Old 05-24-2023, 12:20 PM   #1
Spektyr
Drives: GR86
Wheel Spacers/Lugs Question
I'm considering some mild (10mm-ish) hub centric spacers for my Gen2 GR86.
I'm aware these cars have a reputation for the wheel lugs being made from soft cheese so there's non-zero cause to just change them out while I'm doing that anyway, but I'm not entirely convinced I want to do that right now.
So the question is: How thick can you go on wheel spacers before you need longer lugs?
Follow up question: if I want/need to replace the lugs, what's the best way to be sure I'm getting good ones and not some crappy knock-off alloy that's going to shear off under load?
Spektyr is offline   Reply With Quote
Old 05-24-2023, 01:02 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
I believe 3 or 5 mm is the max you can do with stock studs.
ARP are the go-to. Most other brands might be as good but they're not cheap enough to warrant not going with ARP, IMO.
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Dzmitry (06-01-2023), Spektyr (05-24-2023)
Old 05-24-2023, 11:58 PM   #3
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '24 CX-50 Meridian
Highly recommend buying H&R Hubcentric spacers, since they actually come with extended lug studs to accommodate for the additional spacing. Takes all of the guess work out of finding studs that have enough length.
I have 15mm H&R Hubcentric spacers on my BRZ (to help make my 17x7.5 +48 Gram Lights 57Cs not look so wimpy), and they came with lug studs that were exactly 15mm longer than the stock studs, so you get the same lug engagement as factory.
JBezugs is offline   Reply With Quote
Old 05-25-2023, 02:49 PM   #4
Spektyr
Drives: GR86
Looks like they're only sold at brick-and-mortar distributors, and nothing within 300 miles of where I live.
Do they just not sell online at all?
Old 05-25-2023, 02:53 PM   #5
JBezugs
Good Job Subaru!
JBezugs's Avatar
In the US, EvasiveMotorsports carries them online.
The filters in this link should be pre-set for our car:
https://www.evasivemotorsports.com/s..._By=disp_order
The Following User Says Thank You to JBezugs For This Useful Post:
Spektyr (05-26-2023)
Old 05-30-2023, 03:08 PM   #6
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I did Eibach spacers with extended studs, worked great.
3mm is the max I'd go with stock wheels (and aftermarket wheels may be worse), bone stock there's only a tiny safety margin of lug engagement as it is.
Old 05-30-2023, 04:49 PM   #7
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
3-5mm for slip on spacers is the max on stock lugs
Bolt on spacers are essentially unlimited
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
wheel spacers question nammie81 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-17-2016 12:10 AM
Spacers with closed lugs phrosty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 08-26-2015 06:16 PM
Wheel Spacers Question bhbnuckle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-03-2014 01:54 AM
