go_a_way1
Old 11-04-2012, 01:10 PM   #225
ironchef
ironchef's Avatar
Drives: GLI
Originally Posted by ill86 View Post
So much wheel width, so little tire..
To each their own.
255 is too little for that width?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
ironchef is offline   Reply With Quote
Old 11-04-2012, 01:15 PM   #226
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Nah, it's not that bad. Mild stretch.
255-285mm on 9.5".
Keep in mind the increased weight of a 9.5 vs 8.5, as well as tire weight increase. If you don't care then no worries.
Fwiw, i run a 255 on a 9.5" TE37 on the front of my Z33.
I am just seeing a trend of wide wheels/tires on 86's. Just busting some balls. It's all good.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 11-04-2012, 01:18 PM   #227
ironchef
ironchef's Avatar
Drives: GLI
255-285mm on 9.5".
Performance is the number one goal. I just really liked the look of the 18s.
Also looking at 17x9 +35 instead. 255 good for that though?
Old 11-04-2012, 01:26 PM   #228
ill86
ill86's Avatar
Drives: iG FR-S
I editted to add more info. Please re-read.
255 on 17x9 is perfect imo.
Keep weight in mind as to not potentially ruin the feel of the car. It's always a tradeoff between weight and grip. I tend to lean more towards the extra grip & take the weight penalty.
If weight is truly important get a stickier tire in 215 and mount it on a 7" wide wheel.
Check the specs on the tire/wheel you want to run. Report back with weight.
Old 11-04-2012, 01:29 PM   #229
Mo707
Mo707's Avatar
Can someone help me here?
Should the offset of the front tires be more than the back?
or the other way around? And will these wheels fit with the stock hight and if i lowered the car an inch (maybe a little more?)
http://www.elementwheels.com/proddet...188gmdr3118gm#
Mo707 is offline   Reply With Quote
Old 11-04-2012, 01:40 PM   #230
ironchef
ironchef's Avatar
Drives: GLI
Well the combo of 17x9 RPF1s and say 245 or 255 Hankook Ventus RS3 or Dunlop Star Spec equal about the same wheel/tire weight as stock, but with an additional 2 inches of rim width .
Old 11-04-2012, 01:55 PM   #231
ill86
ill86's Avatar
Drives: iG FR-S
Show me (us) the numbers.
Ps i agree with you.. Just want others to learn so we don't have to repeat.
Where i was going with this:
Rpf1 in 17x7 or 17x8 weighs less than 17x9.
D1 star spec in 215/xx weighs less than 245/xx or 255/xx.
In other words if you REALLY cared about weight...
Of course extra grip doesn't hurt. And wider does look better.
peace
Old 11-04-2012, 03:24 PM   #232
ironchef
ironchef's Avatar
Drives: GLI
peace
I guess that brings up the point of where is the break-even between weight and grip?
In the case of the RPF1/Star Specs
17x8 according to TR weighs 15.6 lbs
17x9 based on research around the internets weighs 15.9 lbs
Assuming 225 for the 17x8, the Star Specs weigh 26 lbs
Assuming 255 for the 17x9, the Star Specs weigh 28 lbs
17x8 total = 41.6 lbs
17x9 total = 43.6 lbs
Stock I believe is ~41 lbs or so.
Compared to stock both of the alternatives should be faster on a track.
Compared to each other, will the 2 lb increase per corner contribute to a slower laptime even though there is more grip?
Obviously this is getting into the nitty gritty, but now I'm curious.
Old 11-04-2012, 03:38 PM   #233
ironchef
ironchef's Avatar
Drives: GLI
Follow up question.
Why would a +45 be better for handling vs a +35? If a +35 pushes out the wheels further giving the car a wider track, isn't that better for grip?
Old 11-04-2012, 04:06 PM   #234
ill86
ill86's Avatar
Drives: iG FR-S
Follow up question.
Yes, wider is better.
Replying to your previous post next.
Old 11-04-2012, 04:11 PM   #235
ill86
ill86's Avatar
Drives: iG FR-S
I guess that brings up the point of where is the break-even <snip>
Excellent question.
In my professional opinion ,grip is more important in your case.
Here is a link to read:
http://hpwizard.com/rotational-inertia.html#answers
Old 11-04-2012, 04:40 PM   #236
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
drag wheels
hey im kinda a noob with tires and wheels what size of tires would you need to get for a drag dr-31 17x8
would P245/45ZR17 95W work? or would if be to big?
any help will get a thanks!
kendalldwhite is offline   Reply With Quote
Old 11-04-2012, 05:22 PM   #237
#87
I usually post drunk
#87's Avatar
#87 is offline   Reply With Quote
The Following User Says Thank You to #87 For This Useful Post:
kendalldwhite (11-04-2012)
Old 11-04-2012, 05:50 PM   #238
ironchef
ironchef's Avatar
Drives: GLI
Why does everyone always recommend the narrower offsets then? Many times on this forum alone I've seen that kind of recommendation.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
