Drives: 2017 BRZ MT, 2009 Civic sedan AT
resulting in the inability to completely drain the old oil during an oil change
#2 |
Drives: 2013 Subaru BRZ Sport
Because if you scrape, you want your drain plug to not be ripped off.
If you angle the car properly, you will be able to drain most of the old oil. In case you absolutely want to get the last drop of the old oil out, you can use a syringe, but normalls this is not necessary. |
| The Following User Says Thank You to Trollhart For This Useful Post: | cmiovino (08-19-2024) |
| Need help extracting drain plug... | SamtheKorean | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 33 | 01-25-2020 06:18 PM |
| Quick Drain Plug | dholloway543 | Engine, Exhaust, Transmission | 29 | 11-14-2019 02:08 PM |
| Why isn't there a 2nd drain plug on the bottom of AT oil pan? | FT86.ca | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 03-04-2017 09:40 PM |
| Drain plug leaking...what to do... | OUGrad05 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 03-28-2016 03:01 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 08:36 PM |
