Old 09-23-2025, 07:50 PM   #1
redlined600
redlined600's Avatar
Drives: Fr-s
Driveshaft carrier bearing movement
Hey all, I was checking the car over and this seemed like an excessive amount of movement from the carrier bearing, but tbh I've never checked it before. Can anyone confirm it this is normal or not.
redlined600 is offline   Reply With Quote
Old 09-25-2025, 11:49 AM   #2
norcalpb
norcalpb's Avatar
I'm going to check the play on mine this weekend, but I want to say yes.
Since the carrier bearing isn't serviceable, if I were you I'd just buy a used GR86 driveshaft and call it a day. Lighter, less miles with less play, CV joint that replaces the U-Joint all for ~$150 shipped to your door.
The Following User Says Thank You to norcalpb For This Useful Post:
callisto (09-27-2025)
Old 09-25-2025, 03:46 PM   #3
callisto
Drives: 2019 Subaru BRZ
Seems normal enough. There’s a YouTube video somewhere of it doing that under load, too. Look up the JXB carrier if you’re curious about alternatives.
callisto is online now   Reply With Quote
Old 09-25-2025, 05:37 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I hated the feel of the 2 piece shaft. I could feel it off balance especially at low speed. That's why I went one piece.
Did the same thing with an Isuzu Rodeo I had years ago. I was going thru carrier bearings like crazy, so bad I had it customized with a one piece shaft. No problem after that.
Old 09-26-2025, 04:59 PM   #5
redlined600
Drives: Fr-s
Good suggestion, I'll keep in mind for the future. This is already a modified driveshaft for a kswap so I'd rather not modify another one unless I have to.
I've seen the videos and agree that it kinda appears normal. I think the JXB carrier looks like a reasonable option to tighten things up.
I'm not super interested in using a 1pc driveshaft.
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 06:21 PM
Cam Carrier Oil Leak (hole in the cam carrier) Subaru86 Issues | Warranty | Recalls / TSB 0 02-22-2017 02:50 PM
Driveshaft carrier bearing Phothiraj Engine, Exhaust, Transmission 2 09-14-2016 07:53 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 11:39 PM
PST vs Driveshaft Shop CF Driveshaft? RehabJeff86 Engine, Exhaust, Transmission 4 08-26-2013 01:39 AM
