| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#225 |
Drives: GLI
#226 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
255-285mm on 9.5". Keep in mind the increased weight of a 9.5 vs 8.5, as well as tire weight increase. If you don't care then no worries. ![]() Fwiw, i run a 255 on a 9.5" TE37 on the front of my Z33. I am just seeing a trend of wide wheels/tires on 86's. Just busting some balls. It's all good.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#227 | |
Drives: GLI
Also looking at 17x9 +35 instead. 255 good for that though? Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 |
#228 | |
Drives: iG FR-S
I editted to add more info. Please re-read. ![]() 255 on 17x9 is perfect imo. Keep weight in mind as to not potentially ruin the feel of the car. It's always a tradeoff between weight and grip. I tend to lean more towards the extra grip & take the weight penalty. If weight is truly important get a stickier tire in 215 and mount it on a 7" wide wheel. Check the specs on the tire/wheel you want to run. Report back with weight.
#229 |
Can someone help me here?
Should the offset of the front tires be more than the back? or the other way around? And will these wheels fit with the stock hight and if i lowered the car an inch (maybe a little more?) http://www.elementwheels.com/proddet...188gmdr3118gm# Last edited by Mo707; 11-05-2012 at 01:08 AM. |
#230 | |
Drives: GLI
#231 | |
Drives: iG FR-S
![]() Ps i agree with you.. Just want others to learn so we don't have to repeat. Where i was going with this: Rpf1 in 17x7 or 17x8 weighs less than 17x9. D1 star spec in 215/xx weighs less than 245/xx or 255/xx. In other words if you REALLY cared about weight... Of course extra grip doesn't hurt. And wider does look better. peace
"The best track modification you can ever make is between the steering wheel and seat." - CSH Last edited by ill86; 11-04-2012 at 01:07 PM. |
#232 | |
Drives: GLI
In the case of the RPF1/Star Specs 17x8 according to TR weighs 15.6 lbs 17x9 based on research around the internets weighs 15.9 lbs Assuming 225 for the 17x8, the Star Specs weigh 26 lbs Assuming 255 for the 17x9, the Star Specs weigh 28 lbs 17x8 total = 41.6 lbs 17x9 total = 43.6 lbs Stock I believe is ~41 lbs or so. Compared to stock both of the alternatives should be faster on a track. Compared to each other, will the 2 lb increase per corner contribute to a slower laptime even though there is more grip? Obviously this is getting into the nitty gritty, but now I'm curious. |
#233 |
Drives: GLI
Follow up question.
Why would a +45 be better for handling vs a +35? If a +35 pushes out the wheels further giving the car a wider track, isn't that better for grip? |
#234 | |
Drives: iG FR-S
Yes, wider is better. ![]() Replying to your previous post next.
#235 | |
Drives: iG FR-S
![]() In my professional opinion ,grip is more important in your case. Here is a link to read: http://hpwizard.com/rotational-inertia.html#answers
"The best track modification you can ever make is between the steering wheel and seat." - CSH Last edited by ill86; 11-04-2012 at 03:44 PM. |
#236 |
Drives: Mint-Tiffany blue FRS
drag wheels
hey im kinda a noob with tires and wheels what size of tires would you need to get for a drag dr-31 17x8
would P245/45ZR17 95W work? or would if be to big? any help will get a thanks!
#237 |
I usually post drunk
| The Following User Says Thank You to #87 For This Useful Post: | kendalldwhite (11-04-2012) |
#238 |
Drives: GLI
Why does everyone always recommend the narrower offsets then? Many times on this forum alone I've seen that kind of recommendation.
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
