Old 02-22-2017, 01:50 PM   #1
Subaru86
Drives: subaru brz limited
Cam Carrier Oil Leak (hole in the cam carrier)
I had an oil leak that occurred approximately 40k miles, I had no issues prior to that. This issue is on the driver side cam carrier (where the intake manifold sits on top). I originally thought it was a bad cam carrier seal, but it turns out to be there is a hole in my cam carrier. It is currently at the dealership, and luckily covered under 5yr/60k power train warranty. I thought I would share this with everyone since this is a very unique case that I could not find a similar situation anywhere. The dealership originally blamed the leak to a "loose oil filter" which didn't even make sense since the location of the oil leak was spilling near the driver side firewall and dripping down from the same side. They said the only reason they are going to warranty it is because they did not properly diagnose the issue the first time. That means I am lucky or they would have had an excuse to void the warranty due to the related items on the bottom. A picture is attached that I requested from the dealership.
Aftermarket parts:
ACT SB8 HDSS clutch and fly
Mishimoto inlet tube
MXP headers w/ overpipe
OFT e85 tune
Volk ZE40's
Voodoo13 fully adjustable rear control arm, toe, trailing arm.
Subaru86 is offline   Reply With Quote
Driveshaft carrier bearing Phothiraj Engine, Exhaust, Transmission 2 09-14-2016 06:53 PM
TWM Front Carrier Bushing... Ty89m Engine, Exhaust, Transmission 15 10-10-2015 12:09 PM
Saris Bones 2 Bike Carrier (FL) fourvalleys Miscellaneous 1 06-27-2014 01:25 PM
BRZ. Remove DRL LED with different carrier? Proof Cosmetic Modification (Interior/Exterior/Lighting) 0 05-13-2014 08:08 PM
