Old 06-19-2025, 03:11 AM   #1
esrun
Drives: Scion Frs
Help P050B After Automatic Transmission Fluid Drain and Fill
I have a 2015 Scion Frs stock with 72k miles and I did my 1st automatic transmission fluid drain and fill and rear differential fluid change which I found also the steps in here. https://www.ft86club.com/forums/showthread.php?t=129898 . I followed the steps in checking the ATF temperature by inserting jumper between pins 4 (common ground) and pin 13 (TC) on your OBD2 port. I forgot to remove the jumper on OBD port because I went under the car to do final check of ATF level and when I was happy with the level and torqued the plug. Turn off the car with the key on the ignition. After maybe 20mins I noticed I forgot to remove the jumper on OBD2. I turned on the car to test drive but check engine light is on and used a scanner with code P050B. Do you think I messed up something that's why I'm getting the code. I reset the code and drive the car about 55miles and its driving fine, the CEL is not showing up, I did not see anything out of the ordinary. Any recommendation what should I check. I'm planning to check the ECT tomorrow.
esrun is offline   Reply With Quote
Old 06-19-2025, 11:45 AM   #2
whataboutbob
AutoX-10/10ths every run
https://www.obd-codes.com/p050b
What are some of the common causes of the code?
Causes for this code may include:
  • Defective ECT sensor
  • Severe vacuum leak
  • Open or shorted circuits or connectors
  • Bad CKP or CMP sensor
I'd say keep driving the car, watch for any malfunctions or return of the error code/CEL. if none show up you're _probably_ okay.
Build thread:Here
Old 06-22-2025, 09:54 PM   #3
esrun
Drives: Scion Frs
Update. I just got worried since I’m due for smog for registration in California. I drove it till readiness test is completed so far no more code. Thank you.
The Following User Says Thank You to esrun For This Useful Post:
whataboutbob (06-23-2025)
Manual transmission fluid flush vs drain and fill Windycitystig Engine, Exhaust, Transmission 6 05-27-2019 05:05 PM
Just a drain and fill for ATF change Ernest72 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 06-11-2018 06:34 PM
Disable CEL code P050B Flat_4_Life Software Tuning 2 10-26-2015 06:42 PM
Transmission fill and drain plugs goshem Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 07-27-2014 01:37 AM
MT fill and drain washers diirk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 11-09-2012 01:24 AM
