Old 09-14-2016, 05:52 PM   #1
Phothiraj
Drives: Lightning Red BRZ
Driveshaft carrier bearing
So I know you can find just the bushings alone for this piece but is there any part # or vendor out there that actually sells the entire assembly? Dealership wants to only sell me the entire driveshaft assembly when it's only a worn out bushing.
Phothiraj is offline   Reply With Quote
Old 09-14-2016, 06:27 PM   #2
gramicci101
Off Topic
I found torque solutions bushings, but not the entire assembly. The dealer has a single part number from slip joint on the transmission end to u-joint on the diff end, so they're not going to break it down further than that. If you want to replace the carrier assembly your best bet is to find someone who swapped their driveshaft and buy it from them.
Old 09-14-2016, 06:53 PM   #3
Phothiraj
Thanks on the quick update, hopefully I can find anybody around my area who recently switched out driveshafts.
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
