go_a_way1
Old 01-04-2013, 06:04 PM   #785
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
I run 215/40 on 8.5. Mild stretch and looks good. 225 will work too
Jesse is offline   Reply With Quote
Old 01-04-2013, 11:09 PM   #786
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Smile Rays Volk TE37's
Question: does anyone know if these wheels would fit on the OEM 17" tyres:
17 x 8.0 (5 x 100) + 38?
The stock tyres are: 215/45/R17
Thanks
yomchi1989 is offline   Reply With Quote
Old 01-04-2013, 11:11 PM   #787
ayau
Drives: Some rust bucket
Yes they will.
The Following User Says Thank You to ayau For This Useful Post:
yomchi1989 (01-04-2013)
Old 01-04-2013, 11:12 PM   #788
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Yes! 8 fits on 215s
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
Old 01-09-2013, 10:13 AM   #789
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Sent as PM...
Originally Posted by Jtymay92
How would some 18x8.5/9.5 Rota Grid - Flat Black (5x100/e44F/e38R/73)
On a 225/40/18 front and 255/35/18 fit and look. I plan on lowering with coilovers but only for the ride height so I don't have to have much camber cause it will be a daily driver and I don't want to ruin my tires.
Old 01-09-2013, 02:07 PM   #790
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by DarrenDriven View Post
Sent as PM...
Good fitment.
ill86 is offline   Reply With Quote
Old 01-10-2013, 01:25 PM   #791
DC-FRS
Drives: Whiteout FR-S
Anybody know if a 18x8.75 +20 all the way around will fit? Any major poking? Tires would be 225/40/18. Also, would it fit if dropped 1". Thanks!
DC-FRS is offline   Reply With Quote
Old 01-10-2013, 02:20 PM   #792
ill86
ill86's Avatar
Drives: iG FR-S
Agressive front fitment. Almost an inch outside the fenders up front. Would need 2+ degrees of negative camber.
The Following User Says Thank You to ill86 For This Useful Post:
DC-FRS (01-10-2013)
Old 01-10-2013, 03:34 PM   #793
BadLuckZN6
BadLuckZN6's Avatar
Drives: GT86
Work Meister S1 R, I'm thinking 18x9.5 the largest id want to go. What offset to still have decent ammount of dish and no fitment issues?
BadLuckZN6 is offline   Reply With Quote
Old 01-10-2013, 05:17 PM   #794
DC-FRS
Thanks! How about +33 or +35?
Old 01-10-2013, 05:34 PM   #795
ill86
ill86's Avatar
Drives: iG FR-S
You're welcome.
8.75 +35 is a better front fitment.
Old 01-10-2013, 05:39 PM   #796
ill86
ill86's Avatar
Drives: iG FR-S
What reasoning brought you a 9.5" wide wheel at all four corners?
My best advice for your particular question is to study what fits, what doesn't fit and then go from there. Your situation dictates that you decide what works best for you.
While fitment can be a science. It's also personal preference.
Old 01-10-2013, 05:59 PM   #797
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Hey guys,
Finally settled on some XXR 530s in 18/8.75/+33 (square setup).
Just shopping around for some tyres. Other than personal preference, is there an ideal size tyre to fit these wheels? I want to go as wide as possible. I'm also planning on lowering about 1".
white_knight is offline   Reply With Quote
Old 01-10-2013, 06:09 PM   #798
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by white_knight View Post
Hey guys,
245/35 or
255/35
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
