to 1 and 18 psi boost, looks like a head gasket blew out....waiting for verdict,....white smoke out tail pipe coolant low.
Wait did you blow your motor too?
industrial is offline   Reply With Quote
Old 04-01-2013, 09:39 AM   #116
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Originally Posted by Noob4Life View Post
If this is true I hope that they find that they installed it wrong and caused the problem. I'd be afraid of them saying it was the tune that caused the issue and therefore they're not at fault.
Good luck and subscribed!
They're more than likely to say that it was the tune and not their mistake.
TRD_07 is offline   Reply With Quote
Old 04-01-2013, 09:40 AM   #117
TRD_07
TRD_07's Avatar
Dang man sorry to here this happened to you.
Old 04-01-2013, 09:45 AM   #118
skatery1989
Drives: BRZ Limited
Don't think so he just likes to say how bad the FA20 is from what I remember from other threads.
skatery1989 is offline   Reply With Quote
Old 04-01-2013, 09:51 AM   #119
2forme
Considering this is the first blown motor thread I've seen from FI.... and it doesn't even appear to be the motor, or FI kit's fault... I'd say he's really stretching to try and say the FA20 sucks LOL.
Old 04-01-2013, 09:57 AM   #120
Huehuecoyotl
I doubt he took his fa20 apart and laid it out on a bench cause he doesnt like the motor. I gather he was playing and popped it too, but is taking it to the next level with his rebuild. I've exchanged PMs with him, and he is on point, doesnt seem to want to deal with the web BS and so doesnt really share his build...seems like anice guy otherwise
The Following 2 Users Say Thank You to Huehuecoyotl For This Useful Post:
industrial (04-01-2013), SkullWorks (04-01-2013)
Old 04-01-2013, 10:25 AM   #121
Visconti
Drives: 05 STi
Originally Posted by GTerran View Post
The stock BRZ/FRS computer is the same out of the GT-R with all the same data points that are associated with a twin turbo car...
wouldn't mind a tuner confirming this.
Not even close.
Visconti is offline   Reply With Quote
The Following 15 Users Say Thank You to Visconti For This Useful Post:
2forme (04-01-2013), adamls2 (05-13-2013), akuhei (04-01-2013), baldolera (04-01-2013), ftc~brz (04-23-2013), Huehuecoyotl (04-01-2013), mad_sb (04-01-2013), naikaidriver (04-01-2013), NorCalRider (04-03-2013), RedAlert (04-01-2013), Silverdub (04-01-2013), Sportsguy83 (04-01-2013), Tim_Asphalt_FRS (04-01-2013), tripjammer (04-15-2013), Tye300 (04-05-2013)
Old 04-01-2013, 12:35 PM   #122
cf6mech
Drives: FRS Silver LS1 swapped.
As of right now blown head gasket is my guess, since the shop that did the short block build stands behind it, letting them check it out....will keep everyone posted.....you guys talking to me about not liking the FA20,...totally not true.
cf6mech is offline   Reply With Quote
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
2forme (04-01-2013), Huehuecoyotl (04-01-2013)
Old 04-01-2013, 02:59 PM   #123
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
My race car is built with zip ties and duct tape. I have zero issues with zipties on stuff like that.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
jamesm (04-01-2013), King Tut (04-02-2013), No Limit Motorsport (04-01-2013)
Old 04-01-2013, 03:19 PM   #124
mad_sb
Drives: 2013 Asphalt FR-S
Dont be mistaken..30 psi on the basemap would put a hole in the block.
8psi boost limiter would have saved this motor.
I was gonna say... Over boost alone can bend rods etc assuming there is no detonation as a result of the over boost... add a little bit of detonation to the mix (a gt 30 can easily make enough boost to go well beyond the limits of 93 on 12.5:1 motor) and you have a nice grenade sitting between the fenders.
Old 04-01-2013, 03:20 PM   #125
Huehuecoyotl
I dont like them under the hood on hoses that can become boost pressurized
Old 04-01-2013, 03:25 PM   #126
mad_sb
So long as you use them in the right place... vacuum lines on barbed fittings.. you should never have an issue at reasonable boost... if in doubt give em the old pull test.
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 04:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 10:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 09:24 PM
